Question about Aastra Telecom Aastra MDC Centrex Telephone
Very low volume on handsfree key. Can not increase volume using the volume button.
I have just got a used nokia CE0681 bluetooth headset, how do i connect it with my nokia 6120c?
All these given solutions are not catering your problem unfortunately; because your problem seems to be the following "You are not at all able to find your bluetooth headset from your phone, pairing is a far off thing" right?
So, here is the simple solution that no one has given here and on other sites (I myself was confused, but finally found it out):
1. Turn bluetooth of your Mobile on.2. Put it into "shown to all" mode.
3. Now pick your bluetooth device, and simultaneously click on the multifunction key (The middle one that blinks) and the "+" volume key for around 6 seconds or more; you'll see that blue blinking light will become static (and it means that your bluetooth device is now "Searchable" by your phone).
4. Start "Pair new device search" from your Mobile, and your Phone will find the bluetooth device.
5. It will ask you for a passcode, just enter 0000.
6. Pair both devices now.
7. The static blue light (Which became static when you pressed the middle multifunction key and "+" volume key together for some seconds) will now start blinking again (in a 3 sec interval approximately).
Your handsfree is now connected, do a test call and confirm.
In case you find any volume problem, then know that the default volume after connecting a bluetooth handsfree is at low level, so just increase it using your Phone's volume keys/ controls and it shall be all fine.
Vote up if it helps, it is the genuine solution of this problem though; I tested it several times. :)
PS: I'm writing this while logging off in haste, pardon any spell/ typo mistakes. :P
Jun 26, 2011 | Cell Phones
Need to increase the volume when using handsfree.
Please post the make and model of your cell & handsfree unit, if any, and we will help you to increase your volume.
Mar 13, 2011 | Cell Phones
How to connect a bluetooth headset with nokia5230?
You need to switch on the bluetooth in both device then search the device in your phone ,same time while you searching in your phone press the button repeatedly in your bluetooth headset.Then device will found in the phone and connect it.
Thanks Fixya team
Sep 29, 2010 | Nokia 5230 Cell Phone
Speaker volume too low in handsfree mode its loud enough.
I hope you know that there are two speakers, one for Handsfree and the other to let you hear without handsfree activated. Before you activate the Handsfree, press the volume key on the phone and turn it up to the maximum level. If there's no changes and you don't see any difference, then there's must be faulty with the speaker (small speaker), you better replace it. If you are not good with repairing mobiles, please don't try to fix it yourself, instead of fixing, you may damage it, you better take it to a local mobile repairing center or nokia care and get it fixed.
Good luck.
Thanks for using FixYa.
Sep 18, 2010 | Nokia 3110 Cellular Phone
The volume on my nokia n-86 hands free is too low.the speaker works properly but when the handsfree is used the volume is low
when you use hands free then again open the volume by pressing volume key in this way you can increase volume it can help you try it or change hands free orr you should use original hf
Jun 09, 2010 | Nokia N86 8MP Unlocked Dual-Slider 3G...
Is there any way of increasing the volume? I can't use the handsfree because it's not loud enough - I can't hear them and they can't hear me
Press HandsFree once, and then press DELETE (several times to scroll through loudness levels from 1 to 4. Then, press Handsfree to confirm setting. Press DELETE to exit & view normal screen.
Jan 05, 2010 | Innovage Touch-Panel Phone 1507102
Very low volume on 'handsfree' option; whereas the vol. for the line button can be quite loud
Hi.
The Volume function of that phone is controlled by the up down vol button on the phone. the only time it does anything is when that function is being used. ie. when you have the handset in hand the vol buttons control the handset volume, while the phone is ringing the buttons control the ringer volume etc.
Dan
Oct 09, 2009 | NorStar M5316 Phone, NT4X42 (Refurbished,...
Handsfree Volume
Lucky you, mine doesn't even have a volume function!
Aug 28, 2008 | Innovage Touch-panel Phone 1502084
Cant hear an incoming caller talk
Press the navigation key: right arrow to increase volume, left to decrease volume. Maximum volume is 7.
Dec 11, 2006 | Motorola Mobility Earwrap Handsfree For...
Aastra Telecom Aastra MDC Centrex Telephone Logo
54 people viewed this question
Top Aastra Telecom Lands Phones Experts
Illimar Saatvali
Illimar Saatvali
voyager663rd
Level 1 Expert
Are you an Aastra Telecom Lands Phone Expert? Answer questions, earn points and help others
