Question about HP LaserJet 4250n Printer
I need printer repair for an HP Laserjet 4250n. I believe I have some gears that may need replaced
  • 39 Answers
Mabee the hard drive has failed . try entering bios and see if the hard drive is recognised .If not try turning the computer off unplug it then reconnect the drive data cable and power cable
then re- start the computer and see if it is recognised. some models of older hard drives needed a driver installed during set up -- you usually have to put the driver on a floppy disc and hit the f6 button when prompted by windows set up to install third party drivers . I hope this helps
Posted on Apr 08, 2011
Replace HP4350 swing arm gear
The swing arm gear and spacer are available here:
http://www.ccl-la.com/catalog/product_info.php?products_id=299
And it comes with instructions. Simple to do, it takes less than 10 minutes to replace.
Mar 28, 2013 | HP LaserJet 4250n Printer
Geting erro of 59.00 in 4250 printer
hi
HP LaserJet 4250n Printer - (Q5401A)
replace the fan --- erro 59.00 is failed fan.
on right or left of printer
Fan RK2-0278-000CN In stock
Cooling fan - Located on left side of printer (FN101)
RoHS: Modified
93.60 0.00 93.60 RK2-0280-000CN In stock
Cooling fan - Located on right side of printer - Provides air to the print cartridge area (FN103)
RoHS: Modified
Aug 01, 2011 | HP LaserJet 4250n Printer
I am having printer quality issues with hp laser jet 4250n. All the words are blurry.
Replace the Fuser, it is behind the back door Part # RM1-1082.
Remove back door and push two blue tabs on fuser, remove and replace.
Jan 10, 2011 | HP LaserJet 4250n Printer
What is the default ip address of the printer hp laserjet 4250n?
There is no default IP address on HP printers with Jetdirect print server card.
You set the IP address in the printer's network settings. The IP address need to be set to match your network's address range.
To configure the HP network printer to work on your network, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559242-setting_up_hp_jetdirect_print_server_p
Dec 14, 2010 | HP LaserJet 4250n Printer
Banging noise when printing. Changed cartridge and didn't help.
That is a swing gear and its damaged. Service will be needed. The part is an RM1-0043 Swing Plate Assy and you may also need to replace the fuser RM1-1082. The cost plus repairs will be around $250-$300 due to the 45 minutes it will take the service tech to remove the swing gear assy.
Jun 24, 2010 | HP LaserJet 4250n Printer
Hp 4250 laserjet is noisy and has numerous jams. page count is 137,619 maint kit has 39% left when searching event # 13.05.00 Fuser output paper late jam
Probebly the swing gear assy, this assy is driving the fuser, is defective. This is a common problem with these machines. Replacing the gear assy should solve your problem.
Feb 16, 2010 | HP LaserJet 4250n Printer
Sir, We have a hp laserjet 4250n printer since
Replace the fuser unit (they last about 75K pages in my experience)
1. Power down the printer and unplug it
2. Remove the fuser from the back side of the printer
3. Replace the fuser unit with a new one
4. Turn the printer back on
Dec 24, 2009 | HP LaserJet 4250n Printer
How do i clear an 49.4C18 error message on a HP LaserJet 4250n?
Any of the 49 errors are from the formatter board, you may need new memory, or a new board. The machine doesn't reset from this error without a new board.
Aug 11, 2009 | HP LaserJet 4250n Printer
Printing Problem
GO ON LINE AND TYPE INTHE FOLLOWING INFORMATION; EXAMPLE:
HP LASERJET 4250N PRINTER ERROR MESSAGE KERNEL
ENTER
"" "" "" ILLEGALOPERTORSEQUENCE
ENTER
HP LASERJET 4250N ENDCHAR ERROR
ENTER
HP LASERJET 4250N PRINTER POSITION 24 ERROR
ENTER
HP LASERJET 4250N ERROR MESSAGE [ CODE # ]
ENTER
ROD THE CANDYMANGANDY
Dec 20, 2008 | HP LaserJet 4250n Printer
HP Laserjet 4250n printer error 59.00
Replace the main motor assembly. A qualified tech will need to do this.
Dec 08, 2006 | HP LaserJet 4250n Printer
HP LaserJet 4250n Printer Logo
42 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
