Question about 5303L 2Way LCD Remote Start Security System
Remote in a constint sleep alarm will not go off unless holding lock button, but will still unlock and lock also no cherps when locking and unlocking?
4 Suggested Answers
  • 4 Answers
SOURCE: can anyone help me get my stereo unlock code for a 98 tahoe?
hmm that is realy a problem because this is security lock for stealing car radios.. you must have a 4 digit number on smal paper and a serial number on it alsso,but the solution is also to call the factory of the radio and thel them your serial on radio and thay will give you your 4 digit number PIN when you confirm you bought your radio leagaly
Regards,bis3946
Posted on Jul 14, 2009
SOURCE: my avital 4103 does not unlock the passenger door
Its not the avital piece that's the problem, it's your INSTALLER that is/was the problem....haha, got somethin wired wrong!! It only does what you install it to do! :)
Posted on Dec 22, 2009
logosc75
  • 625 Answers
SOURCE: I am trying to remote start my car and it wont
The secondary chirp alerts you to an open trigger, probably the hood pin switch since the car is not remote starting. Check under the hood for a broken or bent out of place hood pin switch. Make the adjustment so the pin makes contact with the hood when the hood is closed.
Posted on Feb 05, 2011
Avital alarm wont lock or unlock doors
If the remote is arming and disarming the alarm then, it should be locking and unlocking the doors as well. The door lock and unlock wires need to be connected. Are sure that they are connected? Do the door locks work with the switch?
Mar 03, 2014 | AviStart 5303 2-Way Security / Remote...
Tip
How to Program Acura Remote Transmitter
Acura Remote Alarm / Central locking
Model: CL Year: 2001-2003
Model: TL Year: 1998-2006
Model: MDX Year: 2001-2006
Model: RDX Year: 2007-2009
Model: RL Year: 1996-2004
Model: RSX Year: 2002-2007
Model: TSX Year:2004-2008
System Operation
  • Pressing remote transmitter LOCK button once activates alarm and central locking.
  • Pressing remote transmitter UNLOCK button once deactivates alarm (if fitted) and unlocks driver's door only.
  • Pressing remote transmitter UNLOCK button once also activates driving position memory. Driver's seat and mirrors move into memory position specified on remote transmitter when driver's door opened.
  • Pressing remote transmitter UNLOCK button twice within 5 seconds unlocks all doors.
  • Pressing remote transmitter trunk release button for 2 seconds activates trunk release.
  • Pressing remote transmitter PANIC button for more than 1 second activates panic alarm.
  • Pressing any of the remote transmitter buttons deactivates panic alarm.
  • If vehicle unlocked and doors not opened within 30 seconds, locks are reactivated.
Synchronization.
when
  • Remote transmitter battery replaced.
How
  • Press remote transmitter LOCK button or UNLOCK button 5-6 times.
  • System should now lock and unlock vehicle to indicate synchronization procedure complete.
  • Check operation of remote transmitter
Programming
How
  • Obtain all remote transmitters.
  • Switch ignition ON.
Proceed as follows:
NOTE:Point remote transmitter at central locking signal control module (located behind glove box).
  • Within 4 seconds: Press LOCK button or UNLOCK button of first remote transmitter.
  • Within 4 seconds: Switch ignition OFF.
  • Within 4 seconds: Switch ignition ON.
Repeat procedure above twice.
  • System should now lock and unlock vehicle to indicate programming mode activated.
Within 10 seconds:
  • Press LOCK button or UNLOCK button of first remote transmitter, allowing doors to lock and unlock once.
  • Press LOCK button or UNLOCK button of each remaining remote transmitter to be programmed, allowing doors to lock and unlock once as each remote transmitter is programmed.
  • Switch ignition OFF.
  • Remove key
  • Check operation of all programmed remote transmitters.
Immobilizer
System Operation
  • System arms 5 seconds after switching ignition OFF. Immobilizer warning lamp flashes during this time
  • Immobilizer warning lamp illuminates for 2-3 seconds.
  • If immobilizer warning lamp illuminates for 2-3 seconds then flashes rapidly:
  • Key code not recognized.
  • Remove key and try again.
Programming
When
  • System malfunction.
  • Key added or replaced.
How
Immobilizer can only be programmed using diagnostic equipment.
Model: MDX Year: 2007-2009
Model: TL Year: 2007-2008
System Operation
  • Pressing key LOCK button once locks the vehicle.
  • Pressing key LOCK button twice within 5 seconds activates the alarm.
  • Pressing key UNLOCK button once unlocks the driver's door only and deactivates alarm.
  • Pressing key UNLOCK button within 5 seconds unlocks all doors and tailgate.
  • Pressing key UNLOCK button within 5 seconds and holding will open windows and sunroof
NOTE: Models with "Technology Package": Alarm central locking functions can be altered using digital multifunction display in instrument panel.
  • Pressing key PANIC button for more than 2 second activates panic alarm.
  • Pressing any of the key buttons or turning ignition ON deactivates panic alarm.
  • System will automatically lock all doors when vehicle is driven above 15 mph (if function selected).
  • If vehicle is unlocked and doors or tailgate not opened within 30, 60, or 90 seconds (depending on programming), locks and alarm system are automatically reactivated.
  • Pressing tailgate release button once will open, close or reverse direction of tailgate.
Programming
When
  • Key remote transmitter added or replaced.
How
  • Obtain all keys fitted with remote transmitters.
  • Ensure doors, trunk / tailgate and hood are closed and unlocked.
NOTE: A maximum of 5 remote transmitters can be programmed.
Proceed as follows:
Repeat procedure above twice. Locks should cycle when button in pushed.
  • Within 4 seconds of each other press LOCK button or UNLOCK button of each remaining remote transmitter to be programmed, allowing doors to lock and unlock once as each remote transmitter is programmed.
  • Remove key.
  • Wait 10 seconds.
Immobilizer
System Operation
  • System arms when vehicle is locked using the remote transmitter.
  • If key code is not recognized:
  • Engine starts, then shuts off.
  • Immobilizer warning lamp flashes once, then blinks until ignition is switched OFF.
  • With ignition switched OFF, immobilizer warning lamp will flash 10 times to indicate the system has reset.
Programming
When
How
Model: RL Year: 2005-2009
Programming
When
  • Remote Transmitter added or Replaced.
  • System Malfunction.
How
Remote Transmitters can only be programmed using diagnostic equipment.
Automotive and Commercial Locksmith Acura Remote Transmitter Programming...
on Mar 26, 2015 | Televison & Video
Keyless remote
hi Alan
what procedure you are doing for remote matching?
try this one and let me know.
1 Unlock the car, get in and close the door
2 Switch ignition on
3 Press the door lock button on the dash to lock the car
4 Press and hold the door lock button on the dash, the alarm will beep
5 Keep holding the door lock button on the dash, press and hold the lock on the remote,
the alarm will beep
Repeat (5) for the other remotes,
6 leave the door lock button on the dash, the alarm will beep, switch ignition off
Feb 13, 2014 | Suzuki Cars & Trucks
How do I activate the alarm on my Dodge
The 4103 is not an alarm. It's a remote starter with keyless entry! Do you want the horn to sound when locking and unlocking? First, make sure that the horn wire was connected. Press and hold the lock button on the remote. That should activate the panic/car finder. The horn will begin to sound. Press and release the lock button to turn it off.
If the horn is connected and, you want said horn to sound when locking and unlocking, open door, turn ignition on then off, press and hold programming switch until the horn chirps once. Release programming button, press and release programming one time then, press and hold programming button. While holding the programming button press and release unlock button on remote. You should hear two chirps from the unit. Release programming button, turn ignition on to exit programming, Test system.
Feb 13, 2013 | 4103LX Remote Start System with Two...
MY 94 850 VOLVO WILL NOT START NEW BATTERY AND STARTER IT DID WORK AFTER THE STARTER WAS INSTALLED BUT THE PERSON THAT BROUGHT IT BACK STATED THAT SHE HEARD THE ALARM CHERP THEN IT WOULDNT START (DO YOU...
replace remote battery to make sure, but if alarm is activated it continous to chirp the alarm or if your alarm system is set by the manufacturer try to relearn the program, if all fuse are ok, and your remote lock/unlock is work, check for lose ground connection, if remote is not working, replace the battery then try to do this. swtch ignition in 10 seconds to on-off-on-off-on-off-on-off-on wait 30 seconds, press any button of the remote once, turn igniton off, after 30 seconds start the car, if not go to the nearest service center to check the troublecodes
Jun 26, 2010 | 1995 Volvo 850
I have just charged the battery on my 1996 r reg audi a4 now central locking has disabled as has alarm system! any ideas
unlock the car with the key/hold over for 30 secs.
lock the car with the key/hold over 30 secs.
then press/hold down unlock button on remote.
you have just reset your alarm/central locking system
change remote batteries every 2 years...... both remotes....
May 08, 2010 | 1997 Audi A4
Procedur to reset theft system
most of the alarm systems reset procedures are similar,lock with key/hold over for 30 secs then unlock/hold over 30 secs.(or vice versa)
OR press/hold unlock button on remote 30 secs,then press/hold lock button
OR put key in ignition,turn onto running position(not starter)and press/hold alarm button 30 secs
once car starts, it will remember codes in keys.
Apr 01, 2010 | 1997 Pontiac Grand Am
New alarm fob for pt cruiser not coded to car (correct serial numbers)
Programming
When
Remote control added or replaced. System malfunction.
How
Switch ignition ON. Press and hold lock button Fig. 1 [2] for approximately 10 seconds. Keeping lock button depressed, press and hold unlock button within 10 seconds. Programming mode activated (acoustic signal will be heard). Proceed as follows: Release lock/unlock button. Complete the following within 30 seconds: Press lock or unlock button of first remote control. Correct programming indicated by a single acoustic signal. Press lock or unlock button of second remote control. Correct programming indicated by a single acoustic signal. Repeat above procedure to program any remaining remote controls. Remote controls can also be programmed using diagnostic equipment.
NOTE: A maximum of 4 remote controls can be programmed.
Feb 03, 2010 | 2001 Chrysler PT Cruiser
My valet remote control RPN491 Starts vehiclr and unlocks doors but will not lock doors do I need to reprogram remoteto unlock doors?
Ok you said "unlock doors' but you said it already unlocks the doors. This remote should lock and unlock door on same button, if you are describing the 2 button remote. If it is not then it could be alot of things. Does the alarm lock itself? Does the alarm lock the door when you turn on the ignition? More info is really needed. Like what veh and what model alarm.
Sep 11, 2009 | DEI Valet Keyless Entry System
5303L 2Way LCD Remote Start Security System Logo
Top Avital Vehicle Parts & Accessories Experts
D. E. Hev
Morgan Kane
Level 1 Expert
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
