I would like to reset it back to factory settings thank you
    Problem Solver:
  • 8 Answers
At most motherboards there are 2 main ways to do it.
1st one is to boot pc and depending on motherboard press "F2" or "Delete" at pc startup.
Then you should be able to enter at bios setup of your motherboard.Now search carefully without changing anything you dont know what it is for.Usually at the last options you might have a "Reset to factory setting" or something equivalent, press it.That should do the trick.
In case the above solution doesnt work, you can move to next solution.
Get a screwdriver to open the side cover of your pc.
Unplug the power supply cable.Remove the 2 screws at the rear.Remove carefully the side lid and watch carefully the inside of your pc.
There you should be able to spot a flat silver coloured battery.Sized about of the size of 1euro coin.
now the options are 1 of the following:a)Either you remove it for about 1 min ,replace it and the motherboard is reseted.b) either there is a button that resets the motherboard which should be close to the batter c) either you should change a jumper setting and boot computer so that it resets.The last option is the most tricky one cause you need to have the manual of your motherboard cause if you change wrong jumper you could hurt to a big degree your motherboard.
Try all the above solutions with the sequence i pointed out and reply if you are about to reach the last one.
Posted on Apr 08, 2011
  • 27,725 Answers
During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart also click start all programs accessories scroll to system tools from there you should see a system restore click next a sytem date should open up select the date you want to restore your computer to or if you want a full factory restore or Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
Hope this helps
Kobo frozen. Willl not respond to touching button
Performing a basic reset A basic reset will force your eReader to restart properly. In many cases, this is enough to restore your eReader to normal.
  1. If possible, turn off your eReader.
  2. Locate the small hole on the bottom of your eReader.
  3. Unfold a paperclip and slide an end into the hole.
  4. Press gently until you feel a click. Your eReader should restart.
Performing a factory reset If a basic reset doesn't work, you can perform a factory reset to restore your eReader to its original settings. After a factory reset, you'll have to set up and sync your eReader again.
If you perform a factory reset on your eReader, you'll:
  • Remove all books from your eReader. Any books you purchased from Kobo can be re-downloaded from the Kobo Cloud after a factory reset.
  • Lose any bookmarks and annotations you made in your books since you last synced your eReader.
  • Sign out of your account on your eReader.
  • Reset all of your settings and preferences.
  • Return your eReader to its original settings.
  1. If possible, back up any books or documents that you added to your eReader using Adobe Digital Editions, or that you manually added using your computer. You do not need to back up any books you bought from Kobo. Any books you purchased from Kobo can be re-downloaded from the Kobo Cloud after a factory reset.
  2. Go to your Home screen.
  3. Tap the ios-menu.svg Menu icon at the top of the screen.
    The Quick Settings panel will appear.
  4. Tap Settings.
  5. Tap Device information.
  6. Tap Factory Reset under Advanced.
  7. Performing a factory reset If a basic reset doesn't work, you can perform a factory reset to restore your eReader to its original settings. After a factory reset, you'll have to set up and sync your eReader again.
    4. Tap Settings.
kobo com help Resetting your Kobo Glo HD
Jun 30, 2016 | Kobo eReader
What are the advantages to doing a factory reset? I'am setting up tx in new place and need to start fresh. Does the tx reset?
Hello Arthur, The reset will take all of the settings back to factory default. This includes network settings and speaker settings. Thanks, FJD
Mar 27, 2016 | Onkyo TX-NR801 Receiver
How can I put a sanyo ce32fwn5-b back to factory settings thanks
You have to enter its service mode option to set the TV to its factory settings. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Dec 12, 2014 | Sanyo Televison & Video
Reset nokia e71 to factory settings
Hi
To reset the phone to factory settings please understand that this will delete all data on the handset:
  • Switch on the phone
  • While its on standby mode, press *#7370#
  • Then the phone asks for a password, enter 12345 which is the default password.
  • The phone will reset.
Thank you and good luck.
May 29, 2012 | Nokia E71 Smartphone
How to reset htc mozart
Warning: Resetting your phone will erase your phone completely. Remember to back up your phone information and settings.
To reset the phone to factory settings, please tap on
START > All apps > Settings > About > Reset your phone.NOTE 1:
Resetting your handset to factory or manufacturer's default setting will delete all the data stored on your phone memory, please back up your files first.
I hope this information will be helpful. Thank you for using FixYa!
Jun 07, 2011 | HTC 7 Mozart Cell Phone
How do i reset to factory default settings if i lost password
This router will have a Reset button in back side of router.
Press that button for 30 Seconds. It will go back to factory default setting.
Thanks for using FixYa.
May 19, 2011 | D-Link DES 3226 (DES-3226) 24x10/100 Mbps...
How to format HTC WILDFIRE A33333
Factory reset is not a step to be taken lightly. It will permanently delete all your data and customized settings, and will also remove any applications you've downloaded and installed. Be sure to back up any data and files you want to keep before you do a factory reset
Performing a factory reset via settings:
The most convenient way to do a factory reset is via the phone settings.
From the Home screen, press MENU, then tap Settings.
Scroll down the screen, and then tap Privacy > Factory data reset.
On the Factory data reset screen, tap Reset phone, and then tap Erase everything.
Performing a factory reset using phone buttons:
If you cannot turn on your phone or access the phone settings, you can still perform a factory reset by using the buttons on the phone.
With the phone turned off, press and hold the VOLUME DOWN button, and then briefly press the POWER button.
Wait for the screen with the three Android images to appear, and then release the VOLUME DOWN button.
Press VOLUME DOWN to select CLEAR STORAGE, and then press POWER.Press VOLUME UP to start the factory reset.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Feb 25, 2011 | HTC Computers & Internet
HOW TO RESET BACK TO FACTORY DEFAULT SETTINGS FOR CWA-854
You need to login to the router and go to the save/reload settings section.
You can reset this Wireless Access Point back to its default settings by clicking on Reset button, and then press OK button to confirm your decision. Note: you can also hold down the reset button on this Wireless Access Point’s panel for more than 10 seconds to reset its default settings back to factory default.
Please don't forget to rate me!
Thanks
Jul 08, 2009 | Cnet CWA-854 (CWA854) 802.11b/g Wireless...
Reset to factory specs for blackberry curve 8330
how to reset the Curve back to factory state (a complete wipe-out). Please note if you just want to reboot the device, you only need to take out the battery.
To reset the phone back to factory state:
Go to Options -> Security Options -> General Settings
Press the BlackBerry Menu key and select "Wipe Handheld" and type in "blackberry"
Thanks.
Jun 04, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
How do i reset blackberry curve 8330 to factory settings
Dec 28, 2008 | RIM BlackBerry? Curve 8330 Cellular Phone
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
