Question about Samsung B1245 Front Load Washer
My detergent tray fills with wather. Also, behind front access door when I unscrew the thing that I am suppose to frequently check water spews out.
    Brigadier General:
  • 6,277 Answers
Water spewing out indicates that either the filter requires cleaning (!) or the drain motor is jammed/malfunctioning. This first then guidance for your detergent tray.
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Detergent tray
I suspect that it is the conditioner/softener tray which is causing water to overflow into the dispenser drawer so it needs a thorough clean, paying particular attention to the sentences in BOLD ;-0)
Remove the complete drawer. To do this you will have to do one of the following-
  • Top catch- push down the lip/catch at the middle rear and pull the drawer out (that's how our Bosch one is removed)
  • release the catches underneath (our daughter's Indesit) or
  • lift upwards on the tray as it is coming out to clear the lip underneath.
One of these should enable you remove it
(I am having to guess some of the following!)
Once out identify which tray is for the conditioner- the others are simply 'chutes' and open-ended.
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
Please score these advices accordingly ;-0)
John C
Posted on Apr 08, 2011
How do I fix a washing machine that doesn't fill with water, but spins and drains? Water enters the detergent holder, but doesn't seem to make it to the tub. Draining can be heard as well, even though
Hum for one a front load H.E washer should not be having very much suds as u claim it had. Are u aware the front loads are made to use very little soap and if u use to much soap hence alot of suds, ur SUDS SENSOR will act up and can shut down any wash cycle. a trick is to run just water and some vinagar trough a couple loads if u can get to wash at all. Another issue u may have is a plugged line somewhere. or loose unconnected water hose line hence the water on the ground effect. u may want to check ur flow line from the entry into the tub where the water at the moment I cant recall the name of the gadget but it can get clogged or damaged and hinder the water from entering the tub
Jan 15, 2015 | Kenmore Washing Machines
Seems like there should be a pump or sending unit the would be controlled by the cycle timer. ProbAbly went bad. Hopefully you got the extended warranty?
I have had water leaking from underneath my dishwasher and have found that on filling, water overflows top of the water inlet unit
My Miele 828 dishwasher started to leak at the front left corner. The leak became worse. I tipped the machine on its side and removed the rubber moulding connecting the base of the drum to the pump. I cleaned it out and refitted it finding two small coins inside. The leak persisted. I took off the top of the machine by unscrewing the two screws on either side and pushing the lid backwards. I switched the machine on and, with a torch could see that the detergent dispenser had detached from the delivery pipe under it. Using advice elsewhere on Fixya I undid the three bolts around the door and the three screws around the detergent dispenser; one is deeply recessed and easily missed. Than I unclipped the drain pipe behind the little door at the bottom left hand corner at the front. The front then hinges out from the left with hinges at the right side making the leaking connection easily accessible. Make sure you get the rubber flange well up the plastic tube as there is no flange on the tube to secure it. A possible design fault but the unit has functioned for ten years before the connection failed.
Sep 24, 2013 | Dishwashers
Not enough water seems to be getting up inot soap area to mix it during wash leaving alot of unused soap behind after wash
Home Depot Sales Associate-
First make sure you are using a high efficiency detergent and not a standard detergent. The product should have HE in the corner. After that, make sure you are not overloading the tray. The detergent should not exceed the max fill line. If both of these requirements have been met, you may have a clogged line which typically is due to overfilling of the detergent tray. Call LG out if you are under warranty. If not, consider a professional anyways as accessing the water linkage is difficult without a diagram.
Mar 19, 2011 | LG WM-2277HW Front Load Washer
A steady stream/trickle of water leaks from tube behind the soap tray and flows out of the spout onto the inner rubber door gasket.. When I plug the tube with my finger, it give a "poof" of...
looks that you have problems with your water valve. make sure the fill hoses screens are clean and valve screen too. check water pressure, you need 20psi or more. if all checks good then replace water valve.
Feb 09, 2011 | Kenmore Washing Machines
Water is pouring out of my dispenser drawer
I have read other folks say that this has happened to them when a sock or wash cloth gets stuck behind the rubber seal of the door. There is a pipe that drains the water from your detergent tray and it may be clogged with a sock. Try feeling around behind the rubber seal in proximity to the detergent tray and see if there is a piece of clothing stuck in the pipe that drains the detergent tray. Also remove the tray and check the pipe from that end too.
May 04, 2010 | Kenmore HE2 Plus Front Load Washer
Water leaks
I had similar issue. Fill tube running from the bottom of detergent tray to the washer drum was plugged.... (by a sock!!!). How did it get there? I'll tell you. You see the drum seal (around the inside of the door) is not a tight seal. You can actually reach up behind it from where it meets the top of the drum. Anyway in my case, a sock made it's way through that seal and outside the drum and into the drum containment vessel. So when the drum spun (to dry the clothes and empty the water) it made a terrible noise. The sock became lodged at the base of the fill tube opening and plugged it thus not allowing any water into the drum. Instead, when filling, the water just flowed out from the bottom of the detergent tray and onto the floor. I hope this helps.
Jan 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The softener holder just fills with water but will not drain.
Is water left in the dispenser at the end of the cycle?
About two tablespoons of water remaining in the dispenser compartment at the end of the cycle is normal. At the end of the wash cycle, fresh water automatically cleans the dispenser. Check that the cycle is complete before opening the dispenser drawer.
Is the dispenser drawer clogged?
A clogged dispenser can block the flow of water through the dispenser and cause water to leak out. Manually remove the dispenser, and clean any leftover detergent or additives that could clog the flow of water through the dispenser. Also, check that the detergent drawer is always completely closed during the cycle. If the drawer is not closed completely, water can leak out onto the floor.
Are the additives dispensing too early?
Here are a few things that can cause the additives (detergent, fabric softener or liquid chlorine bleach) to dispense early:
  • Check that the dispenser is not overfilled. Do not fill past the MAX fill lines on the dispenser. Overfilling can cause early dispensing of liquid chlorine bleach and/or fabric softener.
  • Check that the detergent separator is in the correct position. For liquid detergent, the separator should be in the front position. For powdered detergent, the separator should be in the rear position. If the separator is in the rear position while you are using liquid detergent, it will dispense immediately, which is not how it is designed to work.
  • Use powdered HE detergent when using the DELAY WASH option. Liquid detergent may dispense prior to the start of wash.
Are the additives dispensing too late?
The additives will not dispense until the proper time if the DELAY WASH option is selected.
Dec 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer instructions need manual
You have a clogged pump.Find access to inside the machine,locate the pump and clean it out.
May 24, 2008 | Hoover Nextra HNWL 3136 Front Load Washer...
Miele W830
I have exactly the same problem - what was the answer ?
Mar 15, 2008 | Miele Novotronic Premier 500 Front Load...
Samsung B1245 Front Load Washer Logo
117 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
