Question about Xerox WorkCentre XD100 All-In-One Laser Printer
Copies are light color and l like to know how to get darker
A repair man came to service it because the j2 was on .he told me the drum is going bad. he got it to work and copies were dark for couple days then started to go lighters. plenty of toner. what you think .. thanks
    President:
  • 2,072 Answers
MOst likely the drum cart is the issue. There is a fine charge wire and grid on top of that cartridge that probably is going bad.
Posted on Aug 07, 2008
Mp 470 printer, how to make copies darker.
You most likely have done gradation simulation, strange that they are all light? All drums are new or in good %? have you changed out your transfer belt ITB?
Dec 04, 2013 | Canon imageRUNNER C3220 Color Copier
I have purchased a remanuf toner drum for my xerox xl 2130f copier and installed-- everything fit very well and seems to seat well/ only I still get a j2 signal upon the startup and I am lacking for...
Most likely the "remanufactured" cartridge does not have the counter reset flag in the proper position or is missing completely. Just reset the counter via the service mode by pressing these keys in sequence and as quickly as possible (within 4 seconds).
Press Clear, then exposure mode (far left key) the clear then exposure mode again. So in short form C, Far Left, C, Far Left. If done properly the display will go blank. Now key in 24 as if you wanted to make 24 copies. Now press the print button. Now enter 7 then press print again. You should now see flashing 000.
Press C a few times to exit and the drum light/J2 should now be gone.
Good Luck and Thank You for using Fixya.
WheatlandServices
Jan 31, 2011 | Xerox WorkCentre XL2130f Laser Printer
Page has a dark bar along the length of the page copied and it gets darker the more copies you do
Defective toner cartridge. Try sliding out the cartridge, turn it over and slide open the cover/gate that covers the drum. The drum should be clean all the way across. If you see a toner band or anything that would be your proof. 9 times out of 10 this is going to be a bad toner cartridge.
Oct 09, 2010 | Canon PC-430 Color Copier
I have a Xerox XD125F Workcentre. The J2 toner
1. turn off XD125f
2. Turn on
3. within 4 seconds press, clear, auto, clear, auto. LED Should go blank,
if not try again
4. use copy quantity keys to enter 24, then push start
5. Again use copy quantity keys to enter 7, then push start
6. turn off
when you restart the cartridge count will be set to zero
I have done this twice and never replaced the drum cartridge.
Jul 24, 2009 | Xerox Office Equipment & Supplies
Xerox XD100 that is showing a code J2
No. The CRUM is integral to the Drum Cartridge. The only way would be to swap CRUM from a cartridge that failed for a reason other that it reached end of life.
Jul 02, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Canon PC6re copier makes copies that are dark on the long edges
Just fyi, a Canon PC-6e is a copier that is about ten + years old of a model... The drum unit will make the copies better.... But, you most likely need to clean the optic's. Have you tried to make the copies lighter??? If I am correct, there is a small botton on the control pannel that will turn... It will make the copies light one way and darker the other way... Good Luck
Apr 20, 2009 | Canon PC170 Copier
Drum Cartridge XE Series P8 part number 13R553 Printer code J2
With "J2" flashing, press:
1. "CLEAR" button
2. "AUTO" button, then again
3. "CLEAR" button
4. "AUTO" button
Do it fairly quickly. If it's done quickly enough the display goes off. When it does:
5. enter "2" and "4" (see "24" on display)
6. Press "START/COPY"
7. Press "7"
8. Press "START/COPY"
DONE
If display doesn't go off repeat steps 1 to 4 but faster, until display is off.
Nov 07, 2008 | Office Equipment & Supplies
We have a xerox 2520, that has a J2 error code. We can't fix a service rep locally.
1. turn off XD125f
2. Turn on
if not try again
6. turn off
Sep 16, 2008 | Xerox Office Equipment & Supplies
J2 drum cartridge light no after replacing drum
J2 is the indication that the Drum Cartridge life has elapsed. The possibly exists that the Customer has installed a New Drum Cartridge. The Customer would be directed to change their Drum Cartridge by their User Guide. This action on the part of the Customer will cause the Drum Reset Switch to actuate for a moment when the Side Door is closed. This is with the provision that the Drum Reset Circuit is working properly. That momentary actuation of the Drum Reset Switch, being actuated by the New Drum, resets the Drum Counter. Should something be faulty with either the reset mechanism on the New Drum Cartridge, or the Drum Cartridge reset Switch circuit, the Counter will not reset. Note: A new Drum Cartridge will NOT reset the Drum Counter unless the machine is holding a J2 presenton the display. The first revolution of the Drum will render the Drum Cartridge used. A Used Drum Cartridge will NOT be capable of resetting a J2. Again, one revolution of a new Drum Cartridge will render it to be a used Drum . Cause:
Apr 25, 2008 | Xerox WorkCentre XD130DF Laser Printer
I need help with workcentre XD130df
J2 means the life of the drum has expired.
If replacing the drum does not fix it let me know.
J2 means the drum has met it's 18,000 page life.
Apr 04, 2008 | Xerox WorkCentre XD130DF Laser Printer
Xerox WorkCentre XD100 All-In-One Laser Printer Logo
47 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
