I need the coding for simple calculator in 8085 that can display in lcd..that calculatoar can perform +,-,*,/..operation
    President:
  • 1,623 Answers
Try going back to class and listening instead of coming on here and asking people to supply you with the correct answer for your homework/project.
Posted on Apr 08, 2011
I've got a casio fx 991plus calculator and I want to know how to use feet and inches in the calculation displays, like how is used meters and centimetres in the display
PDF]fx-570MS/991MS Additional Functions - Support - Casio
support.casio.com/pdf/004/fx570MS_991MS_E.pdf
Casiodisplay format (Disp) settings while the calculator is in the BASE ... Be sure to checkthe current calculation mode (SD, REG,. COMP ... Use [ and ] to display the expression 4 + 4. Press A ... want to perform scientific function calculations. COMP .
The Casio fx-991es, fx-570es and - Numericana
www.numericana.com/answer/casio.htm
The Casio fx-991ex succeeds the fx-991es (functionally identical to the ... Both are nonprogrammable nongraphing scientific calculators, with natural ... Side-by-side comparison of the fx-991EX and fx-991ES PLUS. ... Displays QR codes for smartphone use .... Work out a formula for many values of the input variables.
CASIO fx-991MS Calculator Tutorial: Lesson 5- Dealing with ...
Dec 03, 2015 | Casio Office Equipment & Supplies
I CANT GET MYCALCULATOR TO DO FRACTIONS CAN YOU HOPE ME
To configure the calculator to do fractions, set the Input/Output mode to MathIO.
Press [SHIFT][MODE] to open (SetUp) then select [1:MathIO].
After you set it to MathIO, pressing the fraction key will display a fraction template where you can enter numerator and denominator as you would by hand (horizontal fraction bar). Also, the calculator will display results as fractions and radicals whenever possible.
To perform arithmetic operations on fractions use the regular operation keys (x, +, -, /). The calculator will perform the operations and display the results as fractions (whenever possible).
Aug 15, 2011 | Casio fx-300ES Calculator
This is so easy but I've forgotten. I have an old manual Casio caluculator. I just want to divide a series of numbers by 4. I can't seem to figure out how to do it. Any ideas? Thanks, Julia
If your calculator has the capabilities to do constant calculations here is how you perform calculations with a constant.
  1. Enter the constant (4)
  2. Press the operation key (/) once.
  3. Press the operation key (/) a second time.
  4. Your calculator may show a k in its display (LCD)
  5. To divide a number by 4, enter the number and press =
  6. To divide another number by the constant (4) , Enter the number and press =
  7. Keep entering the dividends and pressing =
I hope it works for you.
Oct 01, 2010 | Office Equipment & Supplies
My calculator says DEG in the top right and I don't know how to remove it. Is this something that will not allow me to perform simple functions. Ten year-old children need to use this for class, so it...
The calculator has three angular modes: degrees, radians, and grads. No matter which of the three you select, the calculator will indicate which one it's in. You can get rid of the DEG, but only at the expense of getting one of the other two.
This should not affect the operation of the calculator in any way (except, of course, for the trignometric functions).
Sep 20, 2010 | Texas Instruments TI-30XA Calculator
I am getting the wrong results when performing some basic FV math problems. Doy you have any math problems that would help test my calculator?
It might be more efficient to make the calculator perform a self-test. Here is the procedure.
Verifying Proper Operation (Self-Tests)
If it appears that the calculator will not turn on or otherwise is not operating properly, use one of the following procedures.
1. With the calculator off, hold down the [ON] key and press [X] (the multiply key)..
2. Release the [ON] key, then release the [X] key. This initiates a complete test of the calculator’s electronic circuitry. If everything is working correctly, within about 25 seconds (during which the word RUNNING the display should show –8,8,8,8,8,8,8,8,8,8, and all of the status indicators (except the * battery power indicator) should turn on. If the display shows Error 9, goes blank, or otherwise does not show the proper result, the calculator requires service.
Tests of the calculator’s electronics are also performed if the [+] key or the [divide] key is held down when [ON] is released. These tests are included in the calculator to be used in verifying that it is operating properly during manufacturing and service.
If you had suspected that the calculator was not working properly but the proper display was obtained in step 2, it is likely that you made an error in operating the calculator. We suggest you reread the section in this handbook applicable to your calculation — including, if appropriate, appendix A.
If it needs repairs, contact FixThatcal.org
Here are some examples from the manual (there is overlapping in the first two screen captures)
Mar 07, 2010 | HP 12c Calculator
Has new battery and wont turn on
Hello, You can try to perform the self-test. Procedure is as follows. To perform the self test on units with two batteries:
  1. Turn the calculator off.
  2. Press and hold the c01788482.jpg and c01774569.jpg keys; keep both keys held down for the next step.
  3. Press the c01788481.jpg key so the c01788483.jpg and c01788481.jpg keys are held down simultaneously.
  4. Release the c01788481.jpg key.
  5. Release the c01788482.jpg key, followed by the c01774569.jpg key. The main test screen displays the following: '1.L 2.C 3.H'.
    • Press c01788484.jpg to perform the LCD test (all LCD segments will be turned on). Press any key to exit.
    • Press c01788485.jpg to perform the checksum test and see the copyright messages. Press any key to go from one screen to the next until the main test screen, '1.L 2.C 3.H', is displayed again.
    • Press c01788486.jpg to perform the keyboard test. Press EVERY key on the keyboard until all the keys have been pressed at least once. The screen will progressively turn off with each key press. Once all the keys have been pressed and the screen is clear, press any key to return to the test screen.
Press c01788481.jpg to exit the test system. This will also turn the calculator off. If the calculator detects an error at any point, it will display an error message. For the HP 12c financial calculators with one battery, to perform the LCD self test:
  2. Press and hold the c01788480.jpg key, and simultaneously press and hold the c01788481.jpg key.
  3. Release c01788481.jpg then c01788480.jpg .
  4. After a few moments, all elements of the screen should be displayed. Press any key to exit.
Nov 02, 2009 | HP 12c Calculator
TI 84 plus calculator, flashing dot in upper left hand corner
When you turn the calculator on, its screen is cleared, save for a small square on the top left corner. This is the cursor and it is blinking: The calculator is waiting for you to order it to perform some calculation.
Try this simple operation
[1] [+] [1] [ENTER]. The calculator will display the result one line down justified to the right.
Hope it helps.
Aug 26, 2009 | Texas Instruments TI-84 Plus Calculator
I just want to find out how to use the simple functions of my desk calculator, ie. add, and multiply in one operation and so on.
Usually you enter the first number then you press the key ( +, -, x or /) corresponding to the operation you want to perform and you press the equal sign (=).
ex: 15+3=18
Often you can perform the operations one after the other without bothering with the intermediate results. You can do so provided you respect the priority rules: parentheses,powers, multiplication/division, addition/subtaction...)
Hope it helps
Aug 18, 2009 | Sharp EL-1750PIII Calculator
Can i get source code for calculating arithmetic operations of vb
just take a look to this site:
http://www.codeproject.com/
you'll get all your answers about VB and totally .NET there by a simple search
enjoy it!
Feb 19, 2009 | Microsoft Visual Basic 6.0 (361-00686) for...
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
