Dear Sir, My name bobby from Indonesia, i have seagate expansion 500Gb Usb disk just for 3 months, but while i'm transfering some data to it, the power off accidentaly, since that time, i'm not abble to acces the disk, i have try to buy a new usb cable or else, but still cant acces it, please help me, and very thankyou for your time for reading my letter, forgive me for my english, GBU
    Scholar:
  • 96 Answers
It's not the cable that's to blame, it's the disk itself, it had probably gotten corrupted. this is a serious matter, but you can try to fix it up by
  1. running error check (go to my computer> right click disk>go to properties>click on "tools" tab>click "check now">select both options>click ok and follow instructions)
  2. formatting (in my computer, right click disk> format >start)
Remember that you could already have lost any data held on the disk because of the power outage. Also the second option will erase any data on the disk completely.
If none of these work, or if the disk doesn't show up on my computer at all, you are going to have to give it in to the shop u bought it from to try and repair it.
This is a good lesson that you should remember; never use a computer without a UPS (also called "battery" but this is a wrong term.) That will hold a few minutes electricity enough for you to shut down the computer.
Hard disks get damaged if the power is suddenly cut off without any warning; when you shut down your computer, it tells the hard disk to move the hard disk's moving parts into a safe orientation. in fact, if you listen to a disk while shutting off power from the switch, you'll hear a click sound. this is damaging.
Posted on Apr 08, 2011
Seagate expansion portable drive won't post makes clicking noise
Very likely the head is no longer aligned, and can no read the disc correctly. This is physical damage that can not be repaired. There are specialist, but at premium prices.
Oct 20, 2012 | Seagate Expansion 500GB External USB 2.0...
My mac OS X 10.4.11 won't let me drag and drop into Seagate Expansion 500GB - says it can't be modified!!! Help please.
If the drive is formatted with NTFS (the format used by recent Windows operating systems), then you won't be able to write to that file system.
What you will need to do is reformat the drive to HFS or FAT32.
If you will be moving the drive between a Windows and a Mac, then you'll have to format with FAT32. If you will only be using the drive on your Mac or other Macs, then format the drive with HFS.
NOTE: unless you copy the existing files off of the drive first, you will lose all data on the drive.
To do this, do the following:
  • Copy all existing data off of the Seagate drive to a safe location
  • Unmount the Seagate hard drive
  • go to your Machintosh HD / Applications / Utilities folder and start "Disk Utilities"
  • Select the Seagate drive from the list
  • click on the Erase tab
  • Select the Format. For HFS choose "Mac OS Extended (journaled)" for FAT32 choose "MS-DOS FAT"
  • Type a name for your volume in the Name: field
  • Click the "Erase..." button and allow the Disk Utilities program to format the drive
  • Once the drive is formatted, you will be able to save files to the disk.
Thanks for using FixYa and have a great day
Jan 15, 2011 | Seagate 500GB USB 20 5400RPM Portable 500...
Hi , I have 500GB USB ..i just been six months..
SEAGATE ('www.seagate.com') offers a one-year warranty.
Copy all your files (onto another disk, or onto DVD-writable disks),
and then exercise the warranty for SEAGATE to repair/replace it, at no cost to you.
Dec 27, 2010 | Seagate 500GB USB 20 5400RPM Portable 500...
FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive: SIR i hav connected my frnds seagate 500gb externa...
WHat you could do is test other usb ports on the system or you will have to remove the drive from the caddy and install it as a slave inside your pc and see if you can access the data,
If you can then you know its the caddy at fault
Here is another possibility that i found on another forum
"I was playing around in Device Manager, unplugging and replugging the hard drive. Finally I found that although it wasn't listed under Disk Drives or Removable Storage
, it was listed under USB controllers. It had a little x on the icon. Upon right clicking it I found that it had somehow become disabled on my computer. I'm not sure how that happened. I know I didn't do it."
or you can try this
Try this fix for missing usb ports by JohnWill
Create a file with NOTEPAD containing the following lines and save it as FIX.REG
-------------------------- Use text after this line --------------------------------
REGEDIT4
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Environment]
"DEVMGR_SHOW_NONPRESENT_DEVICES"="1"
-------------------------- Use text before this line --------------------------------
Double click on FIX.REG and say yes to the Merge Into Registry question.
Unplug ALL USB devices.
Open Device Manager.
View, Show Hidden Devices.
Uninstall all devices under USB Controllers.
Uninstall all devices under Disk Drives that you know are not present.
Uninstall all devices under Storage Volumes. Say no to any reboot prompts until you are finished. Also, if a Storage Volume doesn't uninstall, ignore it and move to the next one.
If you have a yellow ? with unknown devices, uninstall all of the entries there as well.
When this is done, reboot TWICE.
Reconnect the USB devices and see if they're recognized properly.
NOTE: If you have a USB keyboard and/or mouse, you'll have to modify the instructions and leave enough parts for those to function.
May 05, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Partition external hard-disk
You can partition your hard drive using any of the available free partition tools such as EASEUS Partition Master or Partition Logic. You can even buy tools like Partition magic to do the same job.
Please rate if Helpful.
Thanks
Apr 12, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Data Recovery from Seagate Desktop Expansion 500GB External Hard
This is a solution I have used in the past and it has worked. It's a Seagate Recover utility for end users.
https://services.seagate.com/diysoftware.aspx
If the data is absolutley critical and very valuable, you can send it to Seagate and they are very good at recovery as well. It gets a little pricey at $800, but I too have had to use that as well for mission critical data I could not afford to lose.
https://services.seagate.com/consumer_standard_services.aspx
Nov 06, 2009 | Seagate Computers & Internet
Connecting my Seagate 500GB USB drive reboots PC continuously.
update the firmware from seagate official,sir,any problem u can contact with me,thanks honglake@gmail.com
Nov 09, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate freeagent 500g usb 2.0 beeps sound
You still need assistance in cracking open the Seagate Freeagent Pro 500GB and trying data/file recovery? If yes, would appreciate a post back.
Good luck and kind regards.
Thank you for using FixYa.
Mar 17, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
