Question about GE Iti Simon Burglar Alarm Home Security System Kit
I had a power failure, wiyh power off about 6 hours. Since power ws restored, I hav a low battery alarm for about 3 days. The system is about 11 years old. It currently has a hard-wired rechargeable battery + a connection for a 9-volt battery. can I cut the wires to the current battery and replace it with a lithium 9-volt battery?
  • GE Master
  • 5,568 Answers
The charge circuit probably only supplies a tiny charge current to prevent overcharging of the main battery and I suspect the original is a NiCad and has likely lost a cell or two (shorted; it's common with them) over that fairly long period.
Replacing it with either Lithium Ion or NiMh rechargeables with a honest voltage rating (*some aren't) is a good move; neither of these are as prone to failure as NiCad is. Don't be surprised if you still have a 'low battery' alert for several days since these batteries rarely have a full charge when shipped.
*So-called '9V' block batteries are, except for rare batteries, actually 8.4 or even only 7.2 volts. I have some instruments that indicate 'Low battery' with either of these even when fully charged.
Posted on Apr 08, 2011
HOW DO I REPLACE BATTERY ON FIREX FX1218
BATTERY REPLACEMENT Always turn off power to smoke alarm before replacing battery.
Replace battery at least once a year, or immediately when the low
battery signal sounds (a beep once per minute indicates low bat-
tery). Batteries should be replaced regularly as necessary, even
when the smoke alarm is receiving AC power.
Use only the following batteries as replacements in this smoke alarm: Eveready 216, 522, 1222, Duracell MN 1604, or Ultralife U9VL-J [Alkaline batteries 9Volt] DO NOT USE RECHARGEABLE
BATTERIES.
1. Turn off power to smoke alarm at main service panel.
2. Turn smoke alarm counter-clockwise to detach from mounting plate.
3. Gently pull down smoke alarm. Be careful not to separate wire
connections.
4. Pull out power plug from back of smoke alarm.
5. From back of smoke alarm, lift tab to open battery pocket door.
6. Remove battery from pocket. Disconnect and discard bad battery from battery connector.
7. Connect a fresh, 9-volt battery to connector. The battery will fit
only one way. Be sure battery connector is securely attached to
battery terminals.
8. Place battery into battery pocket.
9. Close battery pocket door. Push down until it snaps into place.
10. Replace connector plug. Connector will "snap" into place.
Gently tug connector to be sure it is attached properly.
11. Reattach smoke alarm to mounting plate by turning smoke
alarm clockwise until it snaps into plate.
12. Turn on power and test smoke alarm using Push-to-Test button
Jan 03, 2018 | Home
Medion NoteBook :LT 9886 The "Battery
The battery is shot and needs replacing.
Jun 30, 2008 | Medion Computers & Internet
Invertomatic victron imv ups
Malfunction of input circuit: voltage delivered is too low. The batteries may
be faulty or depleted. Wait for a few hours, leave the UPS switched on
If absence of input power (utility failure, maintenance work) is expected to last longer than a few hours, switch
off the UPS to save battery power. If the UPS input power is absent for several days and the UPS remains on
under no-load conditions, the batteries can be discharged very deeply, resulting in a short battery life time
Apr 22, 2014 | Computers & Internet
Dcs 5501 trouble light
When checking troubles on DSC, *2 brings up the trouble codes and trouble light will flash after pressing *2
1=Service Required (press 1 to get sub codes)
1=Low Battery
2=Bell Circuit
3=System Trouble
4=System Tamper
5=Module Supervision
6=RF Jam Detected
7=PC5204 Low Battery
8=PC5204 AC Failure
2=Loss of AC Power
3=Telephone Line Fault
4=Failure to communicate
5=Sensor (or Zone) Fault --- Press 5 to identify zone/sensor
6=Sensor (or Zone) Tamper --- Press 6 to identify zone/sensor
7=Sensor (or Zone) Low Battery --- Press 7 to identify zone/sensor
8=Loss of Time & Date
Apr 04, 2014 | DSC Home Security
My 1000kva cummins generator shuts down during operation indicating low voltage. what is the cause
Check for floating debris in fuel tank possibly restricting fuel flow thru screen on bottom of fuel pickup;
Sep 17, 2017 | Pramac Electrical Supplies
I have the Caddx NX-6 alarm system. Problem: Alarm system will not arm when entering the 4 digit code. Symptom: I have all doors/windows/zones closed. LED displays READY. I press the code and get 3...
If the power was out for 5 hours and the control panel still shows 'low battery', it's probably time to replace the battery for the control panel. However, this shouldn't keep the alarm panel from arming up. I would first try to re-start the control panel by removing the power and battery connection for a few seconds and plugging it back in. After that, it would be a good idea to re-enroll all of your attached sensors, etc. by entering into programming mode and exiting. Press * 8 + {go code} then just press exit. The default 'go' code is 9713. After about 15 seconds, the panel will have auto-enrolled each attached device. Try arming and disarming the panel. Be careful of setting off the alarm, as your monitoring station may dispatch police, etc. in the event of alarm. This is why having a certified alarm installer do this work is a good idea, as they can put your account with the monitoring station on 'test' so alarm signals are recorded for testing purposes but are not acted upon.
Feb 11, 2011 | GE / Caddx NX 6 Fastpack with NX 1308E LED...
Burglar alarm not working after power failure
many systems require that the back up battery is good. Having said that, are you sure there is power to the unit and if so how?
I would check that first and then if that fails replace the battery. Lastly if all else fails the unit is probably damaged from surge.
Mar 08, 2010 | Home Security
How to reset house alarm after power cut
alarm may be in battery back up mode when power is lost it will automaticly start running off these batteries that are usually located in the panel. diffrent devices have diffrent ways or restoring regular mode. i would contact the maker.
Feb 27, 2010 | Lorex 4 Channel Business & Home Security...
Battery low sensor failure on Wireless Simon ADT
the sensor seems to be malifunctioning and will have to be replaced
Sep 20, 2009 | GE Security Simon 3 Wireless Home Security...
Low Battery warning on Simon 3 even when I changed it out
temperature affects batteries. if the batteries on the window sensors have been in use for some time it is probably time to change them. Alarm batteries are only expected to last 3 to 5 years with moderate use. If you have close neighbors or live in an apartment complex then false reads could be a factor.
Aug 11, 2009 | GE Security Simon 3 Wireless Home Security...
GE Iti Simon Burglar Alarm Home Security System Kit Logo
334 people viewed this question
Top GE Home Security Experts
Sean
Jim Goldsmith
Jim Goldsmith
Michael Galve
Michael Galve
Are you a GE Home Security Expert? Answer questions, earn points and help others
