Question about NetGear RangeMax Next Wireless ADSL2+ Modem Router DG834NB
Trying to install this router i successfully complete all steps in guide , pluging all cables as described but keep getting an error message saying the ethernet adapter is not connected. My computer is not wireless enabled that is why i purchased ths model.My computer system is XPhome edition with an AMD Athlon 64 Processor 3200 (2,00Ghz, 512k) 80GB SATA - 160GB SATA . Dell C521 dimension.I have had a netgear DG834G connected and in use for many years.
    New Friend:
  • 33 Answers
The ethernet cable needs to be connected from your computer to the router. It looks like a phone cable sort of. Once that is plugged in it will work. If you need assistance on what the ethernet cable looks like go here:
Posted on Jun 19, 2017
  • 110 Answers
SOURCE: Netgear DG834G router
Are you getting any internet?
Are you using Windows Vista?
Posted on Oct 19, 2007
  • 14 Answers
SOURCE: Server not found} NetGear WGR614 Wireless Router doesn't connect me to the internet.
Dear Loud Nouises,
Your router must be connected properly to the cable modem. This must be to the wan port on the router.
Next, the router must be set-up accordingly to recognize the modem's internet connections. Please ask for the IP address.. and other relevant informations from your internet provider.
Set -up your computer using the internet connections wizard on each of your respective computer.
This should work fine if all connections were correctly configured.
Posted on Dec 06, 2007
  • 101 Answers
SOURCE: Netgear DG834G Setup
Hi Tradeboy,
This link should walk you though it, step by step!
If you are using Vista, you will probley want this link, too. Click on Network icon.
In the past I have found the biggest issue with networking is firewalls, so I suggest you disable them just for testing and setting up your network.
Good Luck
Posted on Jan 11, 2008
  • 38 Answers
SOURCE: Trying to install Netgear Router DG834G on Vista and failing!!
don't bother installing the router with the cd.
There isn't any drivers your computer needs, it just installs cr*p.
You will, however have to set up your router they didn't send it to you already set up.
If you bought your router from your ISP when you took out your broadband, its probably already set up. Simply plug the router in, plug it into the phone with a microfilter in, and watch the green lights on the front. If the 'internet' or 'dsl'light lights up green, it should mean your router is already set up.
Now, you should be able to connect to the internet by plugging the yellow lead in. if you can, then your router is definately set up.
Now you just have to set your wireless up. To do this you need to search for wireless networks. If you know how to do that , then locate your one (it will probably be called netgear something) click it, and click connect. If it asks for a network key, look for a sticker on the router, and it should have your network key printed on it.
Hope this helps. I've been a little vague in places but i'm not sure of your level of understanding
Posted on Feb 28, 2008
  • 1269 Answers
SOURCE: ethernet adapter error during install
Your ethernet adapter might be disabled. Go to Control Panel > Network Connections and look for Local Area Connection. Right-click it and choose Enable. Or go to Device Manager and Enable it there. If that didn't help, try to use a different Ethernet cable.
Posted on Jun 02, 2009
HP 8250 has error 0xc18a0206
Issue: error code appears on the printer display.
Step one: Reset the printer
Press the On button to turn off the printer.
Unplug the power cord and universal serial bus (USB) cable from the back of the printer.
Wait 30 seconds.
Plug the power cord back into the printer.
Press the On button to turn the printer on.
If the error message does not display, the issue is resolved; reconnect the USB cable and resume using the printer.
If the previous steps have not cleared the message, continue to the next step.
Step two: Download and install firmware update
Go to the product support page to download the update.
Click Software & driver downloads.
Click on the appropriate operating system link.
Click on the Recommended update to fix long power-on cycle and error codes and follow the instructions to download the file.
After downloading is complete, disconnect all other USB devices from the PC. Make sure the product is powered ON and plugged into the USB port.
With the printer directly connected to the PC, click the downloaded file FirmwareEnable_Release.EXE.
Click Open/Run.
Click OK at the Update successful window. The error should have been cleared from the printer display.
If you get a message saying a device was not detected (see Figure 1), make sure the printer is powered ON and the USB cable is connected to both the printer and PC and try step five again.
Nov 12, 2013 | HP Photosmart 8250 InkJet Printer
Error 322
When you try to set up the router using the set up Disc, sometimes you will get this error 322. This error says that there is hardwired connection between the router and the computer. Even if you connect the cable between the router and the computer , you will get this error message.
You can try to set up the router manually. It is easy.
Click Here for step by step solution
Nov 01, 2009 | Linksys Wireless-G WRT54G Router
Cartridge Error, Error 50C
Hi there Error 50c
Dell gets this lots so have a try.
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Mar 02, 2009 | Dell A940 All-In-One InkJet Printer
Installed Linksys G router successfully on my own computer. Now I'm trying to connect a second computer for wireless internet and I'm getting an error message saying: The wizard cannot create a wireless...
1 make sure the wireless adapter is on.. (laptops have on off buttons for wireless)
2 make sure the drivers are installed for card in laptop
if not reinstall them..
check in device manager look for ! or ? in there if you see unknown device or cannot start messages reinstalled that device..
Feb 18, 2009 | Linksys Wireless-G Broadband Router
Tech support on wireless router install ?
Hi st45,
Perhaps what you might wanna do first is to check if the wireless device (assuming you're using a wirless adpator of some sort) on the computer below is properly connected (sometimes this causes intemitten or no conenctions at all).
If that is ok and no problem with it, the next step is to use the software (range lan software) to identify the router. It should say something like "conencted to the router but the intenet cannot be found" or "you are now connected to the router and the internet". It is important that once you have the wireless adaptor below plugged into the computer below, you should be able to 'see" the wireless router that you have installed in your network.
Also, a few steps to ensure connectivity to the network (or in this case, keep alive a conenction) is to do a constant ping. Open your command prompt window (located in start>Accessories> Command Prompt), and type in Ping -t
This would send out constant packets to that website, while being able to monitor ant breaks in your netowrk connection if any. If you do occur any error message, please do let me know of em and i shall help you rectify the situation, based on the error messages.
Hope this helps. Please do remember to leave a rating if this solution has helped you in one way or another. Thank you.
- Techomancer
Jun 03, 2008 | Computers & Internet
Installation problem
Initially, I would suggest that you connect either your Dell desktop and IBM ThinkPad laptop using a wired LAN cable to any of the Ethernet Port 1~4 of the router and verify that your PC is set to Auto obtain an IP address. Thereafter pls go through the setup procedures again.
If this is how you have connected your router and PCs, pls post back that we can figurre something else.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 05, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin wireless router
Yes, there are many ways to set up the modem - the instruction are for the "most" successful installation - To make it the easiest on you, do what the cd that came with it says.
Apr 02, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin N Wireless router
return it it sucks!!!!! You have to continually call belkin to reset
Jan 04, 2008 | Computers & Internet
NetGear RangeMax Next Wireless ADSL2+ Modem Router DG834NB Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
