Question about Dewalt Saws
I have a Dewalt flipover combination saw D27107 (305 blade) Great machine has been working fine until this week. Whilst on a job decided to play up, everytime i switch on it blew the fuses and tripped out
SOURCE: Hotpoint CTD00 trips the power
This happened to me.
Your condenser unit on the front bottom left corner may be clogged up and causing water to back up around the fan and heating element behind the rear panel.
Take condenser unit out and give it a good clean removing as much fluff as possible.
If the heating element senses damp on it, then it will trip the electric.
The back panel which is at 45 degree angle on back. I took this off and sure enough there was water in there.
Wipe away all water and use an ever so slightly damp cloth to remove as much dust stuck to the metal as possible.
I used a hair dryer for about ten minutes fanning over the heating element and circular fan. Don't rush this. Take your time to make sure all signs of damp have been removed from heating element before putting the back panel back on.
After carrying out the above my machine worked fine and no longered trip electric.
It is a pain, but to prevent this problem happening I suggest cleaning condenser unit about once a week if you have alot of washing. Empty water panel after every two loads, maximum.
Good luck
Jon
Posted on Dec 05, 2007
  • 8 Answers
SOURCE: Dewalt Table Saw
I don't know about Cleveland, but a while ago I replaced the bearing on my Sears Craftsman saw, and it wasn't a hard fix. I would expect any competent repair shop could do the repair easily. If you can get the arbor off and take it to the shop, that would be ideal. It only takes loosening a few bolts to get it off. I first removed the cast iron top from the sheet metal base so I could turn it over, but it can be done from the bottom, too. Just be prepared to eat some sawdust. The most specialized thing the shop would need is a bearing press to get the bearing in and out of its seat, and many shops would have these; they aren't very expensive. Maybe a good machine shop which does small jobs could do it for a small fee. A good place to find these is at your local auto parts store, such as NAPA or O'Riellys (here in MIssouri, anyway, but you get the idea). Your auto repair shop probably knows one or two they use for 'turning' brake drums, etc. BTY, I didn't have a bearing press and I did the job with carefully tapping the bearing back on with a sleeve made from a piece of scrap pipe. Tauton Press makes a great DVD on tuning up your saw after this fix, as you want to make sure
it is square with the table in two dimensions - parallel to the miter saw slots and perpendicular to the top. Good luck.
dcm
Posted on Oct 01, 2008
stug_57u
  • 99 Answers
SOURCE: dewalt 708 sliding compound mitre saw
Probably a worn bearing. The only other thing that I have seen cause this is a bent spindle. This would usually occour if the machine has had an impact or if the blade has been suddenly jammed against a nail or something in the work that has caused it to jam and/or jump up.
A good indicator for bearing wear is to see how much play is in the blade in an up/down and side to side movement (unplug saw, safety first).
To check spindle, remove blade and run machine without the flanges etc on. Rest a scredriver gently on the shaft as it spins and see if you notice any (uniform) vibration.
Posted on Nov 01, 2008
SOURCE: LG WASHING MACHINE WM14225FD
My machine would not switch on this morning, no beeps or lights, I traced it to a small fuse on the main circuit board. you get to the board by disconecting from the mains, removing 2 crosshead screws at the back of the machine and lifting the top of the machine off ( once screws out, slide top of machine back about 1cm and then it just lifts off. You can now see the main circuit board, behind the control panel on front of machine. the fuse is hard to see and is solderd to the board on the lower left side, I solderd onto both ends of the fuseand replaced with a 10 amp HRC fuse, I still need to find the correct fuse rating, this worked for my machine.
However, and its a big however, If the 13amp fuse in youre plug blew and the trip on youre consumer unit, then I would imagine something big (pulling a large current) has gone down in youre machine to cause all these to blow, anyway hope this helps, Robin.
Posted on Dec 05, 2008
rowdy45176
  • 2176 Answers
SOURCE: dewalt 10 inch portable table saw blade height adjustment very st
What I would do is clean area with air (wear safety glasses) then I use a spray type of dry lubricant on the threads and also the plates that the motor slides on. You can also use WD-40 in a pinch. Hope this helps
Posted on Dec 10, 2008
Where do I find the release mechanism to raise the blade height
UNPLUG THE SAW
Take some time to determine every function and how each one works.
PRACTICE EACH FUNCTION WITH THE SAW UNPLUGGED UNTIL YOU ARE CONFIDENT THAT YOU KNOW WHAT YOU ARE DOING.
Then, plug the saw in and
PRACTICE,
slowly and carefully on easily handled material.
DANGER - THESE MACHINES CAN HURT YOU!
If you don't know exactly how everything works
DON'T EVEN PLUG IT IN.
Aug 26, 2015 | Dewalt Saws
Mastercraft 2 in 1 flip over saw only works on one side
You have a safety lock as the table turns to table saw with an open blade.if you don't hear the click or one of the wires on the locking mechanism have come loose it will not function. Used to have one but I wore the motor out - best portable saw I have owned and I own a lot of high end saws.if anyone has a flip saw for sale let me know - pipeline@nucleus.com.
May 31, 2013 | Saws
My Dewalt 788 Scroll Saw table has a problem: It's fine when level, but when inclining the table left, it contacts the blade. That's when I noticed there's vertical play in the table; the
First: if there is looseness in the table, it is dangerous. So I would check all the parts for wear. If, for instance, a knob worked loose, the bolt could have worn (via vibrating) the bracket, resulting in you being unable to tighten it correctly. Occasionally I take mine all apart and check it all over for just that reason. I also check all the knobs just before use to make sure they are all tight. Here is a web page talking about Dewalt scroll saw problems and solutions http://www.scrollsaws.com/SawReviews/DewltTuneUp.htm
Jan 03, 2018 | Dewalt DW788 Heavy Duty 20" Variable Speed...
Blade not releasing
Getting a broken blade our of the sawzall chuck can be difficult and require some ingenuity and patience...
Sometimes there be enough blade left so that you can grab it with a needle nose pliers... othertimes it is flush and that makes it more difficult... holding the chuck in the release position and rapping the saw against a table or with a hammer can jiggle the piece out....of course you have the chuck pointed down while you do that...
Also moving the piece around a bit with a stiff wire and also soaking the chuck and blade with WD-40 helps also....
Usually it will take a combination of these things and some persistance to get the job done...
heatman101
Jul 05, 2010 | Dewalt DC385B 18v. Cordless Bare...
Can not replace blade on Dewalt 303 6.5amp
heatman101
May 23, 2010 | Dewalt DW303 Heavy Duty 65 Amp...
I reassembled the blade guard after cleaning and found that the blade guard prevents the saw from lowering. Is it possible to get the spring in backwards? If I move the guard up an inch, everything works...
Had the same problem with the dewalt, either the lifter arm is bent just enough or some thing is worn just enough, we put a zip tie on the part where the saw comes up to rest and it works fine.
Feb 05, 2010 | Hitachi C10FCE2 10" Compound Miter Saw
Spindle and spindle hole in blade different shapes
there is a blade clamp missing like you get on grinders that transfers drive from the motor to the blade,otherwise they are quite a nice saw
Jan 07, 2010 | Dewalt DC390K 18v Cordless Circular Saw...
Blade won't stay in
That the reason we been using clamping collar for all these years.
Sep 09, 2009 | Dewalt DC330K XRP 18v cordless Jig Saw Kit...
Dewalt 708 sliding compound mitre saw
Oct 07, 2008 | Saws
Dewalt Table Saw
dcm
Sep 12, 2008 | Dewalt Saws
Saws Logo
111 people viewed this question
Top Dewalt Saws Experts
JOHN LAPIER
ken skalski
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
