Question about Alpine CDA-9813 CD Player
Hey, everytime i try to play a cd it says error...is my cd player broken or is it something i can do to fix the problem?
  • 2,098 Answers
Hi jmatt313,
If you have necessary tools and test instruments, know safety precaution in basic troubleshooting try the steps below to solve your problem.
Assuming that the disc is good.
1.Clean the lens. - Sometimes because of dust and any fine foreign objects build up at the top of the optical lens it can't read any disc. Try clean the lens by soft cotton buds. Be careful while doing this.
2.Check the ribbon - Check the ribbon connected to the lens from the main board for scratch, damage. Once it has an open line then of course the lens can't read the disc. Also try to erase the contact by pencil eraser. If you've done the steps above and the symptoms still there then the next step requires you a little knowledge in soldering technique and reading the ohmmeter.
3.Check the motor - Check the motor that spin the disc with an ohmmeter. You can test it using the ohmmeter (x1) even it is connected on the lens assembly.Good motor - reading should be fairly high and it will spin. Bad motor- reading will drop to low resistance and will not spin.
Hint : 50% of my repaired unit the above parts are commonly caused of the problem.
If you confirmed that you have a defective motor then replace it with a new one. Before replacing the new motor you have to check the clearance of the disc holder with the old one. The clearance should be the same as the old because if not the lens will not read the disc if it is too far or too close.
If the above steps didn't cure the problem, high chance that your optical lens was faulty.
If you can't do the job yourself, I would advice you to look for a professional to troubleshoot the symptom.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Apr 08, 2011
2004 lexus RX330. CD player has 6 cd's in it. Has one cd in it. Will not play or eject. Error 4
Something inside the cd player has broken and can most likely be sent off for repair but I don't know how much that would cost, but a new one can range anywhere from $500-$1,000.
Aug 10, 2012 | 2004 Lexus RX 330
I get a CD Error 1 message when I put in a CD to play. They message doesn't appear everytime. Sometimes it plays parts of the CD, but when it does this it skips alot. What does the CD Error 1 message...
The cleaning kit is a fix if you have 'dust' on the lens, but will not fix the root problem you are experiencing. It is a mechanical wear problem of the cd-rom player. If you can replace the cd-mechanism, that will solve your problem. But, most people are sticker shocked by the price of an oem cd-player.
There are quite a few aftermarket DVD players now available, and aftermarket CD-players which have new warranties and have features and power that surpass the original decks.
If you want to stick to your original design, though, you can try a salvage yard to see if they have one that works better. But, one is taking a monetary chance by buying a used radio that might do the same thing as your own.
Jul 29, 2010 | Nissan Sentra Cars & Trucks
E20 error code
E20  error is a problem with the focus on the CD reader.
If the error only occurs on one CD then it's most likely a problem with a smudge or scratch on that CD and not the CD player  lens .
Try cleaning the CD thoroughly with iso-propyl alcohol
Nov 06, 2009 | Car Audio & Video
Masterlink "Disc Read Error"
try to reinstall the O.S. /firmware.
the firmware is avail on the alesis site
dave
Sep 11, 2008 | Alesis MasterLink ML-9600
My Zen is frozen on a song on play and everytime i try to reset it it just goes back to the same screen and still does nothing... What do i do to fix it? or can i fix it at all?
Hey just figured it out if you ever see this. There is a very tiny "Reset" button in the bottom Right hand Corner.It's too small for a pen, so try a needle or something of the sort. Don't hold it down either. . . it will only need one push.
Aug 12, 2008 | Audio Players & Recorders
Delstar ds 801 1gb
hey dude!! try to format it with ur computer ,,,,,,,and take NOTE; make sure u dont have a virus to ur computer!!!! tnx me if ive helped u out!! ^_^
Jan 18, 2008 | Delstar DS-802 Digital Media Player
Dvd won't load
open it and check for a broken part in one of the gears that operate the drive. if the unit is under warranty, take it back rather than try to fix it.
either something is in the mechanical portion of the unit, or it is badly worn.
i would suspect a broken part from the noise issue/ clicking sounds.
the read head runs on a track and could be jammed up, unable to run to access the directory of the disc. inspect what you can get to, and hopefully that will be a simple fix.
good luck
mark
Jan 05, 2008 | Symphonic SD200E
Error
make sure it is set to cd/wma/mp3 mode
press menu then go to set up then I think general and then look for play mode or cd mode. something like that.\
ps if it was over heating the unit actual tells you that it is over heated and then powers down.
Oct 20, 2007 | Alpine CDA-9855 CD Player
Kenwood KDC-2025 won't play CDs
source http://www.kenwood.nl/support/veelgestelde_vragen/ Changer Error Codes ? E-00: Poor Cable connection. ? E-01: Magazine not properly set in changer. ? E-02: No Disc in magazine. ? E-03: CD does not have selected track number. ? E-04: Disc is dirty, upside down or unreadable. ^^^^ ? E-10: No data is recorded on the MD. The player plays the next disc automatically. ? E-99: Changer malfunction, disc may be caught in machine or changer requires service. I suggest the lens needs a clean, or someone has dropped it and broken the delicate lens mech. Luck
Apr 30, 2007 | Kenwood KDC-2025 CD Player
Alpine CDA-9813 CD Player Logo
122 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
