I have a pakon scanner f 235 which read error code 235 ,what can i do to resolve that problem.
  • 27,725 Answers
The drivers for the scanner might have been corrupted
you might have to uninstall the printer/scanner restart your computer then reinstall the printer/scanner and its drivers
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options plus you can troubleshoot hope this helps
Posted on Apr 08, 2011
Error Code : 0x5a
The detail code 5a in Fujitsu fi-5900 scanner is displayed due to frequent paper jam error. To resolve this issue, you need to clean the two lenses of JAM1 sensor and check it's performance.
Also, to resolve paper jam error, you need to check the condition of pick,separator,brake rollers, feed and pinch rollers. Replace the rollers if required.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Aug 01, 2014 | Fujitsu fi-5900C Pass-Through Scanner
Check engine
Your Rodeo's onboard computer has detected an error in one or more of the many systems on modern vehicles. Along with the Check Engine light on your dash panel, the computer has recorded a Diagnostic Trouble Code (DTC) that can be read (and cleared) by a code scanner. Large auto parts stores usually have code scanners that they will allow you to use - normally at no charge - at their location (a good store counterman will even connect the scanner, read and interpret the code, and advise you of the problem and possible solution (they are trying to sell you parts, right?). Some error codes are advisory and inconsequential, while others indicate serious problems that should be corrected immediately. Go have the code read and interpreted, then decide if you want to have it resolved soon, immediately, or sometime before your next vehicle inspection. Good luck.
Oct 01, 2013 | 2000 Isuzu Rodeo
Hello, I have a Canon MP810 printer and the screen shows there is an error with that number: 5020. It says that I have to unlock the locker of the scanner and then restart. I have done it many times...
I have just read it on the other forum..try this one
Error Code 5020:
Scanner lock switch locked. [5020] Release the scanner lock switch and turn the power
off and back on.
Turn the machine off, unlock the scanner lock
switch, then turn the machine on again.
Hope it helps.
Sep 09, 2011 | Canon PIXMA MP810 All-In-One InkJet...
Unable to resolve "scanner error
how can i resolve the error code 22 on my hp laserjet m1212nf MFP?
Jul 23, 2011 | HP LaserJet M1120 MFP All-In-One Printer
> My computer does not detect my scanner >
Search on-line see if you can get an-updated driver for it. Some windows updates remove old drivers.
Apr 09, 2017 | Canon CanoScan N640P ex Flatbed Scanner
SHARP-235, F5-02 CALL FOR SERVICE CODE
Sep 2010 ... What does error code L6-10 mean on a Sharp AR-235 ... my machine sharp a 235 say call for service u9-99 what dos it mean and how can i
Sep 04, 2010 | Sharp AR-235 Copier
We are looking for USB Board of Pakon film scanner F-235
PLEASE, WHAT CAN I DO IF PAKON FILM SCANNER FP335 REFUSED TO SCAN WHEN THE DUST AND SCRACHED REMOVAL IS ON. BUT IF WE OFF IT THE SCANNER WILL SCAN BUT WITH STAINS
Jun 25, 2009 | Office Equipment & Supplies
Fi-4120c2 error Code
The scanner does self-diagnostic when receiving Read Command (to start scanning) and displays the result if any error or alarm is detected.
Error code-E3 in Fi-4120c2 scanner means "Light intensity check" . When this error is displayed on the scanner panel, TWAIN displays the following error-
" Irregular status is detected in scanner. If this status recurs after power cycling, please give following Sense key and ASC code to your service provider.
If ASC code is the following, please confirm following status before power cycling’
- When ASC=0x580, confirm if the shipping lock (if any) is set at “Release” position.
- When ASC=0x680, clean the sheet guide (white part) in ADF.
(Error Code DS42001)
E3 explains Optical alarm (back). This alarm occurs if the gain adjustment of the CCD amplifier does not succeed at a READ command for the first document, or during scanning.
Probable causes:
- The lamp, the optical system or white sheet guide is dirty.
- Defective lamp or CCD.
- Connector disconnected
To check and resolve the issue, lease follow the steps provided below:
1. Is sheet guide (white part) in the reading position dirty?
#Open the ADF and clean the sheet guide (white part) and the glass.
2. Is the lamp ON?
3. Are the cables damaged?
4. Are the connectors connected correctly?
#Disconnect SCSI cable and turn the scanner ON. Open the ADF and press Cover open sensor to see if the lamp lights. If not, the error is caused by the defective lamp.
5. Is the optical unit dirty?
6. Are the cables damaged?
7. Are the connectors connected correctly?
# Check and Clean (ADF back):
# Check if inside of the grass for Upper unit ASSY is dirty. Clean inside of the glass of the dust cover.
9. If the issue still persists, then you may have to replace Optical unit.
Hope the above information will be helpful.
Please revert if you have further queries.
Thanks & regards,
TechSatya
Oct 08, 2008 | Fujitsu fi-4120C Path-Through Scanner
Computers & Internet Logo
185 people viewed this question
David Payne
David Payne
