Question about Fisher and Paykel RF201ADUX Bottom Freezer French Door Refrigerator
Fisher and Paykel fridge/freezer RF540ADUX shows fault code F20 what is this fault?
4 Suggested Answers
SOURCE: Fisher Paykel Fridge Freezer
I have a Fisher and Paykel E442B upside down, which is a very similar model, and I just fixed the same problem (temperature was around -4C even though I set the fridge temperature as warm as possible).
The cause of my problem was excessive ice build up on the side of the evaporator coil (which is in the back of the freezer compartment behind the rear plastic panel). I had the same problem around a year or so ago, so I expect it to be a regular occurence. To defrost the coil, I removed all the drawers in the freezer, and the plastic insert by pulling out the bottom of the panel out and rotating it upwards until it released at the top. There are a couple of snap-in tabs holding the panel in, so with a bit of pulling they released. The tabs are either side of the slot at the bottom of the panel.
I then supported the panel horizontally on the top shelf so that I didn't have to disconnect the thermostat wire and the circulating fan wire.
52de81a.jpg With a small fan heater set on low, aimed roughly at the ice buildup on the left hand side of the evaporator coil, I defrosted the ice built up. This took around 2 hours or so. Then put it all back together and it worked fine.
I'm not sure why the ice build up on the side caused the problem, but presumably it interferes with the proper flow of cold air to the fridge compartment.
If you don't seem to have ice build up like I did, then it could be a thermostat problem, or a fan problem (a symptom of which would be fridge being colder at the bottom than at the top).
Posted on Oct 04, 2008
SOURCE: Fisher and Paykel model RF610
The F24 error show that the sensor in the ice maker is out of normal ranges. The usual fix is to replace the sensor in the ice maker.  Also worth checking it to see is the water to the ice maker has frozen up in the value (switch the fridge off for a day). If the error still exists after that you will need to replace the ice maker sensor. You have a 2 year warranty on these parts so the fix should be free.
Posted on Mar 24, 2009
SOURCE: Fisher and Paykel N500B fridge freezer. Freezer not freezing
I had a similar problem on the same model. Ice creams were soft & frozen food not ice cold. I opened the freezer. Removed the food & noticed the evaporator fan at the back was not turning. This is the likely cause of poor cooling in the freezer. I got it running by turning the fan with a screwdriver but replaced the fan soon after!!!
Posted on Jan 09, 2010
What does fisher paykel fault code f0 mean?
Faulty freezer temperature sensor - this would be for an older model fridge
Feb 23, 2016 | Fisher and Paykel Active Smart E522B...
I recently scored a bargain Fisher Paykel stand-in fridge/freezer because my original fridge developed a fault. sadly the stand-in Fisher Paykel N405T has an issue of its own, the freezer doesn't really...
Yes ur correct. the fan can be accessed by removing the back panel wall from ur freezer dept. sometimes u will have to remove the bottom panel first a couple screws are all it takes
Mar 31, 2015 | Fisher Refrigerators
Defrost Cycle on Fisher and paykel RF610
Malcolm, if you are indeed getting an F20 fault, this is a problem with the flapper heater. The flapper heater current is low.
First, Check the JST in-line connections for the flapper heater.
Second, Check the resistance of the heater. If open circuit, replace the heater.
Apr 20, 2014 | Refrigerators
Fisher paykel French door fridge shows F20 error everylme the door is opened - it beeps
F20 does not stand for 20 degrees Fahrenheit you pleb. It is a fault code. Your fridge probably beeps 20 time when you open the door and then stops. To fix is simple and takes 5 mins. Remove the top left hand hinge cover and you will find a broken wire. Just switch off the fridge and then connect the wires together with a auto12v type connecter or solder it and use shrink tube. Switch the fridge back on and hay presto, you can fill your fridge to the max 3 times over with the money you just saved. It will happen again as the wiring loom they fit is well and not flexible. Use silicone insulated wire from J-car or similar and replace from the plug and reconnect inside the door where the wires don\'t bend. Hope this helps you.
Feb 15, 2013 | Refrigerators
Fisher & paykel active smart fridge not keeping cold
Do you see any ice buildup on the back wall of the freezer or behind it?
Nov 28, 2012 | Fisher and Paykel Active Smart E522B...
CONTROL PANEL SHOWS F20 AND BEEPS WHEN OPENED PLEASE TELL ME HOW TO FIX THIS THANKS
F20 can be fixed very easy. Get something high to stand on. and see the top of the fridge. you will see the top panel and 2 pieces of plastic covers on the front corners. take of the left on and you will see broken cables. attache the cables back together and please at least use electric tapes to make it safe or soldering iron even rubber melting tubes.
Apr 15, 2011 | Fisher and Paykel RF201ADUX Bottom Freezer...
Fridge beeping
the beeping is an alarm certain lights on the display will be flashing when it is beeping record which lights are flashing this idicates a fault code then post your results and i will tell you what the fault code is and what the problem is likely to be :)
Jun 07, 2010 | Fisher and Paykel Active Smart® E522BR...
Fault Code F24
fisher paykel fridge model e522b fridge section is freezing up
Mar 31, 2010 | Fisher and Paykel Active Smart E522B...
I need to know how to change the water filter on my Fisher & Payk
This should be pretty easy to do. Have you checked your users manual?
If you don't have it handy, look at this link:
http://www.fisherpaykel.ie/admin/pdfs/pdf_usecares/819447_NZ-AU-ROW-UK_IceWater_UG.pdf
Look on pages 28 and 29 for instructions on how to change the filter
Jan 23, 2009 | Fisher and Paykel RF201ADUX Bottom Freezer...
Fisher and Paykel RF201ADUX Bottom Freezer French Door Refrigerator Logo
312 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
