Question about Garden
I have a Honda GX 670 engine. The engine starts and runs well for about 1-2 minutes. Then it begins to pop back and backfire the governor starts surging intermitently at first them after a short rtime, surges continuously. Any suggestions.
  • 11 Answers
SOURCE: Coleman generator OHV3000
The carburetor is probably clogged up. Mix a bottle of carburetor cleaner with the gas to see if that would help. Also check/replace the fuel filter.
Posted on Sep 10, 2008
ccrozier_agr
  • 36 Answers
SOURCE: 2 1/2 Briggs......doesn't run smoothly....surges at all speeds.
Hi, Check that you have the correct spark plug fitted or fit a new one as it sounds like your plug is getting hot then shorting out.
Sometimes the magnito can do this as well. but I would start with the plug.
Posted on Nov 29, 2008
  • 12 Answers
SOURCE: rough idle / engine surges until power is applied
Sounds like a possible vaccume hose leak?
Posted on Feb 07, 2009
VonZeppelen
  • 60 Answers
SOURCE: (1) How do I turn off the computer fan from surging?
As far as the fan issue goes, especially if it's a laptop, blow out the fan exhaust area. Use compressed air to blow out the ventilation area in the opposite direction that air flows through it normally. You'll be amazed how much dust comes out. You can try one of those crappy over-priced ridiculously low pressure canned air deals but to really get it clean, find someone with an air compressor. A mechanic friend or someone in construction that uses an air nailer maybe? If it's a desktop, try blowing out the processor heat sink preferably with the fan removed. Be careful, start at lower pressure and slowly work your way up. Also, if you take the fan off of the heat sink, be careful not to knock the heat sink off of the processor or you will need to clean both surfaces (heat sink and processor), reapply a thin layer of heat sink grease, and reinstall the heat sink and fan assembly. I'll leave the second half of you question open incase both issues are one-in-the-same.
Posted on Feb 21, 2009
mowerman1857
  • 389 Answers
SOURCE: Honda Harmony II HHR216 Governor Surge
You have dirt and/or moisture in your carburetor float bowl. Remove the bowl, clean it out, remove the main jet and clean it out and you should be good to go
Posted on Sep 14, 2009
My 22hp Kohler engine back fires through carb won't start, need to know how to adjust the governor.
that isn't a problem with the governor, that is pre-ignition. The spark is firing too early. Normally because the engine needs timing, or because of overheating.
It seems to be a known problem, so have a read.
22 hp kohler engine backfire through carb Google Search
Apr 01, 2018 | Garden
How to set the timing on a honda gx 670 motor with no timing marks
Hi, if it's a newer style bike, it could be like a newer car. Not possible to change the timing.
Dec 21, 2016 | V-Twin Horizontal OHV Engine with Electric...
Gx 670 twin getting spark &gas wont start
Check the flywheel keyway, they will shear and cause the problem you are encountering.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/darryl_24e8d8d43e609e3c
Nov 22, 2013 | V-Twin Horizontal OHV Engine with Electric...
No fuel out of fuel pump on a gx 670
what kind of fuel pump, what kind of fuel tank, is there a filter b4 or after the pump, is there even a fuel filter, is the tank empty? all questions you should ask yourself because any one of them can cause this problem.
Sep 14, 2013 | V-Twin Horizontal OHV Engine with Electric...
Honda gx 670 chokes and sputters in thick grass or when goose throttle
It sounds to me like the carberator is a little dirty, drain the bowl and clean the main jet. Also while you are there check all the jets and make sure they are open not clogged.
Sep 09, 2013 | V-Twin Horizontal OHV Engine with Electric...
Gx 610 back fires
Is it backfiring. Thru the exhaust or the intake or the carbs
Mar 17, 2013 | V-Twin Horizontal OHV Engine with Electric...
I have a gx610 that runs nicely for about 3 minutes to 5 minutes then it stops FAST. Like very sudden. It wont start or crank again until a few minutes pass then it cranks, and a minute later or so it...
Check for plugged fuel tank vent. Vacuum builds up then fuel stops. Also check if it has a low oil presssure switch that might cut it off (check the oil level). This engine has many variations so finding a specific problem is not easy.
Apr 25, 2011 | V-Twin Horizontal OHV Engine with Electric...
Honda GX 160 quits running at variable times.
a coil wire may be shorting so look for damage on them!
you can sleeve them or a quality electrical tape will be ok for temp measure ok
Cheers Rob.
Jul 28, 2009 | Garden
Powermate 6250 loaps.
I've never been a big fan of the 180 OH family of engines in these things, but here goes.
1 - If the engine will stay running while it surges, close the choke a little at a time and see if it settles down. If it does, there is something amiss in the carb. The carbs on these engines are very picky about tiny bits of dirt. The good news is that they are fairly simple to take apart and clean, the bad news is that lots of the parts are plastic and break easily. At least they aren't too expensive.
2 - I've seen 2 ways to adjust the governed speed on these engines; a spring that connects to the governor arm at one end and a tab bent up from the sheet metal that mounts on top of the engine at the other - bend the tab so the spring is tighter to speed the engine up, and (b) a jam nut and screw mechanism that presses against a lever that pulls on a spring that connects to the governor arm - screw the screw in tighter to raise the engine speed.
Note that in either case the mechanism adjusts the tension in a spring that pulls against the governor arm, this is helpful in finding out where to make the adjustment.
Here in the US we want our 2 pole generators like this to run at 3750 rpm at no load so that we get very close to 3600 rpm at load. If you're using a DMM to measure the output of the generator in Hz, you want 61.5 at no load.
If nothing you can do with the choke makes the surge go away, you might have a misadjusted governor. The Tecumseh service manual has a great procedure for making this adjustment, essentially what you do is loosen the retaining nut on the governor arm, twist the governor shaft to its minimum speed position, then hold the throttle assembly at the idle stop and tighten the governor arm jam nut. Always keep a finger near the kill switch when running the engine the first time after this procedure, it's easy to mess up and have a runaway engine.
Please rank me if this was helpful,
Carl
Nov 12, 2008 | Coleman Powermate Premium Plus 6250W...
Garden Logo
487 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
