Question about Kenmore 400 6942 Dryer
How do you get an object out of the lint space?
  • 413 Answers
Probably will have to take the whole front panel off the dryer. I have gained enough access at time if I just take the exhause hose off the back of the dryer and shine a flash light up the 4" dryer vent. unplug the unit before inspecting
Posted on Apr 08, 2011
If an object able to be out from our sun gravity, goes under the milky galaxy gravity if the object can be out of the milky gravity goes into space gravity and then what ?
SPACE HAS NO GRAVITY.
the voyager 2 satellite the united states launched
40 years ago, just left our galaxy last year and is traveling in stellar space.
the scientists did send a command to the voyager
to change thrusters for positioning if needed. they were surprised the
the
command worked after all of these years
Jan 02, 2018 | Sun Computers & Internet
My lint collector wont collect any lint
Step 1:
1- look if the fan are blowing
Step 2:
look if there's lint traffic jam (use a vaccum)
Feb 08, 2013 | Fisher and Paykel DEGX2 Dryer
How does a sattelite fall if there is no gravity in space
Gravity is a force that causes a mass/object to be attracted to another mass/object similar to magnetism. Gravity is not an object itself located in any particular place like earth or space.
The satellites stay in orbit around the earth because the force propelling the satellites forward away from the earth is balanced by the gravity pulling them back to earth.
The satellites move too slow and they fall back to earth. If they move too fast, they fly out further into space and out of orbit.
I hope this answers your question.
Sep 26, 2011 | Computers & Internet
No lint in the lint filter
Check air flow out of unit and ensure you do have some foreign object stuck in the blower wheel. UNPLUG unit, and clear out exhaust tube from dryer. Have a professional clean house vent if you cannot see where the vent exits the house. It is common on Whirlpool, top of cabinet vent opening to have objects fall into the lint screen opening and restrict airflow.
Mar 28, 2010 | Whirlpool LER5636P Electric Dryer
An object fell into the lint screen compartment while cleaning out the lint. How do I access the bottom of the compartment to remove the object
UNPLUG THE DRYER FROM THE POWER SOURCE,
GO TO THE BACK OF THE DRYER
REMOVE THE AIR DUCT FROM THE BACK
USING A 1/4 IN SCREW DRIVER REMOVE THE ITHINK IS 10 OR LESS SCREWS FROM THE BACK PANEL, THE PANEL U ARE REMOVING IS THE LOWER PANEL OF THE DRYER
ONCE U REMOVE THE PANEL, YOU WILL SEE THE PORT WHERE THE AIR COMES OUT OF THE DRYER, THERE IS A PANEL THERE, TAKE THE SCREWS OFF AN U WILL BE INSIDE THE AIR SHOOT, CLEAN IT REMOVE THE OBJECT AN PUT IT BACK TOGETER IS THE SAME WAY
GOOD LUCK I HOPE I WAS ABLE TO HELP YOU!
Feb 02, 2010 | Kenmore Dryers
Completed setup, can't see anything through eyepiece.
I answered your question already-- TURN THE SCOPE around you have it mounted backwards! The eyepiece end is pointed UP. Like the picture above in your question.
Jan 22, 2010 | Bushnell Deep Space 78-9003 (525 x 76mm)...
Can't see anything through eyepiece.
The FOCUSER end should be pointed UP the mirror end is toward the ground. Turn the scope around and put the eyepiece with the largest number written on it into the telescope. DO NOT use the 2x barlow if you have one.
Go outside during the day time and practice focusing on a distant object.
Space bar does not work
Hello, Thomas.
I'd suggest flipping your notebook on its side and then over, lift/pull the space bar slightly with a flat screwdriver or other thin, flat object. First shake, then spray compressed air in the area.
Hopefully, something is lodged (like a paper clip or other small object) and will be removed.
If not, the space bar cannot be replaced, unlike other keys. So, you would need to replace your keyboard.
Hope this helps.
Hope this helps.
Dec 22, 2009 | KDS Valiant 6480iPTD Notebook
Combination washer dryer full laundry center does not heat to dry clothes
1) check the lint trap, and reach way into the dryer to remove all lint.2) Look at the dryer motor, and make sure that it spins freely (toys and small objects fall into the lint trap and drop into fan. While there make sure you remove all lint
Aug 29, 2009 | Frigidaire Dryers
Kenmore 400 6942 Dryer Logo
44 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
