Question about Estate ETW4400VQ Top Load Washer
It will not turn on. I checked the breaker and even switched outlets and checked to make sure other things worked in that outlet. So not the outlet but will not start. What's next?
    Brigadier General:
  • 6,277 Answers
Sorry but with such a fault it is extremely difficult for anybody on this forum to guess remotely what is wrong with your washer.
It could be internal wiring/plugs sockets, control panel switches, control PCB. I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
Sorry again and good luck,
John C
Posted on Apr 08, 2011
I want to reset the oven
Gas or electric? If electric are you sure you have power. Double check the breaker. Turn of and back on. If it pops, you have a wiring problem, the breaker is bad (yes they do wear out). If Gas, make sure you have power to the outlet that serves the stove. If no power the system will not work. If no power to the outlet, again check the circuit breaker for that outlet. If these things don't help check your owner's manual and it's troubleshooting.
Feb 28, 2015 | Ovens
Maytag neptune drying center has no power mcg8000aww
Could be a bad thermal fuse, a bad drum belt, a door switch a loose wire , one of the computer boards or the user interphase. Time to call a qualified technician. This machine is a complex machine to disassemble and diagnose and if reassembled wrong could prove to be dangerous to operate.
Aug 31, 2014 | Maytag Neptune MCG8000AW Gas Dryer
Turned my coffe maker off for week-end & now will not heat up water
Make sure it's getting power, and that the "vacation" switch isn't on.
If on a GFCI outlet, press the RESET button - Do Not press the "test" button. If GFCI is located upstream on another outlet, or the breaker (not uncommon), try resetting the breaker or that other outlet.
If still no joy, check that the outlet is hot by plugging something else into it. If that item doesn't work either check the circuit breaker for that outlet by moving the lever all the way to the Off position, then back to the On position. You should hear a click like a light switch.
May 21, 2014 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Dryer 220 Breaker Repeatedly Tripping
Check all your wires again make sure you have a solid connection also your dryer plug has to fit really good in to the outlet not loose
Don't forget always turn off your power before work
Apr 01, 2014 | Electrical Supplies
Don't have power to 120v recpt. on dometic rm 2862 ref
Go to your breaker box inside the RV. Locate the breaker that is for the refrigerator. It may have tripped but still looks as if it is on. Turn it off then back on. It should click and stay firm in the on position. Now check your outlet for power. Either use an outlet tester or a portable radio. If you have power but the refrigerator is still not working you will also need to check the 12vdc power supply. The refrigerator must have 12volts to operate even when in AC mode. There is a wire from the 12vdc connection block that goes to a thermal switch on the heat riser tube to the right. That wire has an inline diode and if the diode has failed it will not allow the refrigerator to work and like wise if the thermal switch has tripped it will shut the unit down. The switch is resettable. The diode wire, if bad, will have to be replaced. If you do not have 110vac power at the outlet after resetting the breaker you will need to remove the outlet and inspect it for bad connection or broken wire and then trace the wire back to the breaker box until you find the point of failure. You will also want to check the ground bar in the breaker box and make sure the neutral wires are properly seated and tight.
Sep 18, 2013 | Dometic Refrigerators
Two of the electrical outlets in our kitchen have no power. I checked to make sure the connections were tight and they were, still no power. Then I replaced both of them with new receptacles (ones that...
Each outlet receives power from previous outlet box or switch box in a long chain of parallel wiring back to ceiling box, or junction box, and then back to circuit breaker.
Use process-of-elimination to find problem.
Locate all boxes on same circuit breaker. Locate box before the two dead boxes... it can be in ceiling light, or switch box, or outlet box. Then test those wires. Look for loose quick connect where wires are pushed into hole on back of device, or loose white wires twisted together and shoved to back of box.
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/How-to-wire-switches.html
Gene
Aug 03, 2013 | Leviton 10 Brown Switch Outlet...
Hi! Can you give an answer a blonde gal can understand? :) I'm not sure what model number it is butit has the # 3831a20015r on it. I moved into a rental house of my cousins. He is having a rough...
Hello Debbie,
There is so many things it can be if it just wont turn on, first of you need to check the breaker for that outlet of where it is plugged in to see if the outlet is hot, or just grab something you have and plug it into that out let, like a toaster, curling iron, anything that you can make sure the outlet is working, if not of course you would have to go to the main breaker panel for that outlet to see if breaker has not been tripped. If it is working , then of course if you turned on the on button on unit and still does nothing could be a reset switch, but of course with out having the model and all that, i would only be guessing.
Best problems solving in this case, i believe it is only $10 for live chat, to trouble shoot while we chat back and forth, or live phone support is always best and i believe that is $15 something to think about, to have this unit working. But first thing I can only do at this point, is have you check power to MAKE sure outlet is working. Let me know, Mike from fixya
Jun 27, 2011 | Hampton Bay HBLG5004 Air Conditioner
Our GE Dishwasher just stopped all together. No power..nothing. All the fuses seem ok. Not sure why it just died. WIRES seem to be in tact..etc.
Ia the fuse blown? or the breaker tripped off? Must know if these are the problem. Plug in other small appliances in outlets in the kitchen to see if power is there. If not go to breaker box(usually in garage) check your sticker label and reset horizontal switch(curcuit breaker)back to on position. Note; sometimes these breakers can look like there on, if not sure switch off and on again. If you have power to outlets( INCLUDING WERE WASHER IS PLUGGED IN) you'r all set. Check the outlet where washer is plugged in, you may find a breaker built-in to it. The reset will be between upper & lower outlet, if so this needs to be pushed in.(most have tiny red button) Keep in mind the outlet might be defective. Never work on electrical untill you are sure that you have the right breaker OFF! If not sure call a professional! Good luck, best regards.
Feb 01, 2011 | Dishwashers
I have a circuit breaker socket in my kitchen. Connected to it are two coffee pots and a Microwave. Periodically it trips for no apparent reason. Usually when there is only one appliance operating. ...
First make sure the connections to the fuse box and to the outlet where you have the appliances connected are clean and tight. If they are, next you you might want to replace the circuit breaker with a new one with the same Amp rating. You also have to see which other thing are sharing the same circuit. To do this turn off the breakers one by one if you don't have them labeled, and see which rooms or which other appliances or units stop working which are also turned off once you turn off the breaker that has been shutting down. If there are other things connected to outlets which are sharing the same breaker, not only in the kitchen, but in some other outlet in the kitchen or even some other room, then it could be that some other appliance or heavy equipment might also be draining too much power from a single breaker. Check and see how many other things are turned off somewhere else when you turn off that particular fuse which is shutting down. Hope just replacing the fuse will take care of your problem. If what I have suggested does not do it, then just call an electrician to check it out. Be careful! Hope this helps. God Bless.
Jan 13, 2009 | Electrical Supplies
Modular Home Wiring Schematics
Won't be a wiring schematic for it. If it is a modular it will be wired same as a house. Unfortunaltly it will be wired by the lowest paid electrician you have ever seen. LOL. If the wires are hot, put a multimeter on them and have someone flip the breakers one by one to identify the wires and breakers. If they are not causing any problems then they are just spare connections. Don't know why they would even be there.
Dec 11, 2007 | Computers & Internet
Estate ETW4400VQ Top Load Washer Logo
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
