Question about Navman GPS
Model F10 when i plug into car charger the batery light comes on red then after a few seconds turns green but when I press the on button nothing happens and the screen remains blank.
    Genius:
  • 3,422 Answers
HI,
Hold down on/off button till screen clears,this should reset navman F10 .Turn back on and it should...
Posted on Aug 06, 2008
  • Priya darshan Aug 06, 2008
    If you still face the problem then it is the battery.I suggest you to replace it with a new one or if it is under warranty please get it repaired or replaced.
Power button
try taking out the batery, and disconnect the charger. then press the ON button for about 30 seconds. put the batery back in place and try starting it up again. hope it works, it did for me :)
Sep 26, 2013 | ASUS K40IN-A1 Notebook
How do you recharge jump start system
put a battery charger for a car on the + and - leads and this will recharge it if you do not have the correct power pack recharge transformer
Jan 09, 2012 | Stanley Black & Decker Stanley J5c09 500...
I can't turn on the Wii. The red light is always on and when I press the power button (or even the eject button) the blue light is flashing (Only when I press those buttons). I tried the solution of...
Try pressing the power button down and holding it for a few seconds and see if your WII comes back to life. When I first got my Wii I would hold down the button just long enough for it to turn green. This seems like a standby mode. To get my Wii to turn off completly I needed to hold down
the button until it turned red and when restarting the WII I held doen the button until the Wii started back up.
May 10, 2011 | Nintendo Wii Console
MY BLACKBERRY BOLD 9000 WON'T TURN ON!!! My friend gave me her Blackberry Bold 9000. It's battery was replaced a few months ago but it hasn't been used since then. When I plug it into the wall charger,...
Ok...don't panic. The charger you are using is not compatible. Verizon only works with verizon blackberry's. Non verizon will not work with blackberry and vice versa. This is what will happen. you plug it in and it will boot for a few seconds and then the lightning bolt you see is the charge icon and then a red line in it means that charger is not compatable. Blackberry does make its own charger but there is a "pin" on the plug in that will tell it it is not the right one. Am I confusing you?
Jan 06, 2011 | RIM BlackBerry Bold 9000 Smartphone
I've misplaced my users manual for my Stanley J5C09 jump starter
Go to www.baccusglobal.com and link the Stanley link and then the "manuals" link and it should be there
Dec 27, 2010 | Stanley Black & Decker Stanley J5c09 500...
Jabra SP700 will not turn on. Charged until green light came on. Took off charger, and put it back in. Light turned red. Eventually went green again. Will not turn on. Back to red when I plugged in...
You've probably accidentally put it in locking mode. Here's what the manual says about it, and how to get out of it:
Locking mode
To prevent accidental key presses that could turn your speakerphone
on e.g. while carrying it in a bag, the speakerphone can be
turned into locking mode. Press simultaneously the Answer/End
button and FM button for 4 seconds while the speakerphone is
turned on. The speakerphone is now turned off and can only be
turned on again by pressing Answer/End button and FM button
simultaneously for 2 seconds.
Sep 24, 2010 | Jabra SP700 Bluetooth Car Kit
I turn it on the green power button is on. There are four lights that come on normally the only lights that come on is the right two only for a second then nothing
Is the batery led still green when you insert the power connector ?
Maybe the batery is not charging I had that problem with my aspire one.
Nov 17, 2009 | Acer Aspire One PC Notebook
Battery charger red light on, and two min. green charges light comes on. But the battery is still flat. Is there a fix or throw it away
1.) take battery out. no charge cables connected.
2.) bend battery contacts up slightly
3.) place battery in at an angle, so that 4 contact leads are touching, but the metal backing of the batery is not touching the contacts that I had just raised
4.) click the 4 contacts together back and forth repeatedly, at a quick pace (about 2-3 times every second.)
5.) what a relief to see the amber light come on! Place the battery completely in, close cover, press power button, and happy to see the green light and a boot =)
Sep 14, 2009 | Google Android
Tv switched itself onto standby and now will not turn back on. tried unplugging it and plugging it back in but it still won't come off standby. when you press the button on the remote it goes green for a...
unit seems to go into protect mode.Theres very little that can be done..There is good chance unit needs to be checked at a repair shop.Try to find one that is authorized for your particular brand if possible
Aug 05, 2009 | Televison & Video
Supertooth one user manual
Charge your Supertooth one via the car charger or by attaching a usb/mini usb cable to your computer usb port. Need to charge for 4-10 hrs. Indicator light glows red (needs charging), orange (charging) or green (charged)
Power on: Press green button for 1 second. Indicator light blinks blue. A beep will be heard
Power off: Press green button for 1 second. Indicator light turns red. A beep will be heard
To pair with your mobile phone:
1. Press green button on Supertooth for 5 secs until indicator light blinks red/blue 2. Access bluetooth menu on your phone. Turn bluetooth on. Execute a bluetooth search. 3. Select ST ONE from list 4. When phone requests password enter 0000 and press OK 5. The handsfree kit is now ready for use 6. Clip Supertooth on sun visor of your car so that the microphone and control buttons are directed towards you.
To make a call: Dial number on phone. Supertooth will automatically connect. Indicator light is steady blue during call
To end a call: Press red button for 1 second
To answer a call: Press green button for 1 second. The bluetooth indicator will turn a steady blue.
To increase/decrease volume. Press volume buttons repeatedly up or down. They are situated between red and green buttons.
Hope this helps.
Nov 22, 2008 | Cell Phones
GPS Logo
167 people viewed this question
Top Navman GPS Experts
Martin Murray
Are you a Navman GPS Expert? Answer questions, earn points and help others
