Question about Estate TEDX640JQ Electric Dryer
My outside metal outlet cover shocks me when I open the door flap to plug something in. On the same circuit is a mini ice maker and the metal bar inside also shoked me when I touched it. What should I do?
  • KD Grayson Heating,Air conditioning & Refrigeration
    No, plugging in a lamp is not a test when being shocked ! the ground is live, meaning the neutral is hot! this means polarity is reversed and bootlegged ground by jumping neutral and ground on the outlet! A very dangerous condition that a circuit analyzer will miss and a light will still work too! but anybody plug in a trouble light with a metal cover and go crawl on the moist soil and touch the metal covering thats hot and dead!
  • 499 Answers
Yes exactly, a 2 wire circuit has no ground/3rd wire, this is an escape ramp for power to choose over us! if its not there and a bootleg ground was made jumping neutral to ground , reversed polarity or a device plugged in reverse wired will make the ground hot! deadly condition and easily missed.
You need to reference from a true ground and or use the non contact type voltage testers.
Posted on Oct 26, 2012
    Genius:
  • 1,400 Answers
Hello
Turn off the breaker to that circut at main panel box.You can test if off by plugging in a lamp.
Either you have a bad receptacle or a bad ground somwhere on that circut.
There is also something called a floating neutral wire,which is a bad connection at a receptacle.
If your unfamilir with electric then please call an electrician to check out this problem,but i would not run or use anything on this circut until it is repaired.
Posted on Apr 08, 2011
    President:
  • 2,468 Answers
If its an old 2wire service to the outlet have it checked,by law now its supposed to be a G.F.C.I. outlet installed anywhere outdoors,if it is get it replaced,depending how it was installed it may have one of the conductors bare wire touching the metal skin on the outlet box,a G.F.C.I. if properly working should trip its internal breaker,if it doesn't then its defective
My ice maker is making ice, but it won't come out of the door. It gets stuck outside of the icemaker in the door. There is a flap that doesn't seem to be opening.
The units I have seen which have a flap, if water gets in from some drippage, it can freeze and make things get stuck. You might try some hot water on a small towel against the outside of the flap to see if that would melt any ice accumulation, or if you put a small pan under the flap hole on the outside to catch runoff and dribble a bit of hot water from the inside hole down spout to melt any ice that might free it up if that is causing it to stick.
You also might be able to fish out the ice from the inside and give flap a push to open it, or use a plastic spoon or spatula to push it through. While you might be tempted to melt the ice with a hair dryer, don't do that. It could be very dangerous if water suddenly spewed out and got into the heating element or motor and cause a fire or electric shock. Stick to not water and plastic to try and push it from the inside outward. Usually the mechanism to grind the ice is up above inside the freezer, not in the hole in the door.
If the door got stuck because its hinges came loose broke you might have to call a service center to come and replace it if you are unable to yourself.
Be careful and don't try anything if you are unsure of yourself.
Jun 17, 2015 | Samsung RSG257AARS (241 cu ft) Side by...
Jrsde229....why won't my ice maker door will not open fully
On the left side there is a small hinged cover used by the IR ice level sensor you need to push in on that door and then you can open the ice maker cover flap
May 24, 2014 | Freezers
I have LG side-by-side fridge freezer (GRL197NIS) with a Premium ez digital ice maker. When the ice cube or crushed ice is in operation the ice gets backed up inside the dispenser/door as the 'spring...
The answers gave me the confidence to have a look and on mine the arm had come out of the catch the other end from the solenoid.I just had to push it back in. So grateful thank you very much. It's not been working for about 18 months and I couldn't afford to pay someone for something that was just a luxury. A BIG THANK YOU!!
Aug 05, 2011 | LG 25.2 Cu. Ft. Side By Side Refrigerator...
Ice maker door
The solenoid that operates your ice flap needs to be replaced. You can get it at the linked site below.
http://midwayparts.net/midwayparts/zen-cart-v1.3.8a-full-fileset-12112007/index.php?main_page=product_info&cPath=2&products_id=176
May 20, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Ice flap door won't close - Freezer and ice maker frost up
Every time you use the ice dispensor , when the flap opens , cold air will fall inside the enclosed dispensor cover . This cold air , mixed with the warm outside air , produces moisture inside the cover . After so long , this moisture starts turning to rust , causing the solenoid and plunger to rust . G E has no "fix" for this problem yet . My suggestion , would be to drill holes in the bottom of the dispensor enclosure (white plastic enclosure , held on by 4 screws ) at certain points , so that the cold air will fall thru the cover , instead of staying in the enclosure . This is something I have to try on customers refrigerators for a while , before I send this Idea to G E . To answer your question , yes , I is normal to replace every couple of years ,.....for now anyway .
Sep 11, 2009 | GE Refrigerators
Bottom of ice maker is frosted up & leads to food getting frost
Sounds like your freezer is pulling outside air into the freezer from the dispenser door or around the door seals. This could be a defrost problem beginning as this is moisture remaining inside the freezer compartment and not being taken out during defrost. So it may be a good idea to look into the back of the freezer and see if there is frost forming also on the rear wall. If yes you will need to manually defrost by unplugging the refrigerator and removing the rear panel in the back of freezer to expose the evaporator coil. If frozen over I want you to defrost with a hair dryer until we can have a look at the defrost heater below these coils. The heater in your model PSS26MRSS has glass around the heating elements and will be easy to see if the element is burned out. If burned out the defrost heater part number WR51X10055 and the defrost thermostat part number WR50X10068 should be replaced. Let me know if you are ready to begin or if this is helpful. If by chance these 2 parts look OK then we will need to look over the main control board for burn marks or signs of heat damage. I'll be here if you need me Thanks, Sea Breeze
Aug 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrig Ice is freezing up on the door dispenser
Most likely the defrost timer or Adaptive defrost. Yours has the defrost timer. I want you to open the fresh food compartment and find a small opening through the control panel. The opening may have a plastic plug covering the hole to hid it. Remove plug and turn timer clockwise slowly until the compressor stops running. The compressor should remain off for about 25 minutes. If it does not turn itself back on then turn the timer slowly again to the right/clockwise until it does. If you need to restart the compressor. this way the timer will need replaced.Defrost timer is part number 482493 Keep me informed on your progress, Sea Breeze
SITE=> http://servicepartstec.blogspot.com/
SITE2=> http://appliancepartseast.blogspot.com/
Jul 11, 2009 | Kenmore Refrigerators
Can't make ice cubes only crushed ice
Hi: There is a flap right where the ice dispenses. When you remove the bin you will see it when inverted. This flap has to open for the ice to be cubed. You might rember a slap as it swung open when it worked. There is a bar that runs from the flap to the back of the dispenser. Work it manually to see if it's jammed or broken. If not look at the back of the freezer and remove the metal panel if neccessary, to find the jam or defective part. I hope this helps, Jeff
Jun 02, 2009 | Frigidaire FRS3R5EMB Side by Side...
Ice dispenser freezes up in door outlet
look at the circular flap that covers the outlet of the ice, see that it seals correctly as it closes. if there is a damage on the flap or it is not sealing tightly then frost will accumulate on the door because fresh air are coming in the door flap. if it is damage, replace the door flap. if it is stucking up, loosen up the mechanism.
Feb 18, 2008 | Whirlpool GS6NBEXR Side by Side...
Bottom of ice maker/dispenser frosting over
Open the freezer door and look down the ice chute while you shine a flashlite up the dispenser cute from the outside. If you see light around the chute door, it needs to be replaced or something is wrong with the mechanism. The problem you describe is almost always air leakage around that flap.
Post back if you need more help.
Nov 17, 2007 | Whirlpool GC5SHEXNS Side by Side...
Estate TEDX640JQ Electric Dryer Logo
319 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
