The red key light is on and I can`t open the door.
    Brigadier General:
  • 6,277 Answers
As you do not say what the make and model is I am having to guess- sorry, no promises!
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Apr 08, 2011
I have a 2007 golf r32 last weekend the car started and then immediately stopped with immobiliser active reading on the dashboard the battery is fully charged and both keys have new batteries.
Sounds like the tiny transponder in your keys has failed.or dropped.out while your changed /checked batteries. Small glass bead about 2mm diameter and 8mm long. Check where you drooped it ?
Or reset the keys. Driver door open, Key in the ignition, and press.and hold all buttons u.til tiny red light on keys ( pin hole youve probably not noticed before) lights up and flashed to pair after 5seconds press open door. Then close and open again keep driver door open. Repeat with second keys.
Should fix it.
Jun 11, 2017 | Cars & Trucks
Car door wont open
A bit more information needed i'm afraid is the door jammed or just will not unlock when using the key fob ??
Apr 06, 2013 | Skoda Octavia Cars & Trucks
Alarm won't turn off
the valet key doesnt have a transponder chip in it, so it will allow physical turning of keyways and operations, but will not disable the alarm and often wont disable the immobilizer.
sorry to say i think you will need to get an autolocksmith , or main dealer to get you a functioning key with transponder chip mapped to your cars rfid system that will allow alarm to be enabled /disabled
Mar 23, 2017 | 2000 Volkswagen Jetta TDI
Honda odyssey is locked
The red light should be the anti-theft system. Do you have a key fob to open by remote ?
Is the driver's door the only door with a lock cylinder ??
Jul 25, 2012 | 2002 Honda Civic
Key fob would not open 1995 discovery ,used key in door then alarm went off ,after a few seconds alarm ceased then put key in to start engine and got nothing now cant lock doors with key but red light is...
The red light means the Immobiliser has not been turned off, the deactivator in the key must not be working correctly, visit your local land rover dealer who will be able to make sure the key is paired to the car correctly, otherwise you may need a new key.
Feb 11, 2011 | 1995 Land Rover Discovery
I own a 98 Porsche Boxter went out of town for 3 weeks came back and now my battery is dead and my key with remote will not open or close my doors obviously cuz battery is dead. i did manulaly insert key...
now all you need to do is use the key to lock the doors manually and then remove it, after that use the remote to lock and open it like before.
hope it works
rate this
Oct 29, 2009 | 2000 Porsche Boxster
Unable to open doors with key due to discharge battery
you should not have a problem with this as the key is located in the remote and the alerm will sound but as soon as you put the key in the ignition the vehicle cancell the alarm[sword key in the remote
Jul 21, 2009 | Anti-theft Alarm System 3 Series E90 E92...
No check on opening door
you may have a defective door jamb switch
Apr 18, 2009 | Toyota Corolla Cars & Trucks
Remote key will not open door
hi, gareth hear
i think this mite work 4 u
get in your car and put key in ignition turn 1 turn then wait approx 15 20 secs for light in clock to go red then take key out light should stay lit, next get out of your car close door then lock it and open it, when u open car light in clock should flash 3 times, next get out of car hold lock button on your remote down and push open button 3 times (keeping lock button down and remote pointed at reciver) next lose go of both buttons and red light on key should flash 3 times at the same time as clock inside the car.
next get in your car with key! then start her up and turn off get out of car close door and push button to lock (it should lock) if not get back in start her up again and turn off, then push the door locks inside the car then open get out and your car will lock this time!!!!!!!
this will work 4 u!!!
good luck
Dec 14, 2008 | Code-Alarm Code Alarm Transponder
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
