Question about HP LaserJet P3005n Printer
Have reinstalled a HP P3005 printer on a new PC (XP SP2) via the USB port (and the IEEE 1284.4) and print jobs are VERY SLOW 1-2 min). Have of course download the last driver from the HP web. What can we do ? Thanks in advance
  • HP Master
  • 1,121 Answers
>Up date firm ware>check drivers suits pcl5, pcl6 or PS..> if print file is more try with different file & check> add memory.> Replace formatter
Posted on Jan 23, 2012
2 Suggested Answers
jaylex
  • 417 Answers
SOURCE: My HP LaserJet 6L Won't Print on new HP/Vista PC
Hi there I think that vista has a problem with IEEE 1284 connections try setting the driver properties to no bi directional printing. If not then I suggest to get a HP jetdirect box so you can use the Cat5e network cable.
Thanks J
Posted on Jan 28, 2008
Panasonic IEEE 1284
Not sure what the question is. IEEE 1284 is a parallel cable interface, standard on most computers up until Windows XP for sure. http://en.wikipedia.org/wiki/IEEE_1284. This interface was substantially replaced by USB. If you have an older printer with this interface you can still connect this to a newer computer without the parallel interface by installing an interface card (into a desktop computer) or connecting via a Parallel to USB adapter.
http://www.pcfixup.ca/2010/03/connecting-parallel-port-printers-to.html
May 08, 2014 | Microsoft IEEE 1284.4 compatible printer
Printer is too slow to print once the command is given from PC
Hi
While printing from the USB Port sometimes slow printout/data transfer will result in slow printing of print jobs. or The printer might be printing slow , pausing in between print jobs , or intermittent printing. The symptom solution is mention below, read and follow the instruction.
Solution 1
After the printer is installed on the USB Port, check the description under the Ports Tab what is selected. Please refer to the figure below : c00873625.jpg Using the USB/ Virtual Printer Port and DOT4/ HP Laserjet 2420, under the Port/Description Tab printer speed will be as per the standard. Whereas using the DOT4/ Generic IEEE 1284 under Port/Description Tab, Printer speed will be very slow. If DOT4/ Generic IEEE 1284 is selected by default, then you have to uninstall the USB driver from the Device manager and plug in the USB cable again. Then it will detect the printer and USB port with respect to the printer model. Insert the Driver CD as prompted and by default it will select the DOT4 HP LaserJet2420 Port.
Solution 2
  1. Insert the HP LaserJet 2400 print series CD-ROM.
    NOTE: If the HP Software does not automatically start, click Start , Run , and then Browse . Browse to the CD-ROM drive at the top of the window under look in and select Setup.exe .
  2. Select Modify Installation . Figure 1: Modify Installation c00369540.gif
    NOTE: If Modify Installation is not available See Modify Installation is not Available.
  3. Select the Language of your choice. Figure 2: Select Language c00369541.gif
  4. Click Next. Figure 3: Setup Wizard c00369542.gif
  5. Verify Reinstalling an existing printer is selected. Under Select the port for this printer , choose USB001 or Dot4_00x and click Next . Figure 4: Choose Port c00369543.gif
  6. Select desired Features and click Next . Figure 5: Select Next c00369544.gif
  7. Click Finish . Figure 6: Select Finish c00369545.gif
Uninstall options
  • First verify if an uninstall options is available. If an uninstall option is available under Start, Programs, HP LaserJet 2410 2420 2430 , use this method to uninstall the printer.
God Luck
Sep 09, 2011 | HP LaserJet 2420 Printer
I am simply making a copy and it is printing super slow.
hELLO IDEAL58ST,
While printing from the USB Port sometimes slow printout/data transfer will result in slow printing of print jobs. SOLUTION: Solution After the printer is installed on the USB Port, check the description under the Ports Tab what is selected. Please refer to the figure below : c00873625.jpg Using the USB/ Virtual Printer Port and DOT4/ HP Laserjet 2420, under the Port/Description Tab printer speed will be as per the standard. Whereas using the DOT4/ Generic IEEE 1284 under Port/Description Tab, Printer speed will be very slow. If DOT4/ Generic IEEE 1284 is selected by default, then you have to uninstall the USB driver from the Device manager and plug in the USB cable again. Then it will detect the printer and USB port with respect to the printer model.
THANKS.
Sep 06, 2011 | HP OfficeJet 6110 All-In-One InkJet...
I have a citizen prolaser 6000 laser printer, it emulates HP Laserjet 3, I want to connect it to my laptop via a usb interface cable, currently it is connected to the printer port of a desktop (lpt1 for...
There is three things that you will need:
Proper port set up on laptop device manager (Check settings) LPT1 is for a parallel port - Need USB Correct Driver for the Citizen 6000 Pro Laser (Windows should auto install) Hub that will communicate via USB to the IEEE 1284 Printer via cable.
Driver Site: http://www.driverfiles.net/Printers/Citizen/Prolaser-6000-Printer-Driver/download/page,sh,38839,389,12,.html
I hate to suggest, but you may have to call Microsoft Citizen Tech Support for suggestions on the Hub that will communicate via USB properly. Check your manual for setup options.
TF
Jun 02, 2011 | Office Equipment & Supplies
Hp laserjet 1100 - won't print under Win'98SE i've got this printer and can't use it on a computer under win98SE. under XP works fine! all the ports seems to be bussy, and request to increes the timeout...
Try changing the LPT port mode in the BIOS- there should be like SPP, EPP, ECP. As I recall there are different drivers for USB and Parallel and I don't think Serial is supported. If you installed HP drivers, Uninstall and use the Windows drivers.
Dec 07, 2008 | Office Equipment & Supplies
I just purchased a laptop with XP Home. I have an HP Laserjet 6L which does not have a USB connection. So I installed a "USB to IEEE 1284 Parallel Printer Cable." The computer found the...
Power OFF both Printer AND Computer.
Boot up computer.
Insert the USB cable into a port.
WIN XP will recognize and install needed software.
Attached the USB cord to the printer.
Power up the Printer
Next configure the Printer . . .
ø Start > Settings > Printers and Faxes
ø Right-click on HP LaserJet 6L
ø Properties
ø Ports
o Find “USB001 Virtual printer port for USB"
o Select this, if not already done
o Apply
Jul 08, 2008 | Office Equipment & Supplies
Canon BJC 2000 question-1284 to usb
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} USB to Parallel conversion requires translation by XP and Vista's 'hardware interleave' software as well as the USB device manufacturers driver. The software package just doesn't work well with older peripherals that use legacy parallel or serial com ports. Too many sloppy layers.
THE BEST WAY to add an LPT printer port to your laptop is to use a PCMCIA to Parallel adapter card.
The PC Card slot provides access to the laptop's data bus, and the PC Card adapter easily sets up as a native LPT port within almost any OS.
There is no delay, or connection problems as I've seen in so many complaints about USB to Parallel or Legacy Serial adapters. Printing is Instant.
PCMCIA is a mature standard, and works seamlessly with XP and Vista, and almost any other OS.
PARALLEL is the old standard fast data protocol. IEEE 1284 ECP mode up to 1.5 Mbps.
The BJC-80 and the BJC-85 have the same print speed. The BJC-85 just added USB.
INFRARED is ver 1.0 on the BJC-80, and printing is a bit slower at 115.2 kbps. Even the BJC-85 with its higher IRDA transfer rating and a laptop's built-in IR port, the XP print spooler has problems with it, and can hang if printing more than one page, and especially with more than one document. It will not scan.
I use IR for printing single pages only with either the BJC-80 or BJC-85.
USB to IRDA adapters work fine, and are less expensive $5-6 than
PCMCIA to Parallel adapters, $20-25.
I have tested and used several PCMCIA adapters from different manufacturers, and they all work perfectly as a hot-pluggable, instant LPT and/or Legacy Serial port for my laptops.
TIPS:
After installing the PC Card driver, check Device Manager for the LPT port number.
Install the printer manually from the list of printers, and select the proper LPT port.
Most laptops have two PCMCIA slots. If you change slots, the adapter card driver may reinstall, and assign the next available LPT port, LPT2.
To scan with the BJC-80, you must have an LPT port.
The PC Card adapter also allows the use of the IS-12 scanner cartridge within XP or Vista.
Within Vista, set the Canon ISScan software to run in Windows 98 compatibility mode, to allow use of the TWAIN driver.
Jun 05, 2008 | Canon BJC 80 InkJet Printer
Use any printer parallel 25pin convertor to USB cable and connect it to pc or notebook
Connect both ends from pc to 6L printer
Go to website to choose the correct O/S driver for installation
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=14974&lang=en&cc=us&taskId=135&prodClassId=-1&prodTypeId=18972&prodSeriesId=25476
Use virtual USB port005 for printer 6L
Bi-directional option can be ticked
Click apply and ok
Unplug and replug the USB cable
Try printing a test page,
I have tried it, the vista download drivers works on vista, no problems in printing at all, advise from http://www.bebo.com/andythoo
Jan 20, 2008 | HP LaserJet 6L Printer
Cant print from workstations
Try changing the driver for your HP LJP3005 on your XP machine. Use it with the HP LJ Series II driver.
Aug 10, 2007 | D-Link DP-301U (790069251979) Print Server
HP LaserJet P3005n Printer Logo
230 people viewed this question
Seeker5211
Seeker5211
