Question about Zanussi ZXE66X Cooktop
I am wiring in a newly bought zanussi zxe66x hob. There are no instructions. There is a diagram next to the "wiring box" on the unit showing 5 screws for wires. The 5 screws are numbered 1, 2, 3, N and PE. It seems clear that N and PE are for Neutral and Earth connections. Then the diagram seems to indicate that for 200-240v I should connect 3 and N, and that I should connect 1 and 2. I presume I should then wire in my Live wire to 1 or 2. Is this correct? Vernon Gould
5 Suggested Answers
  • 1462 Answers
SOURCE: Only 2 hobs work
this is almost certainly a wiring issue at the mains connection block, there are links which have not been tightened down. there is usually a diagram adjacent to mains block telling you what to do. connection block is covered by a plate. take plate off and tighten all terminals making sure links have been inserted. switch of at mains of course
Posted on Jun 06, 2007
  • 619 Answers
SOURCE: Terminal Designation
Ok if R is live use tester volt meter 110 volts connect tester from cord terminal one tester connect to R the nmulti tester read 110 volt if ok good .
Posted on Jan 10, 2008
SparePartsPr
SOURCE: Back L element no go
Feel free to download a copy of your wiring diagram from http://sparepartspro.zendesk.com/entries/118713-zanussi-electric-hob
Qualified Electricains only.
Posted on Feb 25, 2010
Testimonial: "Thank you"
BarrettDenCo
  • 1772 Answers
SOURCE: i need to know the
Sorry to read about your problem, I hope this helps you out.
you dont need a wiring diagram, the part should be a direct replacement.. wire for wire..
if not you got the wrong part
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Posted on Dec 21, 2010
Bosch five ring hob ignition
It can be for another model if this is the ignition unit. Please confirm with your supplier before it can be tired as they might allow you to exchange if this order was misplaced. Please quote the part number or model of the oven.
Nov 11, 2011 | Cooktops
Hob problems
Take a closer look at the wiring diagram on the base or in the book.Check you have put in the relevant links.If not wired properly you may only get half the hob working.
Hope this helps.
May 19, 2010 | Smeg 28 in. P752 Electric Cooktop
Feb 24, 2010 | Zanussi 23 in. ZKT641H Electric Cooktop
When i switch my zanussi hob on L comes up on all 4 zones.Could you tell me what is wrong Model no.ZKT641F.
Turn on so that all are showing L
Then press - for 5 seconds when all should show 0 then turn off.
Upon turning on all should be fine.
Sep 09, 2009 | Zanussi 23 in. ZKT641H Electric Cooktop
Induction hob switching off
check that the hob is wired correctly underneath 1,2,3 should be linked together as live 4,5 as neutral and earth takes its place as earth,
if it is wired correctly then i m afraid the hob needs a new induction element it is all one complete unit on these hobs not seperate so your looking at £1000 + to fix it plus engineer call out charges
Dec 06, 2008 | Kuppersbusch K 23 in.EKE604.2 Electric...
Brand new bosch pke691e20e ceramic hob trips 50amp mcb
You have a short to ground somewhere.
Was there a new cord installed on it or did the cord come already installed?
It could have been wired wrong causing a short to ground. there could be another wire touching the cabinet, a wire pinched by the cabinet.
You may have to trace down every wire with a continuity meter to find it, but its probably fairly obviose.
I'd start at the cord.
First try this, unplug the cord, turn the breaker back on just to make sure the problem is indeed in the unit not the receptacle or panel box.
If the breaker stays on, you know its in the unit.
Dec 05, 2008 | Cooktops
Wiring for Neff Hob-not supplied/no wiring instructions
The details of how to wire the T1213 hob are printed on the base of the hob next to the terminal compartment. For a single cable installation, Neutral is connected to terminals 4 & 5 which should already be linked with a copper link. Terminals 1,2 & 3 should be linked together using the links supplied (hidden in the side of the terminal compartment) and Live is connected to any one of 1,2 or 3. The Earth goes to the terminal beside the cable clamp.
Nov 28, 2008 | Neff T1323 Electric Cooktop
Zanussi Ceramic hob ZKT641H front/main left zone does not heat up
can't give you much guidence - will be either regulator or the plate itself. no easy way to find out. you will have to remove the hob top and check for continuity thro the plate. ifplate is ok, then power up and check for supply to the plate. if no supply, then the regulator will be at fault
Aug 27, 2008 | Zanussi 23 in. ZKT641H Electric Cooktop
Have a baumatic ceramic hob displayin letter 'L'
Got the same problem, and remembered I've kept the manual book
L means locked. I dont know how Ive managed to do this as well
Anyway it says:
Cancelling the key lock
After switching ON the control the child safety feature can be deactivated. Here it is necessary to simultaneously operate the front right cooking-zone-select-key and the MINUS-key and then operate the MINUS-key alone. If all steps hae been carried out in the right order within 10seconds the key lock gets cancelled and the control is OFF. Otherwise the input will be considered incomplete, the control remains locked and switches-OFF after 20 seconds.
After a renewed switching-ON/OFF key all displays show 0", the display dots are blinking and the control is ready for ooking. If a cooking zone is "hot", "H" will be displayed instead of the static 0".
Followed their instructions & still not worked. ,I am still confused and baffled after these instructions........................
Mar 28, 2008 | Zanussi 23 in. ZKT641H Electric Cooktop
Only 2 hobs work
Jun 06, 2007 | Zanussi 23 in. ZKT641H Electric Cooktop
Zanussi ZXE66X Cooktop Logo
108 people viewed this question
Top Zanussi Cooktops Experts
fyigen
Brian Coughlan
Tom Chichester
Are you a Zanussi Cooktop Expert? Answer questions, earn points and help others
