Question about Konica Minolta Magicolor 4690MF Multifunction Laser Printer
My konica minolta magicolor 4690 mf has a message: toner empty change k toner. i have a brand new printer konica minolta magicolor 4690 mf and i put the k toner from new one into the used one but is giving me the same massage: changr k toner (and the toner is brand new). when i tried to give a print test from pc the error message is: a used toner cartridge or non-konica minolta toner cartridge is installed. what is happening?
SOURCE: Konica Minolta Magicolor 2300 DL - Fatal Error Code 0EH ????
I had the same problem one time, they told me to pull out all of the toner cartriges, power off, power on, power off, replace all cartridges and the problem went away.
Who knows why. If this doesn't work....
Call Konica Minolta tech support.
They were pretty helpful to me.
Dave
Posted on Jan 06, 2008
osiriscompu
  • 16 Answers
SOURCE: Konica Minolta magicolor 2430DL
Open the top cover. Remove the drum (part with long green handle). Below the drum you will see a strip of glass about 4-5 inches long. Take a cloth and wipe across the glass.
This will normally clear up any white lines in your print.
Posted on Jul 19, 2008
  • 192 Answers
SOURCE: After replacing black toner cartridge printer displays Drum Low
Ask you companey that surives you printer to look at it
Posted on May 20, 2009
  • 52 Answers
SOURCE: "Can't Detect Genuine Toner Cartridge"
minolta printers work on "chips" if the chip atached to the cartridge is not original minolta you better change it.
Posted on Jun 18, 2009
  • 97 Answers
SOURCE: Konica Minolta Magicolor 4690MF gives 0502 error.
The fuser temperature is too high. There is probably some residue from the transparency left on the thermister or the thermister went faulty that causes a wrong reading. The only solution would be to have the printer serviced.
Posted on Aug 05, 2009
Not installed toner check Y error message
replace the yellow toner container with OEM NOT THIRD PARTY
Jan 27, 2016 | Konica Minolta Magicolor 4690 MF Laser...
Konica minolta magicolor 4690 mf won't print after changing network setting
I would recheck the network setting first why where they changed???
Jan 30, 2014 | Konica Minolta Magicolor 4690MF...
as before check the network setting correct ip address cabling usb?
Toner not insatlled magiccolor 4690
Remove a toner cartridge and verify a home position sensor or other components associated.If the cartridge is refill change the chip.
Dec 21, 2013 | Konica Minolta Magicolor 4690MF...
Toner problems with Konica Minolta 2450
very annoying message i agree - most likely caused by toner dust.
The printer uses a carousel to rotate the toner cartridges. Dust and toner can easily spill as the cartridges rotate. The error can appear at any time but seems to be most annoying after a paper jam or other error. It is also important to make sure that the cartridges themselves are clear of toner dust. Pay particulair attention to any copper contacts on the cartridge.
http://www.zinetic.co.uk/toner_refill/magicolor-sensor-errors.aspx
Jan 12, 2010 | Konica Minolta Magicolor 2450 Printer
Konica Minolta Magicolor 2400W drum cartrige-how to replace?
Did you buy a whole new drum unit, or just change the cartridge? If so, the fuse may still be blown. Also, you may need to empty the spent toner out of the old cartridge.
Oct 07, 2008 | Konica Minolta magicolor 2400 Laser...
Toner Empty Message won't go off
check that the toner is inserted correctly, reboot print.
Aug 27, 2007 | Konica Minolta magicolor 2430 DL Laser...
Konica Minolta Magicolor 4690MF Multifunction Laser Printer Logo
1,055 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
