Question about ViewSonic VT2230 TV
ViewSonic VT2230 turns on, shows the viewsonic logo, then screen goes blank and can't power off unless I unplug it.
  • aaron1970660 Apr 08, 2011
    ok, well I just replaced the power supply all together, but still having the same problem.
    Well, it turns out it's the LCD inverter board. Thanks anyway
  • 10,594 Answers
This kind of problem related to bad firmware saved in ROM that is part of main board so main board will be rpelaced to solve this issue.
It has nothing to do with power supply board that was replaced.
I'm not sure if main board is available some where as I could not locate it.
Thanks.
Posted on Apr 08, 2011
  • Shahid Electronics
    Shahid Electronics Apr 08, 2011
    LCD inverter board?
    Problem is in Main Board that has inputs jacks.
    Inverter board is some thing else, it provide high voltage to back light lamp to glow.
  • ViewSonic Master
  • 2,098 Answers
Hi aaron1970660,
Unplug the unit to the outlet then push the power on button for 1 minute to drain the voltages and refresh the board. Try to power it on again.
If the symptom still persist, your power supply was gone to out-of-regulation and/or missing some output voltages. Most common symptom of out-of-regulation was a bad filter electrolytic capacitor. Some gone leaky and some are dried which will result to dropped of voltages and disable the unit. Leaky capacitor has bulged/dome at the top and easy to recognized but dried capacitor has no physical indication. You must have a capacitor checker to determine its condition.
Missing voltages in the output stage was caused by open fuse/fusible resistor in line with a shorted transistor. You must know how to test this parts to pinpoint where the fault came from. Effective way to locate where the fault came from is by checking the output voltages...
If you don't have necessary tools and test instrument and can't troubleshoot the unit yourself, I would advice you to look for an experienced technician to isolate the trouble. Also check if your unit is under warranty, if so avail it because the manufacturer will fix it for free or a little charged only.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
I cant change my VT2230-M to the tv setting. I turn it on, the power light turns blue, and then the parrots come up. then the Monitor goes blank.
I had the same problem. It appears to be due to a bad tv tuner. Turn on your computer and leave the coax unplugged. Leave it for a while (15-30 min). When you see "snow" on your screen, you will be able to use the source button to change to another input and see if you can get a signal. I am running my cable through a dvd recorder and using the AV input to watch tv. Also, my HDMI, component and RGB work fine. After thank don't try to access the TV source until you have had your tuner replaced.
Apr 12, 2011 | ViewSonic VT2230 TV
Have just hooked up my Viewsonic VA720 moniter as the main moniter to a new laptop that I have. The laptop is an ACER Travelmate 6293 running windows XP. When I come to start up my computer each morning...
You most likely have a capacitor that has changed value. When a capacitor goes bad it will work after it heats up. Sometimes a bad cap will have a bulging top or show signs of leakage. Sometimes can only be checked with a meter.
Oct 04, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
ViewSonic VA720 Screen displays briefly then goes blank.
it looks like the Inverter's gone in your screen, it works like a starter in a florescent tube, it 'kick starts' your screen to come on. Turning it on/off many times eventually 'kick starts' your screen and makes it come on eventually.
Jan 15, 2018 | ViewSonic VA720 17" LCD Flat Panel Monitor
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Screen goes blank
abandoned problem for now. will look for inverter board or parts from another monitor
May 12, 2009 | ViewSonic 22" FLAT SCREEN CRT BLACK...
Viewsonic vp930b-3
MY VP930b has the same problem.
It takes a very long time (5-10 minutes) before it becomes normal.
Aug 04, 2008 | ViewSonic VP920b 19" LCD Monitor
ViewSonic VA912b (Back light with blank dark screen)!
the capacitors in the monitor give out have to see a technician
Aug 19, 2007 | ViewSonic VX910 19" LCD Monitor
Vx900 viewsonic monitor problem . Blank screen except for power off/on
no, Viewsonic has the part for sale 42.99 - free shipping. Easy to replace
May 25, 2007 | ViewSonic VX900 19" Flat Panel LCD Monitor
Screen goes blank after a few minutes
hi if your sure that all the power settings of the screen and the comp are fine then it points to 1 reason: the screen is heating up and the automatic circuit shuts it down... try locating it some cooler place or put a vent behind it... see if it does any help if soo set it in a cool place good luck
Mar 16, 2006 | ViewSonic VP191b 19" LCD Monitor
ViewSonic VT2230 TV Logo
619 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
