Question about Geberit 152.675.ID.3 Basket Strainer PVD Brushed Nickel
My strainer basket for Geberit 152.675.ID.3 brushed nickel strainer is broken and I cannot find a replacement basket. HELP!!!
I have two Geberit 152.1101.RT. Black sink strainers in my kitchen sink. The baskets have broken and I need to replace them, but I understand Geberit no longer makes this product, and I need to know if...
No, its like mixing Ford with Chevy. See if you can fine something at your local hardware store. If a FIT ALL works take the new strainer to a Powder Coat Shop and they can dip them and make them black for you
Or just buy new ones from Kolher and install them not hard to do
THanks R J
Sep 08, 2011 | Plumbing
Hi When I push down the Franke Strainer Basket in order to fill the sink basin, it appears to leak in the cabinets below. With out pushing down the strainer basket whilst tap is running there is no...
More than likely it's leaking from where the body meets the sink. U might need to pull it apart, clean it up, and re apply plumbers putty to the sink and re apply the body. If you are doing this I would recommend buying a new basket assembly from the hardwear store. Just makes more sence than re using the old one. That is enles it's new. Hope this helps
Mar 29, 2011 | Franke 900SN Strainer Basket: Satin Nickel
Basket, silcone, sink, white gasket, black rubber, drain pipe? Is this correct?
basket
silicone (or plumbers putty)
sink
black rubber
white gasket
strainer nut
vinyl tailpiece washer
tailpiece (drain)
tailpiece nut
Nov 03, 2010 | Kindred 1135 Standard 3 1/2 inch Basket...
Why is my filter system losing prime?
It could be one of these issues with your pool filter. Try these solutions. If none of them work, let me know and I will do some more research.
1. D.E. coated with normal accumulation of pool dirt, algae, etc.
Solution: Bump your filter.
2. Pump strainer basket or skimmer basket is clogged.
Solution: Clean
3. Pump impeller vanes clogged.
Solution: Cleaning with a stiff wire brush through the pump strainer opening will usually work. Alternate method would be to disassemble and clean.
4. Air Leak on suction side of pump.
Soultion: Check cover gasket, hand knobs, hose, clamps, etc. Replace or tighten as necessary.
5.
May 17, 2010 | Hayward EC-40 DE Pool Filter with pump
What can clean your tounge without a toothbrush?
They make tongue scrapers at Walmart in the tooth paste aisle.
Apr 26, 2010 | Orange Kwc Remote 3 1/2" Brushed Nickel...
Strainer lower washer,not basket strainer, do you have source?
Not sure what you are asking. If it is broken it can be replaced, any hardware store would carry it. If it is leaking, try using plumbers putty. Roll it between your hands like play-dough. Roll it into long skinny string about a pencil width, and place it under the lip of the basket strainer where it makes contact with the inside of the sink. Proceed to tighten from underneath. Keep the basket strainer as still as you can. Remove excess putty.
Mar 17, 2010 | Danco Bg/10: Sink Strainer Washer
Basket strainer
You will need to have the entire basket strainer drain assembly replaced.
Jul 12, 2009 | Plumb Pak Laundry Tub Strainer Basket...
Basket Strainer Specs Question
1\ Amount of free open area is the ratio of the open area through the strainer basket to the cross sectional area of the pipe. A good basket strainer should have a ratio of 4 to 1. 2\ Ease of basket removal is important because baskets may require frequent cleaning or replacing due to buildup. 3\ Compactness of the design saves you valuable space. A small strainer is less bulky and easier to handle. 4\ Availability of basket perforation sizes gives the strainers the flexibility to cope with a wide range of particle sizes.
Aug 27, 2008 | Moen 22174 Stainless Steel 2in. Basket...
Geberit 152.675.ID.3 Basket Strainer PVD Brushed Nickel Logo
Top Geberit Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Geberit Plumbing Expert? Answer questions, earn points and help others
