Question about Ariston Technologies Ariston AWD12 Front Load Washer/Dryer
Program knob keep on running contineously - Ariston Technologies Ariston AWD12 Front Load Washer/Dryer
    Brigadier General:
  • 6,277 Answers
On some washers that is an indication that either the filter is blocked or the drain motor is malfunctioning.
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Apr 08, 2011
Ddw1802 wont turn off and continously drains
I would suspect the control board is defective.
Oct 31, 2016 | Washing Machines
My Whirlpool Washing Machine W10560167A restarts after completing a wash cycle. Is their any way to fix this problem or why it keeps restarting?
Need model # that is apart # or diagram number the unit is programmed for continous run provide model # will explain how to take out of this mode
Sep 25, 2014 | Whirlpool Washing Machines
I want to program the fan to run continously
I don't see this as a 'programable' feature.
The unit is designed for the fan to run anytime the compressor runs and if you just want the fan to run all the time (without the compressor) just switch it to the 'fan/fan only' position.
May 12, 2010 | Amana PTC093B35AE Air Conditioner
Sparkling sound can be heard continously on the GE Cooktop
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Feb 17, 2010 | Jenn-Air JGC8536 Gas Cooktop
Whirlpool dishwasher runs continously problem with knob
You have damaged the internal workings of the timer and unfortunately it will have to be replaced. It is not repairable.
Eric
Dec 30, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Hi, freezer is cold at bottom , circulating fan is not working.
Hi Guys, I tested fan removed(to 240vlts) neg- pos to wires+earth to mount bracket, and found to be working, reinstalled and found power - active to both wires??fan cut out (defrost mode)activated by timer control, my timer control ( bottom rear near motor) has a knob, so i turned it and fan started,continous turning knob ran thru all cycles defrost,fan start, etc: obviously timer control was faulty, To save frozen goods , i set control to run and installed a power point timer to cycle freezer till new switch arrives, taking the place of faulty controller...
Oct 23, 2009 | Electrolux Freezers
Drain pump runs continuously. Nothing else happens!
Water had accumulated in the sump - a plastic tray at the bottom of the dishwasher which catches any leaked water. This operates a float switch which makes the drain pump run all the time. The fix was to tilt the dishwasher backwards to drain away the water. It isn't filling up again, so I'm not sure where the water came from, but I'll keep an eye on it!
May 17, 2009 | Bosch Dishwashers
Program knob on GE washing machine not functioning
The teeth on the knob are gone. You need knob. Pull knob out (on pos.) look down on knob& in see clip push clip off to remove knob. Need screw driver
May 05, 2009 | GE WJSR2070B Top Load Washer
PRINTER PROBLEMS
NECESITO LOS DRIVERS DE ESTA IMPRESORA. FAVOR ENVIARMELOS A DLFNA207@GMAIL.COM
Jul 16, 2008 | Epson LX-300 Matrix Printer
Ariston Technologies Ariston AWD12 Front Load Washer/Dryer Logo
197 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
