My maschine wont spin and the lights are all flashing display says F5 Please help!!
    Genius:
  • 1,400 Answers
Hello
Error F5 is a heating element or thermostat error on most machines.Try clearing it out by unplugging machine for 3 min then plug back in.
Try changing you water temp to cold only then try to finish wash.
If this does not help your going to need service.
Posted on Apr 08, 2011
    Brigadier General:
  • 6,277 Answers
As you have not told us the make and model of your washer I am having to guess! Different makes, models, different fault decodes ;-0(
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Hi i have a whirlpool washing machine that keps coming up with a F05 on display with all lights flashing what does this mean please?????
The F5 error code means that during the wash cycle that the computer didnt see a rise in the water tempature...that means that their is a problem with the heating circuit in the washer,it could be a problem with the heat element,thermostat,or control board that wont let the water heat in the wash cycle.
GENE
Sep 08, 2011 | Whirlpool Washing Machines
Display F2 maschine will not start green light flashes two times then pauses
Normally this means the dishwasher is in flood mode. You would need to remove the lower base pan to gain access and check.
Appliance & Refrigerator Repair
Mar 23, 2011 | Dishwashers
Hi got hotpoint aquarious wmf740. all lights flashing f-05 ? wont spin or drain. please help
Hi
Error F5 means that the pressure switch is jammed on full. This may have happened due to blockage or obstruction in drain hose. To be sure check whether hose is plugged, if not then remove lower rear panel of the washer.
Now you would be able to see drain pump and a large black hose on bottom of drum. Remove the hose from the pump; remember to keep a container near you to collect the water from the filter/pump. Remove and clean the drain filter connected with the pump and hose. Clean the pump and let it dry for a while. Now restart the washer after 2-5 minutes and your issue would be resolved. Please post back for further assistance. Hope this helps...
Daniel
Aug 30, 2010 | Washing Machines
The jukebox powers up but the buttons wont work
Is this a CD player or 45RPM? Is the display lighted? What is the display showing? The answers to these questions will help narrow down the problem. For additional assistance please email Rod Stebelton, tech@wurlitzer-ohio.com.
Nov 14, 2009 | Wurlitzer Jukebox 1015 One More Time...
When the machine is switched on ALL the lights
when the washing maschine is switched on all the lights are flashing,...you can´t switch that on or off,..you have to unpluged the maschine,...we are unable to wash any clothes
Nov 08, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Indest wil103 has 3 flashing lights the power one and to green ones stain remover and extra rinse and want spin what is wrong please help
If the machin isnt able to evac the water, it wont spin. It will indicate error with 2 flashing lights + lock led. Check pump, drain hose.
Jul 26, 2009 | Indesit W 123 Front Load Washer
Washing machine door locked indesit WD12X
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Apr 01, 2009 | Washing Machines
HOTPOINT AQUARIUS WF 250 ON/OFF LIGHTS FLASHING
The lights are set off by the balance sensors.And if your balance sensors are  stopping    it from spinning than you first have to make sure the washer is level.You  could have bad Shocks and a bad electronic control board,.
May 05, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
