Question about Proview HV-207 20 in. HD-Ready LCD Television
Trying to connect antenna. Tv will not program for digital channels. Only goes through analog and comes up with 0.
  • 760 Answers
Sounds as if you have a bad tuner. Can be tricky to replace if it is on a 2 sided board. If you are not comfortable with a soldering iron or electronics, I would have a certified servicer look at it.
Posted on Apr 08, 2011
The analog tv picks up a lot more stations and correct channels than the LED TV. Is it possible to set the Insignia LED NS-19E320A13 to analog? Is there a device available?
.YES IF ITS A DIGITAL TV U WILL GO TO MENU GO TO ANTENNA CHANGE FROM DIGITAL TO ANALOG OR AUTO ENTER THEN SEARCH ANOTHER WAY GET AN ANALOG TO DIGITAL SET TOP BOX FIX YA ANTENNA TO IT CONNECT TO TV BY HDMI.OR AV CABLES GET THE SET TOP. ON GO TO SCAN OR SEARCH AND YOU WILL HAVE ANALOG CHANNELS ON YOUR LED TV
Oct 08, 2015 | Insignia Televison & Video
Need programing lg tv/ missing code
there are no more analog channels, only digital ones remain, some tv's have a seperate antenna jack for digital, or for analog, so be sure to look at that, connect to the digital antenna jack, and then search for digital channels
Mar 21, 2013 | LG 55LE5400 TV
How do I retune my Panasonic Viera TV?
Hello
To tune your Panasonic Plasma to on air TV channels do the following:
Connect the antenna connection to its antenna in at the back panel.
Automatically searches and adds available channels to the memory.
Select "ANT in"
Select Cable or Antenna Select "Auto"
Select a scanning mode
Auto channel setup
Select "Auto program"
Select "ANT in"
Select "Auto"
Select scanning mode (ALL channels/Analog only/Digital only
Start scanning the channels
Available channels (analog/digital) are automatically set.
All channels: Scans digital and analog channels
Analog only: Scans Analog channels only
Digital only: Scans Digital channels only
Confirm registered channels
If OK is not pressed after selecting "Apply", the channels will not be saved.
The channel will be saved when no operation is performed for 60 seconds and
the "Manual program" menu will also exit automatically.
If you perform scanning more than twice, previously saved channels are erased.
About broadcasting systems
Analog (NTSC): Conventional broadcasting
Digital (ATSC): New programming that allows you to view more channels
featuring high-quality video and sound
[Use "UP ' DOWN ' RIGHT ' LEFT] AND 'OK"] keys to selcet and proceed.
Mar 07, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
RCA HD52W59 HDTV Plug in digital antenna into air antenna input then run channel scan =0 channels What should I do next??? Mike
Make sure you are connecting the digital antenna to the digital antenna input on the back of the set, then rescan. Most over the air Tv signals migrated to digital transmission and therefore the analog input is mostly for older analog devices. If you still do not get any channels, then you need to make sure the antenna you are using is rated for reception in your area. You can check for proper antenna size and channels available here,http://www.antennaweb.org/aw/welcome.aspx
Feb 08, 2011 | RCA HD52W59 HDTV Projection Television
Can't program digital channels only has analog option
If your TV does not have a digital tuner, you'll need a digital converter box.
After the digital switch in June, did you have channels then? If so just do a rescan.
Jan 11, 2010 | Broksonic CCVG1935 19 in. LCD TV
Trying to hookup vhs analog player to hd proscan
your toshiba player should have output composite video and audio which are color coded Yellow for video, red and white for audio same goes for proscan hdtv. connect between the two keeping in mind color of cables. If the toshiba player is really old you can connect the RF cable output to antenna input to the proscan tv and watch taped programs from the player on channel 3 of the proscan tv. If then you want to keep the hookup and still watch HDTV connect the antenna to the toshiba vcr and when you shut off the vcr you can now watch the hdtv channels as usual because now you are bypassing the antenna to the Proscan tv. Hope this Helps..
Dec 29, 2009 | Proscan 32LB30QD 32 in. LCD TV
My Sharp LC46sb54u does not let you program digital channels from the antenna. The option is deleted on the setup menu. How do you get the digital option back? The manual says once you program channels for...
Go to page 19. Make sure antenna setting is on DIGITAL
Then go to page 11. Change AIR/CABLE option to cable.
Then run the "Analog & Digital Search Start". The digital option should come back.
Jun 16, 2009 | Sharp LC46SB54U 46 in. LCD TV
Using an over the air antenna I get all channels but one.
I experience the same thing on a day to day basis. The key, is location of the antenna. Depending on where your antenna is located, determines if u can recieve local CBS analog v. digitial. I actually tried sticking aluminum foil to my old rabbit ear antenna legs. to my surprise, I even picked up digital channel I never knew existed. Besides, when the signal transmit in Digital, u are already prepared. Your local CBS afilliate station will be accesable on maybe 2 or 3 channels. example:
Channel 10 analog
Channel 10-1, 10-2, 10-3 digital HD will all broadcast the same programming.
hope this helps u out.
Dec 06, 2008 | Dell W4200 42 in. HD-Ready Plasma...
Trouble receiving local channels on TV using new Magnavox converter box
Your digital converter box probably does not have an analog pass through that allows the old analog channels to go through to the tv's analog tuner.
Jun 27, 2008 | Sanyo DS27910 27" TV
Proview HV-207 20 in. HD-Ready LCD Television Logo
212 people viewed this question
Top Proview Televison & Video Experts
Steven Wander
Steven Wander
Tony
joncin91
Level 1 Expert
Are you a Proview Televison and Video Expert? Answer questions, earn points and help others
