1992 Grand Marque, small V-8 Rough Idle when the car is started and starts to die out when you press on gas. Car runs fine after it warms up. What could cause this
  • 417 Answers
most likely a combination of a vacuum leak at EGR and a worn out throttle position sensor .Have it put on a computer for correct diagnosis. I believe autozone does computer checks for free.
jm
Posted on Apr 08, 2011
  • Jude Meredith
    Jude Meredith Apr 08, 2011
    plug wires, plugs, air cleaner, fuel filter... i
My 1979 buick reagal runs rugh when is hot
Idles rough and quits when gas pedal is pressed less?
http://technoanswers.blogspot.in/2012/01/1999-ford-f-150-idles-rough-and-quits.html
Rough idle, staling and Erratic shifting?
http://technoanswers.blogspot.in/2012/03/rough-idlestaling-and-erratic-shifting.html
Its a hot start issue.
Can be related to low fuel pressure or problem with crank sensor.
Also it can be weak battery or starter.
But possibilities are to be inspected to confirm what exactly it is.------
To troubleshoot and confirm the issue,i suggest you refer few solved help links with similar types of problem like yours:------
Click the link below:------
1991 Toyota Trecel: Engine Starts fine but dies when gets Warm?
http://whatisbyme.blogspot.in/2012/05/1991-toyota-trecel-engine-starts-fine.html
1994 Toyota Pickup: Starts fine but dies in few seconds?
http://howtobyme.blogspot.in/2012/05/1994-toyota-pickup-starts-fine-but-dies.html
1995 Lexus LS400: Running Hot?
http://whatisbyme.blogspot.in/2012/05/1995-lexus-ls400-running-hot.html
2002 Toyota Camry: Puff of Blue or White Smoke while Starting?
http://whatisbyme.blogspot.in/2012/05/2002-toyota-camry-puff-of-blue-or-white.html
Multiple problems on car: Car runs hot, A/C blows hot and car starts surging?
http://schematicsdiagram.blogspot.in/2012/04/multiple-problems-on-car-car-runs-hotac.html
Delay starting on Toyota Prius?
http://schematicsdiagram.blogspot.in/2012/02/delay-starting-on-toyota-prius.html
Honda car will not start intermittently?
http://technoanswers.blogspot.in/2012/02/honda-car-will-not-start-intermittently.html
Vehicle Starts, Runs and Loses Power
http://whoisbyme.blogspot.in/2012/07/vehicle-startsruns-and-loses-power.html
Intermittent starting issues on Volvo 760?
http://schematicsdiagram.blogspot.in/2012/02/intermittent-starting-issues-on-volvo.html
Car starts and cuts off immediately?
http://repairhelpcenter.blogspot.com/2012/01/car-starts-and-cuts-off-immediately.html
Car won't start when cold?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-when-cold.html
These details will help.
Thanks.
Dec 04, 2012 | Cars & Trucks
I have 1999Chevy suburban with 6.5 turbo diesel motor.it idles up and down and when driving the gas pedal is real touchy Wat is the problem and were do i locate the problem
Check the help links related to this problem.Click the link below to go through its troubleshooting procedure :-----Idles rough and quits when gas pedal is pressed less? http://technoanswers.blogspot.in/2012/01/1999-ford-f-150-idles-rough-and-quits.html---------
Car won't start without hitting the gas pedal? http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-without-hitting-gas.html
-------Complete loss of brake pedal then all gets normal? http://repairhelpcenter.blogspot.com/2012/01/complete-loss-of-brake-pedal-then-all.html
------Car dies when gas pedal is pressed? http://schematicsdiagram.blogspot.com/2011/12/car-dies-when-gas-pedal-is-pressed.html
--------Pushing on the gas pedal, but the car slows down? Gas pedal to the floor and the car slows down?
http://technoanswers.blogspot.in/2012/02/pushing-on-gas-pedal-but-car-slows-down.html
After replacing brake rotors and pads, brake pedal remains on floor? http://technoanswers.blogspot.in/2012/02/after-replacing-brake-rotors-and-pads.html
accelerator pedal sensor? http://technoanswers.blogspot.in/2012/02/2009-chevy-impala-accelerator-pedal.html
For rough idle issues and problem troubleshooting,go through the help links provided below :----- van idles rough?
http://howtobyme.blogspot.in/2012/01/2004-ford-freestar-van-idles-rough.html
will not idle when cold?
http://technoanswers.blogspot.in/2012/02/ford-explorer-40-will-not-idle-when.html
runs lean and idles rough?
http://technoanswers.blogspot.in/2012/02/ford-runs-lean-and-idles-rough.html
Engine stumbles coming off idle when warm?
http://repairhelpcenter.blogspot.com/2012/01/engine-stumbles-coming-off-idle-when.html
Erratic idle on car?
http://schematicsdiagram.blogspot.com/2011/12/erratic-idle-on-car.html
Low idle when cold out side?
http://repairhelpcenter.blogspot.com/2011/12/low-idle-when-cold-out-side.html
Idle Air Control (IAC) Valve Replacing?
http://schematicsdiagram.blogspot.com/2011/12/gmc-idle-air-control-iac-valve.html
Engine quits at idle?
http://repairhelpcenter.blogspot.com/2011/10/engine-quits-at-idle.html
Car overheats and Air blows hot at idle?
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
While stop engine idles like cylinder missing?
http://schematicsdiagram.blogspot.com/2012/01/while-stop-engine-idles-like-cylinder.html
This will help.
Thanks.
Mar 01, 2012 | 1999 GMC Suburban
I have a 2004 Jeep Grand Cherokee Laredo 4x4 with the 4.0L. It has approximately 150k miles on it. I started the Jeep with 1/4 tank of fuel in it and it started rough and acted like it was going to die....
long post.
ill reduce it for you.
misfires. (is RPM below 700 then misfire can be normal) for idle speed controls dead.
ISC the isc controls speed, of idle,.
mine stuck like zillion times, in 400k miles. endless.sticking
mine was a tiny gutless stepper motor drive ISC valve.
the cone valve is side gets nasty and sticks (
(PCV gases caused as seen on all engines)
i clean it.
the proof is the easy press of right foot easy raises idle back to 700rpm and engine stops misfiring.
ever get a tuneup this decade or running spark parts 500,0000 miles
for the new world record.?
now the tricky part of ISC, , fully explained in the SM serv. man.
the PCM learns its behaviors.
it learns all hot start settings and cold
so when you key on, it goes to the correct HISTORICAL spot.
if it can move there(sticks) engine car race.
or run too slow,
cold start would be worse, as hot isc is more closed
so if sticks there closed, the next cold start will be horrid
some newer manuals telly you to add 5% throttle if car is hard starting this is so common.
clean it. end story.
ISC
Mar 09, 2017 | 2004 Jeep Grand Cherokee
1992 Ford F250 Truck with start and idle problem
Could be many things, Check the EGR valve and make sure its not stuck open, Oil pressure low is probably due to rough idle or low RPM. Also may have restricted cat converter.
Mar 16, 2010 | 1992 Ford F250
It starts fine, runs 20-30 seconds, runs rough,
check the actual fuel line. Also is it fuel injection or carberator
Aug 03, 2009 | 1992 Dodge Power Ram 50
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
