Question about Frigidaire PLMB209DC Microwave Oven
PLMBZ209GCA Professional Series microwave: the timers and lights all work but NO Microwave? The last thing it cooked it shut down during a cooking cycle with 42 seconds lleft on timer. The turn table and micro wave just quit.
MicrowaveSvc
  • 9047 Answers
SOURCE: frigidaire won't run
Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Sep 23, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: microwave not cooking
I would say you have a bad door switch or door switch mount, or your door is loose or out of alignment.
But since it's new, and under warranty, I would contact Goldstar (LG) customer service to have them repair it free.
Contact LG at 1-800-243-0000 or http://us.lgservice.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Feb 28, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: timer will run, but won't cook
najah
  • 180 Answers
SOURCE: Micro wave does not work EM-Z2100GS
First you check the fuse at the out put of highvoltage of the transformer. If the fuse is ok, replace the magnetron.
Posted on Apr 08, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Micro Wave shuts down
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Posted on Nov 24, 2008
Whirlpool Talent Microwave The microwave starts off ok, then during cooking its still turning & the light is on but its not cooking. It can go on like this for 8 or 9 minutes and then you hear a small...
That is the magnetron faulty. The oven stops cooking, as the magnetron lose contact, when the magnetron restart working you hear that loud bang, and it restart radiating.
Replace the magnetron.
You find parts here or here.
Oct 08, 2008 | Whirlpool Microwave Ovens
FMV156DCA turns on, cook indicator lights but not cooking, timer counts down fine too
Hello epinvegas - Try reprogramming the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If it proves to be ineffective, then it sounds like the microwave has a faulty magnetron, wiring failure or control board. Contact a professional to assist with the repairs.
Feb 07, 2013 | Frigidaire FMV156DC Microwave Oven
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean, solder and reset the board. Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron. Check this link to know how a microwave works:
http://www.espares.co.uk/advice/microwave/a/5/1443/how-a-microwave-oven-works.html
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced. See link:
http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Now keeping clear of the microwave, switch on; use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
Feb 01, 2013 | Microwave Ovens
Panasonic Microwave suddenly won't cook.
Your microwave is detecting an internal shot and shutting down, Most likely due to a faulty Magnetron which is not a part that is worth replacing due to the cost of the part and the decrease in cost of new microwaves.
Mar 06, 2012 | Panasonic Microwave Ovens
We have a Frigidaire FMV156DCC that is about 3+ years old. as of last night when the door is closed and the time is selected one of 3 things happen (or doesnt happen) 1. is nothing, just a dark...
I would replace the door switches and set up the door gap to 1/8" just enough to alow for a little play.
Setting the door square is acheived by slackening the lower door hinge and re tightening it when the door is square.
Hope that helps.
Jan 03, 2011 | Frigidaire FMV156DC Microwave Oven
My two year old Frigidaire Microwave suddenly stopped cooking. All of the buttons work. The lights, the fan, the timer, and even the cooking timer operate. It's just that the light goes on and the timer...
Check the plug. If the vault is 110v or 220v etc.
If the plug seems to be right, but still not
working, you should buy a new one
with a good name brand you can trust.
It's better than paying for repairs and future repairs.
Mar 14, 2010 | Frigidaire FMV156DC Microwave Oven
JVM1190 wont cook
You have a blown actuator. This is the device that creates the microwaves that cook the food. The cost of one of these will be as much as a new unit.
Nov 09, 2008 | GE JVM1190 Microwave Oven
Microwave light and timer work, but no cooking
IF IT TURNS ON AND SOUNDS LIKE ITS COOKING IT IS PROBABLY THE HEART OF THE MICROWAVE THE RADIATION PART WENT OUT IT IS MORE RECOMENDABLE TO REPLACE THE WHOLE MOCROWAVE
Oct 03, 2008 | GE JVM1850 1000 Watts Microwave Oven
Frigidaire PLMB209DC Microwave Oven Logo
375 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
