Question about Dishwashers
I have an LGLD1415M dishwasher,that had a prob with water overflowing onto floor. i cleaned the filters and then turned the thing on, all the water left inside the washer was pumped out.but i still have the prob with the EI flashing light.
    Guru:
  • 500 Answers
E1 means: Water Level in Drum lowering, this would usually mean there is a leak on one of the pipes. But from previous experiences it is more than likely that it is the Circulation pump. It will have to be replaced, as it is a common spare that has to be replaced on L.G Dishwashers (lifetime 12 - 18 Months usually) - Not overly expensive. Usually is about 20%-25% the price of a new Dishwasher. The Circulation pump is fitted to the sump. Part Number: 5859DD9001A
See below a image of what a Circulation Pump looks like:
Good Luck :-) - J.Q
* If you found this solution helpful, please vote positively. A 4 four thumbs up will do nicely too :-)
Posted on Apr 08, 2011
Intake/Drain lit flashing
I have exact same symptons, please someone help. I have had issue before where the plumbing backed up so it overflowed into the catch tray. Then that has to be vacummed out and then just start a new cycle. This time there is no water in the overflow tray....
May 28, 2010 | Miele 18 in. G601SC Plus Slim-Line...
Too much sink water causes flooding from dishwasher.
If you let it sit with vinegar and it worked after for a while that tells me it may be plugged up with grease. Might be worth while trying to clean it out with Drain O a drain cleaner. Make sure its washed clean after. Grease and dirt builds up after a while in all machines. If vinegar works might be worth cleaning more often.
Mar 14, 2017 | Maytag PDB4600 Built-in Dishwasher
Dishwasher overflowed, garbage disposal still works. Ran the dishwasher and noticed food and debris shooting back into sink thru garbage disposal. Water was on floor. Upon completion of full cycle, water...
Before loading into the machine you have to remove food particles. Washer will wash the greasy surface. If particles are left in the dishes, the same will find entry to the drain system. Check the drain filter in your machine. Clean them. Mostly problem will be solved!
Apr 08, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
I have a Bosch dishwasher model SHU66. Clean water slowly pools in the base when the dishwasher is not in use. We need to drain the DW every 12 hours or water will overflow onto the floor. Is this an isue...
IT SOUND LIKE IT IS A WATER VALVE ISSUE.DRAIN AND CANCELTHE MACHINE FIRST THEN TRY TO SHUT OFF THE WATER GOING INTO THE MACHINE PROBABLY UNDER THE SINK. SEE IF THE WATER IS STILL COMING IN TO UNIT. IT SHOULD NOT BE. THEN TURN ON WATER IF THE WATER STARTS TO FILL MACHINE THEN CHANGE THE WATER VALVE.
Mar 27, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishwasher overflows from front
Hi andrew did you get this fixed as it sounds identical to my problem.
Ian
Sep 01, 2009 | Hoover 24 in. HD83M Free-standing...
The clean water fill will not shut off and water overflows from the dishwasher onto the floor. We had to turn off the water supply to the dishwasher to get it to stop.
Fill valve is shot , new one required
Ps
Does it still run when you remove the power if so the above applies
If it shuts off then the problem sits with the pressure switch
Jul 03, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
No Water entering machine
What is the make and model number of this diswasher?
Without that specific info, I would first check the water inlet valve for a failure.
Mar 26, 2009 | Dishwashers
Water won't fill
when facing the dw pull it out from under counter and on the left side there is a panel held on with 2 screws. take that off and under there are the float switches for the overflow. those switches is what causes the pump to run all the time but do nothing else.
Oct 30, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
70 people viewed this question
Top Dishwashers Experts
