My Mitsubishi Black Diamond Television Model BDS2151S has a green strip of about 4 inches along the top of my picture. I imagine this is a tube problem but was curious if it was fixable, expensive to fix and if I could do the repair myself. Thanking you in advance. Kind Regards, F. Lonergan.
    Sergeant:
  • 174 Answers
F. lonergan,
The problem is not verry serious, the problem is in the vertical deflection cct. change elctrolytic
capacitors which is in the vertical supply.
Posted on Apr 08, 2011
Tv keep jumping at the top. the picture is green
This is likely a problem in a section called the vertical drive. A number of small parts need to be replaced. The green colour is due either to weak red an blue tubes or the green tube is over-driving. You might want to rethink spending any money fixing this...
Mar 30, 2010 | Mitsubishi VS-5047 50" Rear Projection...
My tv color is blue and red is my lamp out or what
no your optic block is going south u need a new light engine big bucks
Sep 20, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi Diamond Series T.V.
When a tv (Rear proyection) shows this coloration is the meanning that the red color is not there (the red color is generated by a red CRT). Now it can be really bad not having the tube working but before conclution make sure of this: (and if the red color gets back then the tube is ok)
  • is this condition the same in all inputs? or the picture looks ok with a different video source (VCR, DVD other)
  • are the menu letters same as the picture looks or are they fine?
If we cannot see any red color back with this testing, still chances that a technician find an electronic problem that make the tube to be off. so don't rush conclusions and get to the end to save the tv with out replacing the red tube, but if all was done and nothing then the tv needs the tube replacing.
Mar 03, 2009 | Mitsubishi Diamond WD-65831 65" Projection...
CANNOT USE MY TV UNLESS CABLE BOX OR DVD PLYER IS ON
Your TV sounds like its signal board has went out and will need replaced (This is the most common cause of the problems you describe!)
Please rate response and help keep this site FREE!
Jan 03, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS65909
This is a convergence problem and can be as simple as bad connections on the pins of the convergence ICs to defective ICs. If you can solder, try resoldering the pins on the ICs, If that fails to resolve the problem, replace the ICs. These are large black Ics attached to a heatsink and should be marked STKxxx. Depending upon the exact ones in your set, the cost should be between $15-$25 each (there are 2).
Keep us posted.
Dan
Jun 25, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi VS-60705 Large Screen Projection
thanks for your detailed description of what happened.
replacing the vertical output i.c will correct the problem.
the reason it failed was bad connections on it.
Apr 22, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi VS-60111 picture distorted
how do I manually switch my t.v. from 480i to 1080i on dtv with remote.
Dec 31, 2007 | Mitsubishi VS-70707 70" Rear Projection...
Vertical blanking
CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
Dec 06, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Mitsubishi 65 inch rear projection diamond
its the circut board that leads into tv from power cord , i had bought mitsubishi65819 black diamond gray 65inch for $54 ,is under the warranty the board cost $350 , labor $200 but this depends on where u live ,either way it was a steal for me ,but yea i had same problem when u turn tv on it shuts down like not even 2seconds i had tech come out and he had to take the board to get it repaired ,its not available he said but its repairable , was a sears tech so sears can repair it
Oct 29, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi 60 inch projection
They are not BULBS by any stretch of the imagination. They are CRTs (Cathode Ray Tubes, also known as "picture tubes," and each of them are small television screens, in essence), which are optically enlarged for projection onto the back of the front screen. Don't be tempted to think that you will merely be able to replace a "bulb" and have everything work!
Although you will be able to replace all of the components on the PC board if necessary (they all remain available), and may be able to fix the coolant leak that caused the failure, the CRT may have overheated. Considering the advanced age of the television, the tubes are likely already somewhat burned-in. Best to just dispose of the set.
Oct 01, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
