Question about Microsoft ChiMei CMV938D 19" Widescreen LCD Monitor
Gateway 900g Hi I have a Gateway 900g monitor that does not work. All was fine working until one day it just stopped working. It wont switch on or anything. I think it may be the power supply board but I cant seem to find one anywhere and I read that you fix them. If so then how much would that cost and how do I go about it. Regards Adrian
  • ciencia1585 Dec 03, 2008
    mi monitor no enciende no tiene vida tiene arreglo
  • Anonymous May 07, 2009
    how did you check your 12V and 5V suppliers?
    thanks
  • 14 Answers
I'm writing this using a recently repaired Gateway 900g. You may be correct about the power supply, as that was the problem on this unit. There was absolutely no response with this unit. No blue LED, no dim display. Nothing.
WARNING: BE SURE TO UNPLUG THE AC LINE CORD. THE POWER SUPPLY HAS DANGEROUS 120 VAC PRESENT IF LEFT PLUGGED IN. If you don't know what you're doing, it's best not to attempt a repair!!!
Disassembly is a bit tricky, and there's a variety of different sized screws used; so keep track as you go. First you remove the front bezel (be careful as the two control boards on the lower right need to be disconnected). There are two screws (lower left and lower right) that secure the shell, the rest of the frame is just a snap fit around the perimeter.
Then remove the 6 screws that hold the LCD frame to the rear plastic shell. Careful here as well, as you must disconnect the back light cables AND the signal cable to separate the LCD from the Power Supply / Signal Processing board.
The Power Supply board mates to the Signal Processing board thru a 2x5 pin header. This contains convenient points to check the +12V and +5V supplies. In my case the +12V was OK, but the +5V was reading about +2.5V...not good! THIS IS REALLY DANGEROUS TO CHECK AS THE 120VAC IS ONLY AN INCH AWAY.
Here was the key symptom on my unit. Your's may not be the same. If I disconnect the Power Supply from the Signal Processing board, then the +12V and +5V read correctly (as well as the +16V that goes to the Backlight Inverter section).
However, once I connect the Signal Processing board, the +5V drops to +2.5V. However, the Signal Processing board seems to run correctly off of an external supply drawing about 300mA.
On closer inspection of the Power Supply board, I notice that 4 capacitors had buldging tops (domed). This indicated some stress. These were capacitors C205, C206 (470uF/25V) in the +16V section; and C210 (470uF/25V) and C209 (220uF/25V) both in the +5V section. I didn't have a Capacitance Meter handy, so it was simpler to just replace all four parts with similar values. (There's a lot of latitude in making these substitutions.) But be sure you have voltages a *least* greated than those needed; i.e. 16V or 5V. They used 25V to have plenty of headroom.
After replacing the 4 Capacitors, the Voltages and Blue LED responded normally. After reconnecting to the LCD assembly, all was well. Reverse the disassembly process, and you are ready to go.
nateoceanside@hotmail.com
Posted on Aug 19, 2008
I had same problem. Replaced 5 capacitors and it works now
Posted on Sep 24, 2008
Gateway 19" lcd color monitor, product no. fpd1960 model no. 900g
The most common cause of power up issues with the Gateway FPD1960 monitor is a failure of the filter capacitors on the AIP-0100 power supply board in the unit. Here is a link to repair information for that board.
http://www.ccl-la.com/catalog/product_info.php?products_id=206
Nov 14, 2012 | Computers & Internet
I got a Gateway LCD 900G monitor, it keeps flickering and making hissing noises, what can i do?
Flickering could be a loose power connection but the hissing is indicative of a potential short. for your own safety, I'd get this to a TV type repairman asap.
Dec 25, 2010 | Gateway FPD1960 19" Flat Panel LCD Monitor
Gateway 900G does not stay on, has power
the_princes, On the rear side of LCD screen that you look at are two each long, straight, cold-cathode-fluorescent-tubes that need to "LIGHT-UP"and provide pure WHITE light to be reflected through the LCD glass panel that you look at from the front side! If you don't have any luck with Gateway providing warranty service or doing a swapout with them, then you should possibly look into having it Refurbished by someone locally in your area. I highly recommend that you go to youtube and watch some video clips of LCD MONITOR REPAIR to see exactly what you are getting involved with. When making a post to tthis site you should always give some "history" along with the trouble "symptom" such as how old is unit and approximate total amount of "ON" time the unit has. I hope you can use the info provided. I'm louie12fix on fixya or lmistyrel@aol.com Bye for now.
Oct 01, 2009 | Gateway FPD1960 19" Flat Panel LCD Monitor
Gateway 900g no power
Try a different working out to make sure its not a wall outlet issue.if you do that and your still not getting power then the monitor is bad and would need to be replaced.
Aug 18, 2009 | Gateway FPD1975W 19" LCD Monitor
Monitor will not stay on
please try another set of cables ...... borrow ... to eliminate those ....let me know
May 30, 2009 | Gateway FPD1975W 19" LCD Monitor
Gateway screen not responding
Try Pushing together the body of monitor in middle top areaWhere the Word gateway is Imprinted ,Loose connection on ribbion probably,on mine ,but I think I got LUCKY here honestly,
Just try it before disassembly
Apr 11, 2009 | Gateway FPD2275W LCD Monitor
No power/dead
try to turn it on the power switch on monitor.....and make sure all connection are ok
Mar 06, 2009 | BenQ FP731 - 17" LCD Monitor
Monitor doesnt work
You can check the fuse on the monitor and replace it. In case the fuse is OK check the cable connector, display card on the motherboard.
Thanks
Oct 17, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Gateway 19 in flat monitor Model 900G
Does the power button light up or blink at all ?
It probably is the power board/ inverter. I fix many of these.
To TeeKO, did you try moving it back to see if it was maybe a bad household receptical ?
ebaysbammbammfran
Jul 29, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
FPD1960 model #900G
Try running the factory reset on it.
Feb 23, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Computers & Internet Logo
2,998 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
