Question about Homelite Garden
I bought a slightly use Homelight gas blower ( backpacker 2 ? ut 08572) . I cranks for a split second on ether but not without it and won,t stay cranked. Gas may not be filing bulb when primed.
  • 97 Answers
SOURCE: leaf blower problems
You may have a dirty fuel filter, or carb needs cleaned.
Posted on Mar 19, 2009
jmgldsmth
  • 1889 Answers
SOURCE: mower starts w/ priming but stops after 1-2 seconds. Air filter, gas, oil, spark plug are new
Remove your fuel filter (in the tank usually) and, replace it
Posted on May 20, 2009
  • 279 Answers
SOURCE: the bulb primer is not sucking gas into it's
If you are not getting any fuel it should be either the filter plugged or the primer bulb leaking air. It could also be the fuel line. Give all of them a good look. ...Lee
Posted on Sep 14, 2009
mickey813
  • 472 Answers
SOURCE: Gas/oil ratio for a Homlite UT 08026H blower?
I USE SOME STUFF CALLED OPTI THAT WAY YOU ONE CAN FOR ALL YOUR 2 CYL STUFF ITS GOOD STUFF
Posted on Sep 30, 2009
kel1guy2002
  • 3740 Answers
SOURCE: I have a Toro model 20007 recycler with a 6.5HP Tecumseh engine
This almost sounds like a pinhole in the primer bulb but I need to know if you did the following. Did you remove the jet and venturi tube in the bottom of the carb. and clean the BRASS orifice hole and BRASS tube holes? If you did not then It will act just like the symptoms you described. Also check to see if your float bowl nut has holes in the side of it. IF it does then make sure the hole(s) are clean. Also make sure the fuel selector is all the way ON. Adittionally if the carb to block mating gasket is torn or not secure it will also perform as you stated.
Lastly the open the fuel air mixture screw on the side of the carb about 1/8th turn and see if the performance changes.
If the problem persists ....
This is dangerous due to the risk of fire but....
If you have any carb cleaner you can give it a quick shot in the nmating areas just after you start it before it gets hot to see if it speeds up. If it does, you have a vacuum leak. It is better to use an unlit propane torch if you have one.
Thanks for using FixYa,
Kelly
P.s. If the problem does persist I will need your complete engine number to proceed in troubleshooting.
Posted on May 21, 2010
Testimonial: "Thanks for the info. I ordered a rebuild kit for the carburetor so i can replace the gaskets. And i ordered a new primer bulb. The engine is a Tecumseh LV195EA-362003B 6.5 hp engine on a Toro model 20007 recycler mower. Do I need to remove the welch plugs?"
It cranks over but won't start. It sound like it wants to for a split second but doesnt.
My wife had the same problem and she was out of gas. Is that possible? You could spray some ether in the intake while someone is cranking the engine. If it starts good but then quits, suspect the fuel pump.
May 04, 2015 | Cars & Trucks
NEED PART # FOR PRIMER BULB ON HOMELITE BP30185
Thanks for providing the UT number.
When cross reference the carburetor part of up00651 it came as as Zama C1U-H36 which has a Zama 0057003 which is superceded to Zama 0057030
Mar 18, 2015 | Homelite Backpack Leaf Blower
My cub cadet 221 cranks won't start
Clean your carb, if you have not stored it correctly you have a dirty carb now. Carb could be gummed up.
Feb 17, 2013 | Cub Cadet Snow Blowers. 21 in....
Gas and oil mixed in 4 cycle backpack leaf blower
If it is a 4 cycle blower, you do not mix oil with the fuel....It takes straight Gas. there is an oil cap to put engine oil in crankcase, this only usually takes 2,3,4 oz. of oil. Sounds like your Spark Plug probably fouled out from having oil mixed in your gas. I would recomend changing your Spark Plug and put some Fresh GAS only in the blower, dump the old stuff out !!! You should be on your way Blowing in No Time !
Nov 27, 2011 | Troy-Bilt 32cc 4Cycle Backpack Blower
My echo backpack leaf blower pull start seems stuck it wont crank
Without getting to involved with it, did you always mix the correct fuel/oil ratio? or has someone else possibly put straight gas in it without oil? Another possibility is that the recoil could be broke. I would try to determine if the piston is seized in the cylinder. First remove the spark plug and try to pull the starter rope while listening closely for any strange noises from the engine. If it pulls fine then, replace the spark plug and try to start it again. If that doesn't work then I would remove the back cover and remove the muffler so you can look at the cylinder. You will need a phillips screwdriver and a set of metric allen wrenches. Hope that helps.
Aug 30, 2011 | Echo Pb - 413t Backpack Blower
I have a Homelite BackPacker leaf blower. It runs fine until the gas tank is about half empty. Then it sputters. While it's running, I can remove gas cap and replace and it runs fine again for a little...
Great job with the description of the symptoms. What you are describing is a classic case of vapor-lock. In other words, a vacuum is forming in the fuel tank and not allowing the fuel to flow to the carburetor.
Look at the cap, it probably has a small vent built into it. With a little compressed air, blowing from the outside in, try to clear the obstruction. This may not work, but don't worry. Just replace the fuel cap. Your local lawnmower repair shop can probably get a new cap for you. Otherwise, go to www.homelite.com click on the parts tab, enter your model number (starts with a "UT") and order a new one.
Oct 29, 2010 | Homelite Consumer Products Backpack...
RYOBI BACKPACK CRANKS BUT SHUTS OFF AFTER RUNNING ABOUT 10 MINUTES
Make sure you running gas/oil mix in it and you dont have too much oil. It may also need a carb cleaning/adjustment
Nov 10, 2009 | Ryobi Backpack Blower 25.4cc
Wont start, carb is clean will start with ether
It sounds like you have a clog somewhere. Fuel filter in the tank may need to be replaced. The diaphragms in the carburetor may not be as flexible and need replacing. You may have a hole in a fuel line not allowing gas to flow or introducing air to the system. Good Day.
Oct 05, 2009 | Echo Pb - 413t Backpack Blower
Garden Logo
41 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
