Question about Robinair Cool Tech 34700Z Recovery, Recycling, Recharging
We have a robinair cooltech 34700z, looking for directions to change pump oil, can anyone help? thanks
    President:
  • 180 Answers
For change vacuum pump oil follow the bellow step: Press main menu then keep pressing up or down arrow key till display show "CHANGE VACUUM OIL" then press "YES" key. Now vacuum pump will run for two minute & stop automatically. When pump stop you just open the oil drain cap and drain all used oil from pump (oil drain cap located outside of the machine near high & low side hose). After draining all used oil replace oil drain cap and fill 5 ounce new ROBINAIR vacuum pump oil then press "YES" key and keep filling oil up to middle of sight glass of vacuum pump. Press "STOP" key to complete the process.
NOTE: Do not over fill the pump & do not use any COMPRESSOR oil on the vacuum pump!
Hope this will help you & if it is please vote for my support
Hope this will help you. If so please vote for it. Good luck
Posted on May 06, 2011
Robinair Cool-Tech 34700z sending refrigerant to oil recovery container when charging system.
You confirm it by how it functions, if it sticks in a mechanical way there is no electrical testing that would be valid. I would just replace both solenoids.
Oct 13, 2016 | Robinair Cool Tech 34700Z Recovery,...
How to drain the isv in ac34700z
To clean contaminated ISV of Robinair 34700Z, open front lower panel, then slowly disconnect 3 hoses from ISV (Liquid, Air purge and Vapor). Now unscrew ISV tank from machine and then fixed an adapter to Liquid port of the tank to allow all the contaminated refrigerant to go out from tank. after emptying the tank, if possible make vacuum for approx. 10 minute with an external vacuum pump. Replace everything its original location after completing vacuum. Now change spin-on filter (Located on the back side of the machine) and vacuum pump oil. Your machine is now ready to work.
Thanks and I hope this will help you to solve your problems.
Jun 24, 2014 | Robinair Cool Tech 34700Z Recovery,...
HELLO I HAVE A ROBINAIR 34788, MY UNIT WILL NOT CLEAR THE LINES. I TRIED SHUTTING OFF AND ON , BUT LINES ARE STILL HOLDING PRESSURE. I ALSO CANT RECOVER BECAUSE IT WILL NOT GET PAST CLEARING. THANK YOU
sounds like you need to check the grommet between the motor and the pump. If this grommet connector breaks, the motor will come on but the pump will not work. Turn the unit upside down and look where the motor connects to the pump. Be aware if you can lose your oil while turning upside down unless you cap the port and exhaust. If this is it, go straight to the Robinair web site and you can order one for around $25.
May 11, 2011 | Robinair CoolTech 6 CFM Two Stage Vacuum...
The high pressure unit is disabled in my Robinair Cooltech 34700z wat could be the problem?
This is a common problrm of Robinair 34700Z / 347002k & 347112k series machine.so don't worry just do the following :- 1# Verify the ISV tank is not overfilled.if full,remove refrigerant manually from tank. 2# Verify if there is high pressure in the tank.Purge excess air from the tank manually.( Open air purge hose from the tank,then press tank valve as needed) 3#Check the high pressure switch for proper operation,if not then replace high pressure switch.Hope this will solve your problem, if so please vot for it
Jan 04, 2011 | Robinair Cool Tech 34700Z Recovery,...
I have a robinair 34700zasking me if i wanna change the oil nowhow do i do that and what type of oil i need to use?....ty
You have run the machine 10+ hours for vacuum since last oil change. so you have to change vacuum pump oil. For change vacuum pump oil just follow the bellow step: Press main menu then keep pressing up or down arrow key till display show "CHANGE VACUUM OIL'' then press "YES" key. Now vacuum pmp will run for two minute & stop automaticly. When pump stop you just open the oil drain plug & oil fill cap of vacuum pump ( Located oute side of the machine near high & low side hose ) & drain all oil from vacuum pump. After draining used oil,replace oil drain plug & fill new ROBINAIR vacuum pump oil till middel of sight glass.Press "YES" key & follow on screen messeage. NOTE: Do not over fill the pump & Do not use any COMPRESSOR oil on the vacuum pump!
Hope this will help you & if it is please vote for my support.
Jul 05, 2010 | Robinair Cool Tech 34700Z Recovery,...
ROBINAIR 347002K WON'T INJECT OIL
I think you'v try to inject the oil from ''WRONG'' side,as you say RECOVER/VACUUM which is LOW side manifold valve. You should inject the oil from HIGH side ( Turn the high side valve to CHARGE/OIL INJECT after vacuuming & low side vulv to CLOSE possition ) with pressing F1 key. once you press it then hold the key as long as you wish to inject the oil. If you try this way & you still have problem with oil injection then you may need to check oil injection CHECK VALVE or oil injection SOLENOID ( Both located under Hidg side panel mountin valve). NOTE: UV Dye is not a problem for oil injection! I hope this will help you to solve the problem,Good luck. Don't forge to vote for my solution!
Jul 10, 2010 | Robinair Cool Tech 34700Z Recovery,...
Have dye in vacuum pump oil on cooltech 34700z also a buzzing noise
You have to change vacuum pump oil.By pressing "change vacuum pump oil" follow the on scree messege & compleat process. NOTE:please do not skip any option during oil change & do not over fille the pump.
Oct 19, 2009 | Robinair Cool Tech 34700Z Recovery,...
Robinair  Cool Tech 34700Z Recovery, Recycling, Recharging Logo
479 people viewed this question
Top Robinair Measuring Tools & Sensors Experts
Mike
Jay Finke
Jay Finke
Are you a Robinair Measuring Tool and Sensor Expert? Answer questions, earn points and help others
