When i switch on my printer all the lights blink and nothing moving on my computer it shows service required
    Sergeant:
  • 174 Answers
Before you get it done from authorised service centre, you can try yourself.
if the printer is inkjet then you apply some lubricant to all moving parts so that the initializing
process will do smoothly
Posted on Apr 08, 2011
All leds of my deskjet 735 start blinking as soon as power is connected
Regarding to the hp site, the symptom you describe is a " fatal error". In this case you need to send it to an service center.
May 17, 2017 | PRINTER Office Equipment & Supplies
DESKJET 710C PRINTER IS NOT TAKING PAGE/PAGES AND LIGHT IS BLINKING
your printer require serviceing if you can do it that is good .just apply any lubricant oil on steell rod inside the prinetr just open the cover printer catriges will be come to centre remove the power cord and apply oil on the rod and move the print head then close the cover and switch on the printer and see the results.
Nov 13, 2009 | HP DeskJet 710c InkJet Printer
Epson R1800 paper and ink lights are blinking
See status monitor? Is service required? Reset waste ink, Find resetter at indoreset.blogspot.com
Jun 09, 2009 | Epson Stylus Photo R1800 InkJet Printer
Blinking teardrop light blinking
Blinking drop light on HP6122 signifies an ink cartridge is out of ink. There are two cartridges -- color (larger of two) and black (smaller of two). Blinking drop light only indicates either, but not which. HP6122 service software and print driver are available from HP website http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=83027&lc=en&cc=us&dlc=en&lang=en&cc=us. HP6122 service software has a printer maintenance utility which includes ink cartridge monitor. Use the maitenance service utility to determine which (or both) cartridge is out of ink. With cartridge replacement, printer should automatically print test page, then reset and be ready for printing from your computer. To clear printed documents from print que, open the HP6122 print que via control panel > printers > double-click on HP6122 driver to show que > select document tab > select cancel.
Mar 26, 2009 | HP DeskJet 6122 InkJet Printer
Printer showing error
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and use it to reset the Protection Counter. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. This is quite straightforward once you know what to do.
If you decide to have a go at replacing the ink pads yourself, post a new comment, and I will provide further help.
Dec 08, 2008 | Epson Stylus C40UX InkJet Printer
Microline 420
When the alarm light is blinking what other lights are on. This is the fatal error code with the printer.
Remove the ribbon. if still not moving smoothly unit needs service. 3 year warranty on this unit brand new.
If you cannot move the carriage back and fourth accross,
there is a seriuois issue. unit requires service.
Jan 29, 2008 | OKI MICROLINE 520 Matrix Printer
The printer apear to be dead!
Buttons and lights on the printer Two buttons and three lights are located on the front of an HP Deskjet printer.
  • The lights tell when the printer is working or when it needs attention.
  • The buttons help control the printer.
Buttons and lights Purpose c00123886.jpg POWER button and light Push the POWER button to turn the printer off and on. When lit, the light shows that the printer is turned on. c00123889.jpg RESUME button and light The light blinks when there is a problem with paper. When the problem is corrected, press the button. c00123892.jpg Print cartridge light The light blinks when there is a problem with a print cartridge. When the problem is corrected and the top cover is closed, the light will stop blinking. Troubleshooting blinking printer lights Blinking lights Reason c00123895.jpg
All lights are off. The printer is off (asleep).
Press the POWER buttonc00123886.jpg to turn the printer on.
The printer should turn on automatically when a print job is sent to it. c00123898.jpg
The POWER (top) light is on. The printer is idle.
The POWER (top) light is blinking. The printer is busy printing.
Allow enough time to print. When a document has many fonts or graphics or uses complex color such as a color photo, it takes longer to begin printing. c00123902.jpg
The PRINT CARTRIDGE (bottom) light is blinking. Possible causes:
  • The front cover is open. Make sure the front cover is completely closed.
  • The print cartridge is missing. Make sure the print cartridge has been installed correctly.
  • The print cartridge is broken or incompatible. Lift the front cover, and wait for the print-cartridge cradle to slide out. Check the part numbers on the print cartridge:
Black: 51645A
Color: C1823D,
If the print cartridges are compatible and correctly installed, they may be defective. Try replacing the print cartridges.
If none of the above suggestions fix the problem, and, if the error message still occurs, it may be a hardware failure. Call the HP Customer Support Center.
Jan 20, 2008 | HP DeskJet 710c InkJet Printer
Epson 1280 Printer breakdown
it is the wasted ink pad, they are full.
to have your printer work again
turn off the printer.
press and hold the ink and paper button while turning on the printer, wait for 5 seconds then release the button and press the paper button for at least 10 sec.
if done correctly , you will see the carriage start moving
Jan 20, 2008 | Epson Stylus Photo 1280 InkJet Printer
HELP!
hi, the blinking is caused by a fault in the printer, means it needs to be serviced, its usually more expensive for them to fix it than buying a new one, but you can get there number off the canon website.
Happy New Year
John
Dec 28, 2007 | Canon BJC S300 InkJet Printer
jasbo
jasbo
