Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
I need the chain oiler cap for my old husq. 50 which is probably about 20 years old. 7101331.
  • Husqvarna Master
  • 2,239 Answers
The part no. is 501765602, readily available from any Husqvarna dealer, as i guess your not in the UK i cannot suggest any local dealers.
Good hunting.
Posted on Apr 08, 2011
REPLACE CHAIN BAR STUDS 55 RANCHER
Tom, Check the attached links,instruction and guides on Husqvarna chainsaw, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Husqvarna rancher 55 chain bolt replacement
http://www.husqvarna.com/ddoc/HUSO/HUSO2002_USen/HUSO2002_USen__1140106-95.pdf
How to Change Chain on Husqvarna Chainsaw Model 445
How to Adjust the Oiler on Husqvarna 55 Rancher
Apr 02, 2016 | Husqvarna 36 41 50 51 55 136 141 154 254...
Can the chain oiler be adjusted on a 141?
No adjustment possible.
But that can be good news when you got good oil as you can run a longer bar and chain up to 20" The shorter the bar the more oil present on the chain and bar during operation
Jan 08, 2015 | Husqvarna 36 41 50 51 55 136 141 154 254...
Poulan Pro Chain Saw 46cc 20
Yes, mine does that, too. It's seepage that gets past the oiler mechanism by gravity; not because anything is broken. The easy way to stop it is to store the saw so the gas and oil fill caps are facing down. No more seepage! Of course, you need to ensure that the fill caps are snug.
Jan 15, 2012 | Poulan Pro Chain Saw 46cc 20"
What kind of oil do I put into my toro expand it chainsaw?
CHAIN OILER See Figure 18. ? Use Premium Bar and Chain Lubricant. It is designed for chains and chain oilers and is formulated to perform over a wide temperature range with no dilution required. ? Remove the cap and carefully pour bar and chain lubricant into the chain oiler tank. ? Replace the cap and tighten securely. ? Check and refill the chain oiler tank every hour when using an electric power head or every time the engine is fueled when using a gas power head. NOTE: Do not use dirty, used, or otherwise contaminated lubricants. Damage may occur to the oil pump, bar, or chain.
Sep 01, 2011 | Toro Garden
I need to know the oil gas ratio, and about chain
Hi ccollins529...
Normally a 50 to 1 mixture is fine...1 pint 2 cycle oil to 6 gallons of gasoline.
Use "bar and chain" oil on the bar, this is an oil blended for the chain and bar.
If yours has an auto oiler you will put the oil in the bar/chain oil container.
If you do not have an auto oiler,use a hand oiler to lube the chain when needed.
Please take time to rate me
Aug 28, 2011 | Garden
Bar oil leaking constantly. How do I fix it?
These saws are of the self oiling type there is no tip or bottle it consists of a tank and a channel the oil flows thru and on to the bar by gravity. There is a type of bar oil system on some saws that come with a button you push which In turn pumps oil onto the bar. But the poulan is not one of them. I have a 15 year old farm hand 20" bar and a two year old poulan wild thing 18" and both leave there oil in the case when sitting I beleive the fix would be drain it after use and clean up.
Mar 21, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
New chain installed, cut for 1/2 hour, chain now sags well below
Place a piece of white paper on the ground
Start your saw and point the tip of the bar at the paper, this will allow you to see if it is oiling or not
I am assuming that we are dealing with a newer saw and not an old manual oiler
Blowing air back through the oil ports in to the oil tank ( with the cap removed and oil tank drained) should help clean out whatever is plugging it.
Once cleared run a bit of diesel through the oil tank, drain it and refill with clean fresh oil
I never use old oil in my saws for just this reason
Hope this helps
Scott
Mar 17, 2010 | Husqvarna Chain Saw 20" Bar
The chain and bar is not getting oil , what can I do to fix?
You can find an IPL (exploded parts list) with your oil system detail here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Oil System Plugged.
Remove the clutch cover, bar and chain. Clean the oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw.
If no a blunted, hooked piece of wire can be used to pull the hose in the oil tank out. I recommend the filter be replaced. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is probably left handed thread). Please make extensive notes & some digital pictures will help during reassembly. GL
Lou
Oct 05, 2009 | Husqvarna Chain Saw 20" Bar
My chain is not getting oiled when I use the saw.
Sounds like the oiler is clooged where the oil comes out on the chain. Probablly has sawdust in it. Remove the chain guidebar and clean the oiler.
Apr 28, 2009 | Garden
Chain oiler
Depends on the vintage, turn the saw upside down and you can see a screw to turn, 3 settings, right under the clutch and shaft. use a screw driver if it is adjustable. I like to keep mine set on high, oil is cheaper that new chains and bars. Use a bar oil, not old used motor oil.
Nov 01, 2008 | Husqvarna Chain Saw 20" Bar
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
