Question about Ovens
Got a zenith 60 cooker, the clock and main oven has stopped working, the rings and top oven work
  • 65 Answers
SOURCE: electric surge turned off the clock,oven but the stove top works
do you have both legs of the 220v? on the board see if you have 120v at L1 and L2. if you do then you have a bad board.
Posted on Feb 19, 2008
SOURCE: the clock & oven on my cannon chichester cooker dosent work
Hi anyone , my chichester ignition button has stopped working - is there a battery located somewhere
Posted on Mar 10, 2008
SOURCE: clock on cooker flashing
Excellent! Now my clock works, but where can I get an instruction booklet for this oven? Thanks.
Posted on Jun 10, 2009
SOURCE: Fisher and Paykel electric cooker (Pepper)
No, it's the first 2 buttons on the left pushed together as well as the + or - to set the right time
Posted on Jul 16, 2009
SOURCE: frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work
my frigidaire oven will not light. The broiler works and the oven ingiter lights up, but the oven will not ingite. The electronic display does work.
Posted on Aug 12, 2010
Replaced EOU43002X element, clock/timer now dead
Make sure there is power to the timer. Should be a fuse somewhere.
Mar 19, 2014 | Electrolux Ovens
Twin ovens stopped working
Hi, Have you altered the time clock on the cooker? It is possible that the clock/timer is set for 'Auto'
Dec 26, 2013 | Caple Ovens
Lower oven loss of power
I'd check the control switch first, and the wireing and connections.
Sep 05, 2012 | Ovens
I had a power cut and it only lasted 8 mins my cooker works top oven works but the main oven doesnt how do i work it as the fan and light works but oven do not thank you
If you have had a power failure, you may find that the clock has reset. If the clock has an auto setting this will be linked to the main oven only and therefore the clock will need to set to manual for the oven to work. The alternative is that the oven element has blown and this is what tripped your power, in which case you will need to replace the element. Hopefully, the first scenario is correct and will be a lot cheaper.
All the best, pls leave feedback or reply for further assistance with make and model number.
Aug 20, 2010 | Ovens
My90 duel fuel range master cooker : The two fan ovens and the clock have stopped working but the grill and all hobs are fine !! any solution??
the ovens work through the clock auto contacts if the clock not working then the ovens wont. may need a new clock or you can bypass the timer relay contacts if your clever. one of the oven elements may have blown to earth this is the main reason for a clock failing
Aug 04, 2010 | Ovens
The bottom oven on my zanussi zuq 875 has stopped working. No power indications of any kind.Top oven works fine. Followed instructions in manual but no power at all.ie; indicator lights, fan ,oven light....
Have you checked that the timer clock is set and not flashing,because the rest of the cooker will work after power outage but for the main/fan oven to work the clock needs resetting.
Hope this helps.
Jun 13, 2010 | Zanussi Ovens
Fan oven stopped heating
Is the fan working in the oven if not then check if the clock needs resetting.If the fan is working then it is more likely that the ring element around the fan has failed.Check also if the thermostat light comes on,this is an indication it may be ok.
Hope this helps.
May 25, 2010 | Ovens
No gas to lower oven - Cannon Camberley
Hey Stephen - try setting the clock then set the cook period. the oven will only work when that's on i think.
May 07, 2009 | Ovens
Clock on cooker flashing
Just to let you know that i have solved the problem with my cooker, (clock flashing after electric going off) i held down the cook period button and the end time button, then i was able to reset the clock by pressing the +button.
Apr 28, 2009 | Hotpoint UY46 Style Line Stainless Steel...
My oven has completely stopped working
hi there as long as your supply to the cooker is ok the problem can only be one of two things the mains terminal block burnt out or the overheat cutout has blown at the back of the cooker
Nov 30, 2007 | Hotpoint UY46 Style Line Stainless Steel...
Ovens Logo
74 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
