Epson Perfection  V100 Flatbed Scanner
Problem for Epson Perfection V100 Flatbed Scanner
Recognizing hardware on a Mac OS X Tiger
By FOneGospel on Aug 06, 2008
I have recently downloaded the software for this printer and when I go to the Photo Impression option to "get a photo" no option for receiving the picture via scanner shows up. The USB cable and power cord are properly connected.
Solution #1
posted on Aug 22, 2008
Not Rated)
MadBindus
Rank: Guru  Epson Expert
Rating: 88%, 134 votes
Try just using the epson scan utility
1. Launch Epson Scan by going into your HARD DRIVE, APPLICATIONS, and EPSON SCAN.
2. If prompted, select your scanner from the list of models and click OK.
3. In the FILE SAVE SETTINGS window, you can designate the location, name and type of file the scans will be saved as.
-LOCATION defaults to HD/USERS/(YOUR USER NAME)/PICTURES. Click CHOOSE if you wish to change this.
-PREFIX determines how the scan will be named. Type any name you like. You can also designate a start number.
-FILE TYPE dictates what format the scans will be saved in. ie. .JPG, .TIFF, .PDF, or .PICT)
-For example: if the prefix is "img", the start number is "1", and the format is "JPG", the name of the file saved in
PICTURES will be "IMG001.JPG"
4. Click OK once settings are changed as desired.
5. The EPSON SCAN window will open and begin scanning in FULL AUTO MODE. In FULL AUTO MODE the software makes all the decisions for you (as to what is being scanned, where it is on the flatbed, etc). This is the easiest way to scan.
6. If you want full control over the scanning process click PAUSE and change FULL AUTO MODE to HOME MODE or PROFESSIONAL MODE. In the latter two modes you can change your scan settings as desired. Click SCAN after you have selected your settings. Click CLOSE once the EPSON SCAN is finished scanning.
7. When scanning is complete, your images will be saved in the location specified on FILE SAVE SETTINGS, with the prefix and in the format you set.
Was this helpful?
Yes
No
Popular Solutions for Epson Perfection V100 Flatbed
Questions and Unsolved Problems for Epson Perfection V100 Flatbed
Do you recommend Epson Perfection V100 Flatbed Scanner?
Answer
Answer
how to scan a document into pdf using epson perfection v100 scanner? i push the pdf button, nothing... (More)
Answer
After the Espon V100 scans the photo it says: Unable to write the file. Help! :)
Answer
I am getting banding down each page (wide vertical streaks).
Answer
There are some fungus in side of my scanner glass. It is visible scanned pictures. How can I clean... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Scanner Experts
Top Printer Repairmen
in , OH
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
