I have a Defy laundromaid Electrologic 920 and while I was washing the drum stop turning and the hole room smell like something is burning. What can it be and how much will the part cost me
My laundromaid electro logic 920 is making unususl noise when rinsing!!
tshepoflo06@yahoo.com
Posted on Apr 10, 2011
Defy Laundromaid Electrologic 1300 wiring diagram
Contact Defy directly and request the wiring diagram.
Feb 26, 2018 | Washing Machines
Hi, my defy laundromaid electrologic 920 washing machine had a power overload of 430 volts instead of 220 volts and now it won’t switch on. Can anyone please tell me what the problem is and what I should...
i've never worked on one of these machines but i can tell you whenever there's a power outage and then when the power comes back on the surge can take out the electronics so if you had almost double the power going into that machine i'd have to say it's fried and most likely burnt out the computer board or more.if you want to talk to someone else write back but send the full model number off of the washer and maybe someone who knows this machine can help you but the only way to tell is by checking it out with a meter and see what got damaged from the power surge but double the voltage,that's not gonna be good,hopefully there's a fuse or something in there that could be popped but check it with a meter to see.
Feb 05, 2018 | Washing Machines
I have a Defy electrologic laundromaid 1300 washing machine that the cold water runs in even when the machine is switched off.
Your solenoid operated valve is stuck open on the cold side. To find this valve, follow the cold water inlet hose and it will lead you directly to it.
Feb 01, 2017 | Washing Machines
Defy laundromaid electrologic 920 drum wont turn
Something caught between inner & outer bowl. Nail or screw caught in inner bowl. Main bearing seized, replace seal & bearing(s).
Dec 18, 2013 | Washing Machines
I have defy laundromaid electrologic 720, it does not stop draining the water?
My Defy electrologic 720 goes into washing mode ,but not filling up with water.
Dec 05, 2013 | Washing Machines
My defy laundromaid electrologic 1300 suddenly stops spinning and gives a ue error
I had the same problem: E9 error when switching the machine on. This indicates something is wrong with the pressure switch. (or connection to the pressure switch). When you open the top cover at the back of the machine it will be in the right hand corner (when looking from the back of the machine). This is a round device with a clear tube coming in at its bottom and a three wire connecting plug at its side. When unplugging I found one of the pins corroded (green tarnish). After cleaning it off with some steel wool the problem became intermittent - indicating the connection is not too sound. Just bending the pin slightly did the trick causing it to soundly make contact inside the plug. Problem solved!!
Aug 03, 2012 | Washing Machines
I have a defy electrologic 920 washing machine and the drum will not turn
perhaps you have stumbled onto the defy feature? Classic problem.
Mar 20, 2011 | Washing Machines
Washing Machines Logo
262 people viewed this question
Top Washing Machines Experts
