Question about Whirlpool Washing Machines
Knocks when spins - Whirlpool Washing Machines
  • Whirlpool Master
  • 17,130 Answers
Possible that the drum is moving eccentric and so goes out of position to knock on the sides.
Now please check that the mounting of the spindle are not wobbling. Check the bearings, check the assembly for wearing. Also the suspension and dampers to the drum must be in order as they need to counter the motion of the drum with load.
Make sure the washer is firm on the ground and does not move around.
Posted on Apr 08, 2011
Washing machine knocking on spin cycle
Unbalanced washing causes that. If it worries you, open the door and redistribute the wet washing.
Oct 21, 2017 | Washing Machines
Knocking noise coming from the alternator
Your bike actually has a generator. The only way to knock in the generator is bad bearings. The knock could also be a bad connecting rod bearing or crankshaft bearing. tombones49_124.gif
Apr 29, 2011 | 1994 Yamaha YZF 750 R
Kenmore front load washing machines knocks
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 25, 2010 | Kenmore HE2 Plus Front Load Washer
Knocking/thumping noise in rear end while breaking
I HAVE THE SAME PROBLEM I'VE BEEN DOING A LOT OF RESEARCH ON IT AND I THINK ITS GONNA BE THE BUSHINGS IN THE REAR KNUCKLE ASSEMBLY AND YOUR HAVE TO CHANGE THE WHOLE ASSEMBLY. I HAVEN'T TRIED IT YET BUT IF YOU CHECK BACK IN A COUPLE DAYS I WILL LET YOU KNOW
Jul 03, 2009 | 2002 Pontiac Aztek
Knocking sound in the spin cycle off balance.
The motor switch that is mounted on the motor may need replacing. The knocking could mean that the "run" winding is cutting off momentarily, and running on the "start" winding of the motor. I dont know about a 22 year old model, but in most "near modern" machines, the switch has a plastic actuator that is pushed when the motor obtains near-run speed, that plastic may be worn or the actuator part on the motor may be at fault. If you replace the motor, you usually get this switch as part of the deal.
Feb 05, 2009 | Maytag Washing Machines
Machine knocks and walks when spinning a small load
amke sure it is level and on a solid floor with little bounce.
Jan 23, 2009 | Admiral AAV7000A
Knocking while spinning
something is loose or broke you need to remove the bottom panel and top panel and see what is hitting may be a strut
Nov 29, 2008 | Whirlpool Washing Machines
Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Knocking sounds
Ususally knocking is a sign that the rubber belt which spins the dryer tub is old and has hardened. If the knocking sound gets quieter after you have run the dryer for 30 minutes or so, then the belt is the problem. As the dryer turns, it heats up the rubber belt and makes the belt more pliable. This quiets the knock. I have seen dryers work fine for years, knocking the whole time. Have the belt replaced if the sound bothers you.
Sep 07, 2007 | Maytag Atlantis MDG6400AW Gas Dryer
Washing Machines Logo
47 people viewed this question
Dan Webster
Dan Webster
Sal De
