Question about Mtd 22" Yard Machine Push Mower
Where is the oil plug on a yardman yardbug model 13B325401 and how do you change oil in this model?
Where is the oil drain plug located on model 407577
Should be a plug on right side engine almost bottom of engine.
Apr 22, 2016 | Yard Man Yardman Riding Lawn Mower 38in...
How to change oil
If is like mine remove the oil filler cap and tip it up over a drain pan some of the older models have a drain plug on the bottom of the motor that takes a square 3/8 extension on a ratchet to remove over a drain pan
Apr 05, 2014 | Yard Man YardMan 11A41K3001 21Inch 173cc...
I have a MTD yardman yardbug riding lawn mower. Its a 8.5 hp engine. Model: 13b-325-401 year:2000. It will not start, I turn the key and it sounds like its trying to start, but the belts underneath the...
check that you can turn the cutters by hand . I suspect that the bearings for the cutters may have seized up from the wet grass causing them to rust up
Jun 02, 2013 | Garden
How to change the oil in my MTD 6.5h Honda yardman
Many mower engines no longer have a drain plug, or the plug is covered by the deck or other components, the best way is to suck the oil out via the oil filler, there are plenty of inexpensive vacume pumps availble that makes the job easy, check out the dealers or e bay.
Mar 14, 2013 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Owners Manual for Yard Bug ridingmower
Sorry we don't have owners manuals for this type of equipment. I suggest you contact the maker of the mower.
Mar 17, 2012 | Cars & Trucks
The blade belt on my yardman yardbug smokes or burning whichever the case may be,why is this?
Either the blades are not moving due to a tight shaft under the mower deck, or a simpler malfunction, hopefully the belt just needs tightened by adjusting the pulleys.
Aug 13, 2010 | Garden
Mtd 22" Yard Machine Push Mower Logo
213 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
