No sounds,there's a sound but a warning sounds only
    Genius:
  • 1,157 Answers
Hi bagunasjuly,
May I have the brand, type and model name of your system?
Thank you for using FixYa.
Posted on Apr 10, 2011
When I start the car there is a 15 second warning sound which is replicated just after the engine is turned off and the key removed.It drives fine and no warning lights appear.
There are several thing that cause the warning sound. Try cycling the headlight switch often the sound indicator id the headlight warning sound that the lights are left on. You can also call the dealership and see if there has been a recall for this problem.
Oct 22, 2015 | 2007 Chevrolet Lacetti 1.4
No more buzzer warning sounds
Cocking time ? Cocking what ?
Dec 01, 2017 | Cars & Trucks
ABS light on with warning sound and brakes heavy. Brake pads are new
It sounds like the master cylinder may have failed, check for brake fluid leaks at wheels also vacuum line to the brake booster
Apr 27, 2014 | Mitsubishi Montero Cars & Trucks
My Midland WR100 weather radio is set for any S.A.M.E. code. I live in Oklahoma. We have tornado warnings and severe thunderstorm warnings, and my radio has not sounded. If i press the weather/snooze...
I have been used this Midland weather radio with S.A.M.E alert for last 2 years. My device works perfectly. My radio has sounded whether any tornado warnings and severe thunderstorm warnings. After reading your post you have to face some problems with your device, that during tornado warnings and severe thunderstorm warnings your radio not sounded. If you follow some steps then your issue will be resolved. Carefully review the manual. Or, it is possible that the NWS did not issue a warning for the storm. Warnings are issued for thunderstorms. If a storm is not expected to produce severe weather, a warning with an alert is not issued.
Best Weather Radio Reviews Be Prepared For Natural Emergency
Dec 13, 2017 | Midland WR-100 Weather/RDS Radio
Warning bell won't stop sounding
Section 13-09: Gauges, Warning Devices — Chime System 1996 Windstar Workshop Manual
DESCRIPTION AND OPERATION Warning Chime Systems Three distinct sounds are used to indicate the area of concern. Seat belt warning generates 1 chime per second
key-in-ignition generates 2 chimes per second
headlight on generates 4 chimes per second.
Key-In-Ignition Warning The key-in-ignition warning will sound when the driver's front door (20125) is opened with the key in the ignition switch. It will continue to sound until the key is removed, the front door is closed, the ignition switch is turned to START or the vehicle speed is over 24 kmh (15 mph).
Safety Belt Warning When the ignition switch is turned to RUN or START from OFF or ACC, the chime will sound for six seconds or until the safety belt is buckled.
  • The safety belt warning indicator lamp (10C859) will activate for 60 seconds or until the driver's safety belt is fastened. Both the chime and lamp activate at the same time.
Anytime the ignition switch is released from START and returns to RUN while the safety belt lamp or chime is activated, the safety belt warning lamp or chime will remain activated until either the timing sequence has been executed, or the safety belt is buckled.
Headlamp Switch On Warning The chime will be activated if the headlamps or parking lamps are ON, the key is not in the ignition and the driver's door is opened. The chime will sound at a rate of four per second.
Apr 23, 2009 | 1996 Ford Windstar
Key on engine running trouble code 55
Warning Chime Systems The generic electronic module (GEM) will sound the following warnings:
  • key-in-ignition warning
  • safety belt warning
  • headlamp switch ON warning
  • door ajar warning
Headlamp Switch On Warning The generic electronic module (GEM) sounds when the driver door is opened while the headlamp switch (11654) is in the PARK or HEAD position, and continues to sound at a rate of 4 chimes per second until the headlamp switch is turned off or the driver door is closed.
  • When the headlamp switch is in the PARK or HEAD position, power is supplied through Circuit 293 (O/R) to the GEM.
  • When the driver door is open, the driver door open warning lamp switch (10B997)is closed and ground is supplied to the generic electronic module (GEM).
A delayed headlamps on repetitive chime will sound for a period of three seconds beginning twenty seconds after the key is turned to OFF, LOCK or ACC, the headlamp switch is in the PARK or HEAD position, and the driver door is closed. Delayed headlamps on is terminated by opening and closing the driver door again.
Door/Liftgate Ajar Warning The door/liftgate ajar warning functions as follows:
  • The generic electronic module (GEM) sounds a warning tone for one second when any vehicle door, liftgate window or the liftgate is ajar without any other door already open and the ignition switch is in the RUN position.
  • Power is then supplied through Circuit 627 (BK/O) to the door ajar warning indicator lamp which remains illuminated until all doors are closed or the ignition switch is no longer in the RUN position.
Key-in-Ignition Warning The generic electronic module (GEM) sounds when the LH front door is opened with the key in the ignition switch and continues to sound until the key is removed or the door is closed.
  • When the key is in the ignition switch, the ignition key warning switch terminal and wire (11A128) is closed and ground is supplied through Circuit 158 (BK/PK) to the generic electronic module (GEM).
  • When the LH front door is open, the LH front door open warning lamp switch (10B997) closes and ground is supplied through Circuit 57 (BK) to the generic electronic module (GEM).
Safety Belt Warning When the ignition switch is turned to RUN or START from the OFF or ACC position and remains in RUN or START, the chime will sound for six seconds or until the safety belt is buckled. The safety belt warning indicator lamp (10C859) will turn on for 60 seconds, or until the LH front safety belt is fastened. Both the chime and lamp activate at the same time. If the safety belt is buckled when the ignition key is turned to RUN or START from OFF or ACC, the lamp will prove out for two seconds, but chime will not be activated. Any time the key is changed to RUN from START while the safety belt warning indicator is activated, the safety belt warning indicator will remain activated until either the timing sequence has been executed, or the safety belt is buckled.
Feb 25, 2009 | 1999 Ford Taurus
Alarm for speed cameras or red light camers on my tom tom one
1 Change Preference
2 Warn When Near POI
3 Choose Your Red Light Camera POI
4. Set how many yards from it you want to be warned.
5.Choose Sound
Done
Good Luck
Dec 04, 2008 | Tomtom ONE 3rd Edition GPS
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
