Question about Patton Electric U2-20 Box Fan
I have a CS104-2OU4-005CSA floor fan
The relay is toast, where can I get hold of one?
  • 5,568 Answers
Since this is probably a 'Made in C/J/K/T' product, you may not find the exact part here in the US (if that is where you are).
Mouser electronics is one of the few sources for one-off buys anymore.
They will have dozens to choose from but probably not the original - who wants the same crappy relay anyhow?
Posted on Aug 06, 2008
Fan on heater don't work on 2005 Buick Lacrose
Then you either have a blown blower motor relay or the blower motor itself is toast.
Dec 07, 2017 | Buick Cars & Trucks
Indoor blower won't shut off on heat pump
I would look to replace a relay that is not shutting off or replace the thermostat itself.
Nov 14, 2015 | Honeywell Heating & Cooling
Fan wont turn off on bmw 520 i
If it's electric fan then the wiring pig tail is bad or the relay is toast had same problem on electric fan and it was just the wiring at conectors was bad try that k
Feb 21, 2013 | BMW X5 Series Cars & Trucks
When the receiver powers up just the fan seems to go on. Resetting by holding the i/o will turn the yellow light off but doesn't turn the fan off and comes back on after you release the i/o...
Hello Joe, my name is Becki, with DISH Network. You will want to make sure that the receiver is in a well ventilated area, and that there is nothing heavy sitting directly on it. The receiver's fan can start running constatntly if the unit starts to overheat. You may also want to try putting the receiver out on the floor for a few hours to cool down. You can also try to unplug the receiver from the power source for 10 seconds, that can be a more thourough reset than holding the power button down. The fan will run while starting the receiver up, for about 5 minutes, then it should stop running loudly. If you continue to have problems, please let me know!
Becki Barned
DISH Network Customer Service
Jul 13, 2011 | DISH Network ViP 612
My 97 civic will not start. I have a good battery, power to the starter cable, lights and radio work. I don't have power to the ignition side of the starter- the small wire attached to the solenide has no...
The starting system's pretty simple. If you're getting no voltage to the solenoid wire when you turn the key, then the fuse is burned out, the starter switch is bad, or a starter relay is bad.
If it's an automatic, the neutral switch could be bad or misaligned. Hold the key in the start position and jiggle the shifter around. Try starting it in "N" instead of "P". Try forcibly pushing the shifter past "P" while you try to start it.
If it's a 5-speed, the clutch interlock switch could be toast. Try holding the key in the start position and push the clutch pedal up and down, including hard to the floor. Look under the dash at the switch, make sure it's not physically broken and the wires are attached.
Check all the fuses.
Find the starter relay. If there's another relay just like it there in the relay panel, swap them. If the car turns over after that, go buy a new relay.
If you just need to get to work right now, use a piece of jumper wire from the + terminal of the battery to the starter solenoid terminal on the starter and start the engine that way, just make sure the key's on, the parking brake is set, and it's in neutral!
Dec 31, 2010 | 1997 Honda Civic
Toast wont stay down in toaster it wont lock in place
I'm at the same crossroad. Thry holding down the lever for more than 4-secs. The light will blink once, then it is as though the circuit is over-ridden and a toasting cycle will begin. This might help to eliminate wether you have a mechanical or electrical issue. Mine appears to be electrical. I'm now investigating if it is the timing or relay?
Jul 15, 2009 | DeLonghi CTH4003 4-Slice Toaster
Floor standing fan
check fan motor or control relay.
Sep 05, 2008 | Microwave Ovens
Patton Electric U2-20 Box Fan Logo
259 people viewed this question
Top Patton Electric Dryers Experts
Vernon Taylor
Andrew Taylor
Andrew Taylor
Are you a Patton Electric Dryer Expert? Answer questions, earn points and help others
