Question about Kodak Office Equipment & Supplies
Ref kodak esp3 firstly keepa saying printer not responding paper jamms have cleared it but still jamms to right side cannot afford engineer
  • Kodak Master
  • 17,130 Answers
Try also to reinstall driver software after removing printer so as to reset. it this wont work remove the rollers to check as there seems to be fault in the transport of the paper in the rollers. So if you have used any adhesive sticker printing, it is possible that some glue has got clogged into the rollers. If not there can be some jammed paper in the rollers or the mechanism.
So start this work only if you are mechanically able with the right tools.
Remove the covers to get access to the mechanism . Remove the motor drive assembly , the fitting of the motor to the mechanism. Once this is removed the rollers can be turned manually so that you will be able to feed a paper to see the progress of the movement while studying if there is any obstruction or damage to the paper.
There is a in-detect sensor, usually an opto-coupler , make sure this is not clogged or dirty as this IR detection feeds the signal to the processor for starting the motor drive feed.
Reassemble but make sure the rollers are aligned to be in equal gap to feed the paper without a side pull. Now you must print and see if the fault has changed. If not repeat the above work to confirm the area of obstruction
Posted on Apr 08, 2011
SOURCE:
My power switch and the error button won't stop blinking on my Kodak printer.
my printer is not printing paper and the paper not insert the printer
Sep 29, 2012 | Kodak ESP3 AllInOne InkJet Printer
My ESP 3 wont print have changed both ink still wont Why?
HAVE KODAK ESP RECENTLY CLEARED PAPER JAMM
NOW IT S NOT PRINTING OR SCANNING
Sep 09, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Printer says paper jam, now scanner wont work
you will need to open it to remove this piece of paper.
Aug 14, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Paper jam on my ESP3 printer. How do I get the
Go to www.kodak.com/go/itg and select all in one printers and then paper jam as your problem. they will give you step by step instructions to resolve the issue. if this does not solve the issue, call kodak @ 1800 421 6699 and they will replace the printer for you free of cost as all the esp-3 printers are in warranty as of now.
Aug 07, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak esp3 says ink is gone...its actually full and its saying theres no paper and there is im soo aggrevated please respond yo [email protected] thanks
upgrade the firmware of the printer,before dat, go to www.kodak.com/go/printheadsupport.click on 3rd link on how to replace a printhead. then take cartridges out and printhead out, after 1 minute,insert printhead back into the carriage and install both cartridges, go to kodak aio home center on ur desktop and from there on mai ntenance under help and select printhead cleaning. then try to print.ur problem will be resolved
Jul 19, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Error code 1-2036 on Kodak ESP3 printer
this error code is for printer scanner. run clear utility from www.kodak.com/go/clear
and reinstall kodak software from
www.kodak.com/go/downloads.
Note-  Do not connect your printer while installing the software untill installation wizard say to do so.
MS
Jun 14, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Esp3 printer, has new cartriges, printing very fient
Have you tried the maintenance tool - if you open the kodak printer status monitor in your taskbar (next to the clock); at the top right hand side you will see an icon showing crossed hammer and spanner, click on this and run the tools from top down (dont need to do the test page).
If that doesnt work you could try this:-
my new esp3 printer (replaced due to not printing black) came with a suppliment document for action if no black or faint print appears!!:
verify paper is loaded into paper tray then press and hold the Cancel and Copy/Resume buttons simultaneously until the On/Off light flashes -apparently this fixes the no black/faint issue.
hope this helps
Jun 10, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Unable to get ESP3 to work after a paper jam. Cleared the guide at the back. Whats next?
Decided to press resume/copy and as the cartridge was cycling to the left pulled the plug. The cartridge was now stuck on the left and the right section of the printer was now accessable. Removed a piece of paper that got crumpled in and the problem was resolved on re start.
Jun 06, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Trouble printing envelopes on kodak esp3 printer
Have you tried this procedure?
Loading Envelopes
You can load plain envelopes into the paper tray of your Kodak ESP 3 All-in-One printer.
Important Do not use envelopes with cutouts or cellophane windows.
1 Remove any other paper from the paper tray.
2 Insert one or more envelopes into the right side of the paper tray with the print side down and
the envelope flaps on the right, pointing left.
3 Squeeze the paper-width guide and move it to its right-most position up against the envelopes.
4 Leave the paper tray open while the envelopes are loaded.
If you have and it's not printing correctly, there is probably a problem with the document you're trying to print.
Jan 16, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Open Questions:
KODAK Printer NuMbER @[+1-855*536.5666] NEW YORK Kodak Printer Customer Care Phone Number. Kodak is a very famous American technology company where manufutre many types of products for their customers like Lens Packaging Functional Printing Graphic Communications Printer Photographic Materials and also professional services for businesses around the world.Kodak Printer TeCh sUpPoRt Number to resolve all Kodak Printer products. Kodak Printer is an American multinational company which was founded by Kodak Printer using its company headquarters in Round Rock, United States of America.Contact Kodak Printer for Setup & Installation Kodak Printer Setup Service & Installation Kodak Printer Customer Service number Connect is a utility ... KODAK PRINTER products. JCG is an American multinational company which was founded by Michael KODAK PRINTER using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, KODAK PRINTER SUPPORT number, and selling of computer-related services and products. KODAK PRINTER INSTALLATION Phone Number Recently, KODAK PRINTER has been named the number KODAK PRINTER TECHNICALnical SUPPORT advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, KODAK PRINTER technical care number can be dialed to contact the certified TECHNICALnicians Contact TECHNICALnical SUPPORT Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a KODAK PRINTER Service Tag or a KODAK PRINTER Get KODAK PRINTER TECHNICALnical SUPPORT Phone Number and Technical Services. KODAK PRINTER is a US-based multinational TECHNICALWe are creating efficient solutions every day by Kodak Inkjet Printer Support Number are troubling you with Kodak printers. Accordingly, we have produced the possibilities of solving those issues that you can spend more time on solving and failed again. We have assigned engineers with loads of experience who knows which solution is perfect for the problem. The Every problem should be fixed in order to prevent any further damages to the Kodak printer. Due to Leaving any problem can further damage other parts of the Kodak printer. We have the advanced tools to thoroughly analyze your printers root problems and eliminate them with proper method. Call the Kodak Inkjet Printer Repair now and get in touch with our consultants to resolve your printer issues.
Sep 20, 2019 | Kodak Office Equipment & Supplies
KODAK Printer NuMbER @[+1-855*536.5666] TECH SUPPORT We are creating efficient solutions every day by Kodak Inkjet Printer Support Number are troubling you with Kodak printers. Accordingly, we have produced the possibilities of solving those issues that you can spend more time on solving and failed again. We have assigned engineers with loads of experience who knows which solution is perfect for the problem. The Every problem should be fixed in order to prevent any further damages to the Kodak printer. Due to Leaving any problem can further damage other parts of the Kodak printer. We have the advanced tools to thoroughly analyze your printers root problems and eliminate them with proper method. Call the Kodak Inkjet Printer Repair now and get in touch with our consultants to resolve your printer issues.Kodak Printer Customer Care Phone Number. Kodak is a very famous American technology company where manufutre many types of products for their customers like Lens Packaging Functional Printing Graphic Communications Printer Photographic Materials and also professional services for businesses around the world.Kodak Printer TeCh sUpPoRt Number to resolve all Kodak Printer products. Kodak Printer is an American multinational company which was founded by Kodak Printer using its company headquarters in Round Rock, United States of America.Contact Kodak Printer for Setup & Installation Kodak Printer Setup Service & Installation Kodak Printer Customer Service number Connect is a utility ... KODAK PRINTER products. JCG is an American multinational company which was founded by Michael KODAK PRINTER using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, KODAK PRINTER SUPPORT number, and selling of computer-related services and products. KODAK PRINTER INSTALLATION Phone Number Recently, KODAK PRINTER has been named the number KODAK PRINTER TECHNICALnical SUPPORT advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, KODAK PRINTER technical care number can be dialed to contact the certified TECHNICALnicians Contact TECHNICALnical SUPPORT Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a KODAK PRINTER Service Tag or a KODAK PRINTER Get KODAK PRINTER TECHNICALnical SUPPORT Phone Number and Technical Services. KODAK PRINTER is a US-based multinational TECHNICAL
85 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Clive
Clive
Ekse
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
