Question about Frigidaire Refrigerators
I have a Frigidaire RL003B. The problem is that the unit seems to be continually running. I would expect it to switch off when it gets down to tem., and to switch back on when the temp. rises. Does this mean it needs regassing? If so how do I go about getting it done?
  • Frigidaire Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Apr 08, 2011
My Frigidaire FRS26H5AS temperature control on the freezer section does not seem to work.
Hello Greg Olsen, thanks for your post!
From my understanding your Frigidaire refrigerator, FRS26H5AS, runs continuously and the only way to stop it is by unplugging the power cord. It sounds like you may have a possible faulty thermostat or control panel and that is why the compressor will not shut down. I would recommend consulting with a professional for proper diagnosis and repair to be completed. I hope this information has been helpful. -Matt
Oct 25, 2014 | Frigidaire Refrigerators
Frigidaire Affinity ATF7000E Front Load Washer won't stop spinning with 1 minute on timer- it continues until I hit cancel. I don't like to babysit a machine but have to make sure it doesn
If the unit is washing properly, as far as you can tell, but it won't stop spinning, then I would have a professional look at the control panel and timer to be diagnosed because there seems to be in miscommunication.
Sep 14, 2012 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Freezer, model # FFU20FC6AW3. Unit is not cooling and the fan motor inside behind the access panel is not running. My Temperature Alarm sounds and will not shut off, unless I switch it to the...
if the evap fan is not turning try to turn it by hand a few times then start you freezer if it does not turn it needs to be replaced.make sure there is no ice build up on the evap coils.alos check the continuity of the defrost heater below the evap coils.once you het teh fan replace your unit should cool down to the proper temps.
Nov 16, 2010 | Frigidaire Freezer Refrigeration White...
The freezer seems to be running a lot. Is this normal for an energy efficient freezer?
Good day,
Yes, the new high efficiency units tend to run a lot compared to older models. That in fact is not a bad thing, since the compressor has to cycle on and off fewer times per day, and starting and stopping are what create wear and tear on refrigeration equipment. Actually you pay less because of the much smaller compressor that uses less power.
However, keep an eye on it. If it gets continually worse going forward, call for service. Hopefully Frigidaire has solved it's problems but was known to develop internal restrictions in the refrigeration system causing that problem to the point it runs continuously and fails to cool properly.
If the machine is under 5 years of age it would be corrected free of charge.
Oct 26, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Frigidaire SbS fridge FRS26ZGED3 intermittent - smacking helps
I have been looking over the wiring diagram for about 10 minutes. I see nothing other than the thermostat being the problem. I need someone to unplug the refrigerator and go into the control panel and disconnect the two wires going to thermostat and plug refrigerator back in and then give me the results. You feel comfortable doing that? Sea Breeze
Mar 19, 2010 | Refrigerators
Dose not seem to keep cold and tem control flsshes
The control panel light would flash if the compressor overheats( due to constantly being on & running) This could be a result due to leakage of refrigerant gas(freon, CF4,etc.), hence get the gas pressure checked too when getting repaired.The red light could also be an indication that the drain pipe(s) being clogged. Finally get the thermostat checked and replace if it is not maintaining the temperature it is being set for.....................sodeep
Sep 18, 2009 | Refrigerators
Fdb4315lfc2 dishwasher keeps filling up
relay switch is sticking in the open position... the float mechanism tells the unit when to stop pumping water out...
Sep 03, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Refrigerators Logo
48 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
