Question about MGE UPS Galaxy 3000 UPS System
Hello I have a problem on MGE Calaxy 3000 20KVA UPS. I change the batteries with new batteries when i put it on, the battery status deos not come just give me xxx . before has this erorr "UPS TEMPERTURE Fault" But I clean the Cooling Circle. and now it is ok. just the battery status deos not come means discharging. if i take AC IN off it will shut off in 1-2 minutes
I have a galaxy 3000.with 24 batteris and they are dead ,when i check Dc float is 270V that gives me 27 batteries .shoul i put 24 as it was or 27 to accomodate the float voltage
Posted on Sep 06, 2011
    New Friend:
  • 14 Answers
The Galaxy 3000 uses a software which has all the data of the batteries used for the commissioning. However if the battery replaced are not of the same specification then the XXX would appear, meaning the software cannot match the specifications. Please try for first principle, check the ac in, check the rectifier and so on. Across the battery circuit breaker (in off position) compare the battery voltage and the charging voltage. This would give you an indication if the charger is working.
Posted on Apr 08, 2011
Hello, our MGE GALAXY 3000 20kva, front panel display is frosen. UPS still operates but not able to use any buttons to see ups status. Also alarm states "internal communication fault". Would appreciate...
you need an MGE expert engineer to check on the internal components, maybe the display by itself it dead can be replaced while UPS is on no problem. if you want to switch off the UPS you go for force shutdown but I cannot guarantee will restart if you do not fix the fault.
Aug 09, 2013 | MGE Galaxy 3000 UPS System
Hello my UPS MGE 850 evolution is just blinking a red alert and does not charge even when conected to the power suply.. What could be the problem??
Battery has drained and gone.
Get new battery here http://www.battery-direct.com/ups/MGE-Evolution-MGE-EV850R.html
Please rate if this solved your problem.
Apr 19, 2011 | MGE Evolution 850 (68453) UPS System
Mge ellipse ups 1200 wont turn on/power up
hello, ik got a lot of these UPS for repair. I exclude any battery problem that I suppose you already checked. The Systems I have here does all have problem at charger electronics (VT 9 or components around) mostly burned out (short circuit). No repair is possible as copper lines are burned.
Apr 05, 2011 | MGE UPS Pulsar Ellipse 1200 UPS System
Mge galaxy 3000 how to reset battery expire alarm after battery change
Unfortunately the reset is only possible with MGE software (Softunor).
Jan 24, 2011 | MGE UPS Galaxy 3000 UPS System
Hello, could you please tell me the battery type of this UPS model in order to change it? Thank you.
12V (Per Cell)
6Ah
Dimensions
151mm x 94mm x 51mm (Per Cell)
Sealed Lead acid battery - you need 2 of these!
Oct 05, 2010 | MGE UPS Pulsar Ellipse Premium 800 UPS...
Hello, could you please let me know the battery type of MGE premium ellipse pulsar 800VA ups? Thanks in advance.
The batteries in an UPS are sealed lead acid batteries. The voltage and amp hour rating depends upon the VA rating of your UPS.
I suggest you shut down your UPS and remove the batteries and get replacement ones that are the same rating as the ones in the UPS. Be careful of the size of the battery, they are a neat fit inside the UPS battery compartment.
Hello Ive got cooling fault on my galaxy 3000 can u help
try to check the fluid in the cooling system, if it's full. then try to check the sensor on the cooling cap, or maybe change the sensor. Hope this help.
ps: cooling liquid is not water ( buy it from mge, i forgot what's the name )
Sep 04, 2010 | MGE UPS Galaxy 3000 UPS System
Mge pulsar 3000 does not power up
MGE Pulsar 3000 is an online UPS. try to check the battery first if its ok. coz for an online UPS it will need to have a good working UPS battery to trigger the switching relays to on the online UPS unlike backups UPS that can be turn on without any batteries
Aug 13, 2009 | MGE UPS Pulsar Evolution 3000 UPS System
MGE Galaxy 3000 UPS shows charger internal fault .
mge galaxy 3000 battery circuit breaker shut off when normal power shut off too.plz help !!!!!!
Jul 29, 2008 | MGE Galaxy 3000 UPS System
MGE UPS Galaxy 3000 UPS System Logo
417 people viewed this question
Top MGE Computers & Internet Experts
Raj Patel
Are you a MGE Computer and Internet Expert? Answer questions, earn points and help others
