Question about Philips Food Processors
When ever i try to fix the jar with button to lock the arm OL:-- starts blinking then Iswitched it off reduced the load in the jar waited for half an hour then pushed the red button at the base of the processor then I switched it on again still the problem remains the same please help
Can I get replacement jars for my Bullet
You can Linda
  • magic bullet replacement parts ' eBay www.ebay.ca > Search > magic bullet replacement parts Find great deals on eBay for magic bullet replacement parts and magic bullet ... 1 Cross Blade Assemly with Seal Ring Gasket For Magic Bullet Replacement Part. C ...
  • Magic Bullet Cups and Lids ' eBay www.ebay.ca > Search > Magic Bullet Cups and Lids Magic Bullet Replacement Cups Blade Juicer Strainer Pusher Pitcher Lids . ... 19 Magic Bullet Replacement Parts 8 Jars Various Sizes 5 lids 4 Rings Strainer .
  • Magic Bullet Blender Cross Replacement Blade w ... - eBay www.ebay.ca > Search > Magic Bullet Blender Cross Replacement Blade w Gasket Find best value and selection for your Magic Bullet Blender Cross Replacement Blade w ... MAGIC BULLET Extractor Cross ... Magic Bullet Replacement Parts Tall ...
  • Magic Bullet Replacement Parts ' eBay 2q== www.ebay.com/bhp/magic-bullet-replacement-parts Find great deals on eBay for Magic Bullet Replacement Parts in Blenders ... you can find Magic Bullet replacement parts, including the Magic Bullet ...
  • Canadian Tire Magic Bullet Magic Bullet Single Shot, 12-pc ... answers.canadiantire.ca > ... > Kitchen Q & A > Small Appliances Q & A Canadian Tire customers questions and answers for Magic Bullet Magic Bullet Single ... Is there anywhere in Canada where you can buy/order replacement blades? (see ...
  • Amazon.com: nutribullet replacement jar www.amazon.com > Search > nutribullet replacement jar ... nutribullet replacement jar. Just 6 days until Prime Day! Amazon Try Prime All Go. Departments. Hello. Sign in Your Account Sign in Your Account ... by Nutri Bullet.
  • 2x Magic Bullet Flip Top Lids Replacement Part Original ... https://www.amazon.ca/Magic-Bullet-Flip-Replacement-Original/dp/B... 2x Magic Bullet Flip Top Lids Replacement Part Original Fits all Mugs ... YESURPRISE Replacement Seal Lid for Magic Bullet Blender ... Ball Jar Crystal Jelly Jars ...
  • Homemade Magic Bullet: Using a Mason Jar with Your Blender www.primermagazine.com/2011/learn/homemade-magic-bullet-using-a... Video embedded · Homemade Magic Bullet: Using a Mason Jar with Your Blender ... For $.79 each I picked up a bunch of mason jars and now have an easy ... Homemade Magic Bullet...
  • Replacement jar for Magic Bullet? ' Yahoo Answers ph.answers.yahoo.com > ... > Other - Electronics > Next
    • RESOLVED
    • 3 POSTS
    • 2 TOTAL ANSWERS
    2009-07-23 · Anyone successful at buying replacement jars for the Magic Bullet blender? No luck @ www.buythebullet.com or by phone to customer services. No ...
  • Magic Bullet Blenders and Accessories ' eBay www.ebay.com/bhp/magic-bullet Find great deals on eBay for Magic Bullet ... Cook in style with eBay's huge selection of Magic Bullets, ... What you receive:2 Magic Bullet Replacement Tall ...
  • Aug 10, 2016 | Food Processors
    I press a button n it blinks then all the buttons start blinking and the motor never starts.
    The motor is most likely open circuit. Solutions are going to be either replace the motor OR if the thermal fuse on the windings is blown you will need to get one of the same value and replace it. The value is written on the fuse and it is under some fibreglass tape on the field winding with the aluminium clip around it. You need to remove the motor completely to do it.
    Jan 05, 2014 | Wolfgang Puck Bistro 620 Food Processor
    Cannot turn on my new FoodProcessor
    You might have figured it out, but the problem is that you haven't locked the jar properly. Be sure that everything es lined up, and that you have turned the jar and locked it with the machine. If you do this, you will be able to turn the button from 0 to I even if there is no power.
    Feb 13, 2012 | Braun K 3000 Multisystem Food Processor
    The rubber gear attachments with the grinding glass jar is somewhat burned because if i put the vegetable to grind it wont but if i will start the machine empty without any vegetables it works.Can you...
    Are you sure the rubber gear is burned? have you turn the plastic lock on the bottom, so everything is thight? have you checked that the plastic O-ring is well placed?
    Mar 12, 2011 | Braun K 3000 Multisystem Food Processor
    Braun blender blade stuck in the jar and cant seem to take it out
    Some bike locks go through the wheel and are about six inches long and are tempered. you can insert it in blender between the blades and use a pipe or screwdriver to apply leverage without having to get near cutting surface with body parts
    Mar 02, 2009 | Braun K 750 CombiMax Food Processor
    Hello
    Somehoe the blade inside the jar ahs come loose, look on top of the blade you should see a nut if not you should see threads if you see threads then you have lost the nut.
    Feb 26, 2009 | Wolfgang Puck BFPR0035CF Food Processor
    FPB-5PC How to remove blade
    I would suggest wearing heavy gloves and removing all glass shards from your work area. If the shards have completely separated from the belnder collar, then you are done. If not, carefully unscrew the lid from the collar. If it won't budge, submerge the collar and blender jar parts in a very large bowl with vinegar - after 20-30 minutes, try unscrewing again (don't forget those gloves). As expensive as ther eplacement blender jar is, you could just reorder the other parts if this does not resovle the issue.
    Nov 10, 2008 | Cuisinart FPB-5PC 5 Cups Food Processor
    Appears to be locked but won't turn on
    ah! well my mother just tried using her DLC-10S 7 cup food processor and she also encountered the same problem. It worked perfectly fine when she first used it around Christmas time but not anymore.
    After almost smacking the hell out of it we discovered that there is a plastic tab on the lid towards the handle side. This plastic tab actually pushes a lever through the cup and into the base of the food processor.
    New Bee actually mentions this above. The problem is that the flimsy plastic tab in the handle isn't stiff enough to push the lever down anymore. I'm amazed it worked the first time.
    This is very much a design flaw by Cuisinart as there's no way this plastic tab would ever last.
    Now there is a small opening in the case right above the plastic tab. To get our food processor going we just pushed a chopstick down on the tab and held it in place while the food processor runs.
    This is very much a temporary solution until we get a new food processor, obviously a different model.
    Nov 22, 2007 | Cuisinart DLC-10S Pro Classic Food...
    Food Processors Logo
    20 people viewed this question
    Top Philips Food Processors Experts
    Lawrence Oravetz
    Tom Chichester
    Bill Boyd
    Are you a Philips Food Processor Expert? Answer questions, earn points and help others
