Question about Sharp AR-235 Copier
"Error: PostScript printing not licensed
    New Friend:
  • 66 Answers
You have to down load the pcl 6 driver for your machine model from http://support.sharp.net.au/drivers/ and install the printer, because now what you installed is ps driver thats why it is not working, rate this and vote for this.
Posted on May 13, 2011
My SHARP AR-M276 Printer keeps displaying PageError: PostScript printing not licensed for this printer, after downloading and installing the driver. How can I rectify this?
PS license is sold separately as an option for the Sharp Copier. You can contact your Authorized dealer. Or use a PCL6 or PCL4 Driver. If you are having issue printing from a mac then depending on the version you will need postscript, or an aftermarket PCL generic Driver made for macs.
Mar 04, 2017 | Sharp Office Equipment & Supplies
I have a sharp AR-M237 printer and when I try to print is telling me Error: PostScript printing not license for this printer
You need to get the correct driver for printing Post Script. You need to buy the program with the licence to print post script. Good Luck
Jan 06, 2013 | Sharp AR-275 Copier
A sheet prints sometimes with this: ERROR: syntaxerror OFFENDING COMMAND STACK: In one flow we get this error and in other flow it works fine. Any help on this will be greatly appreciated.
This is a Postscript error. You may be using a Postscript driver on the printer. Or else you are printing PDFs which are not true Postscript. likely made by a postscript "compatible" software.
Try loading a PCL driver for the printer. This will work just as well if not better than a postscript driver. You may find it faster.
Check lexmark website under support andd downloads for an alternative driver for the printer, also considering your operating system.
If you are printing PDFs or postscript files, the PCL driver may help there also.
May 23, 2011 | Lexmark T644 Laser Printer
I am currently running windows 7 and using a hp laserjet 1320 PS printer and i keep getting an etrror message saying "This job requires more memory than is available etc etc.." but everyone in my...
To work around this issue, reduce the complexity of your PostScript print job. For example, set the TrueType Font Download option to Automatic, Outline, or Bitmap as follows:
  1. In Control Panel, open the Printers (or Printers and Faxes) folder.
  2. Right-click your PostScript printer, and then click Properties.
  3. Click Printing Preferences, click Layout, and then click Advanced.
  4. Double-click PostScript Options, and then click TrueType Font Download Option.
  5. In the True Type Font Download Option box, click Automatic. If Automatic is already selected, click Outline or Bitmap.
  6. Close the Printer Properties dialog box, and then close Control Panel.
hope this helps you.. please vote.. thanks
May 19, 2011 | Office Equipment & Supplies
My hp color laserjet printer shows 49.4c02 service error on the screen.
49 errors are usually related to the jet direct network card which may need to be replaced. But if only happens from one user or when printing one particular document or from one particular program then you may have a driver or software conflict.
Aug 30, 2010 | HP LaserJet 4700 Printer
Prints PDF documents VERY slowly (4-5) per page
The actual issue you will find that its not so much the actual printing part of the process that is slow, its actually the spooling to the printer that takes the time.
Does your printer support PostScript printing ? (PostScript is a printing & imaging standard used by many printers) To find out if your printer does indeed support this either refer to your manufacturers documentation or perform a test page and look to see if you have a PostScript enabled option.
If your printer does support PostScript, make sure you are using its PostScript printer driver, most of the time we generally use PCL drivers, so simply change this.
Regards....
If you find your printer does not support PostScript there are a few other tweaks we can implement to increase printing speed.
Firstly we can force PDF files to be printed as graphics as opposed to text, to do this launch your chosen PDF viewer, select Print > Advanced > Print as image
Lower the print resolution, if we lower the print resolution most of the time the difference is very small, but it can reduce the actual print size of the document by up to 300%, which can greatly decrease printing times.
Make sure you are using the latest version of any print drivers or your chosen PDF printing program, normally Adobe Acrobat.
If the printer only has a small amount of memory if possible add more, if possible install a PostScript SIMM.
Check the amount of ram your computer currently has, check memory usage from task manager when printing to ascertain usage
May 19, 2010 | HP Color LaserJet 2600n Printer
I cannot print pdf-file. Why?
1. Choose Start > Settings > Printers (Windows 2000) or Start > Printers and Faxes (Windows XP). 2. Right-click the printer, and then choose Properties from the menu. 3. Click the General tab, click Printing Preferences, and then click Advanced. 4. Expand the Document Options, and then expand the PostScript Options. 5. Set Send PostScript Error Handler to Yes.
http://kb2.adobe.com/cps/316/316508.html
Jan 20, 2010 | Samsung SCX-4500 Laser Printer
DISPLAYS ERROR MESSAGE: W2 INVALID PERS. WHAT DOES THIS MEAN AND HOW DO I GET IT TO PRINT?
FROM THE SERVICE MANUAL
W2 INVALID PERS:
The job was not printed because the requested personality,
such as PostScript, was not installed. Install the language in
which the files are sent, together with enough memory to
support that language.
I SUGGEST CHECK IF YOU GOT THE POSTSCRIPT INSTALLED
May 04, 2009 | HP LaserJet 4 plus Printer
Mac laptop hooked up to HP laserjet 4 plus gets error message:
This printer will not work with a Mac - it has no postscript.
The only laserjet 4's that work with Macs all have an "M" in their name - 4M, 4M Plus etc.
You might be able to get a Postscript personality module for the printer to effectively upgrade it to the "M" version.
Feb 05, 2009 | HP LaserJet 4 plus Printer
Canon IR C3100n copier "NG 853" error
I had a similar problem with my MF6540. I could access the remote UI and see that the printer was recieving information via the print log. It would list all of my test pages that I tried to print but in the print results column I would get an error code NG(##5536) and the printer would not actually print anything. I tried the UFRII driver stated above and everything seems to be working now.
Sep 17, 2007 | Canon imageRunner C3100 Copier
Sharp AR-235 Copier Logo
4,248 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
