Question about Maytag MSD2756G Side by Side Refrigerator
My Maytag ice maker is making ice but will not dispense cruhced ice. The metal arm that propell the ice into the cruched has slipped of its slot and I can't get it bak in any ideas?
  • John Tripp
    John Tripp Apr 08, 2011
    Sure I have a solution but you must be willing to reply to my questions. I may have things to ask you and you will again ask me until solved. I have the Technical Service Manual and free photo's to assist you problems regarding your MSD2756GEB, Just write back OK and I will assist you. The first question will be=> Are the parts the parts behind the back freezer ice bin wall and related to the 61005253 solenoid and 61005844 Yoke Assembly? Thanks, Sea Breeze
4 Suggested Answers
  • 30 Answers
SOURCE: Ice maker quit making ice
There are repair instructions available for this particular ice maker at www.AnyoneCanFixIt.com Specifically, you should locate it at www.anyonecanfixit.com/household.htm
Posted on Sep 23, 2009
woodchuck789
  • 4059 Answers
SOURCE: ice maker dispenses cruched ice in cube ice mode
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid.
With your model number I can find a diagram which may help.
Posted on Oct 05, 2009
  • 532 Answers
SOURCE: Maytag sidebyside MSD2758DRW ice maker won't make ice
If the ice maker no longer make ice, check the following.
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on.
On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice.
Check your door seals and thermostat, repair/replace as necessary.
Thanks
Posted on Jul 12, 2010
We have a 7 year old Kenmore Elite trio. The ice maker continues to make ice, but won't dispense it. It appears that the plastic ice shut off arm is stuck in the up position. How can I get it unstuck
Most arms on ice makers are metal.
You might have to take the food out of the freezer temporarily and put the food in an ice chest and disconnect the refrigerator and let it unfreeze the plastic arm.
Jun 14, 2017 | Kenmore Refrigerators
Mu Kenmore refrigerator's ice maker is dispensing crushed iced even in the cube mode
Take out the ice bucket and check the metal arm and make sure it moves freely. Ice may have gotten stuck.
Jul 20, 2016 | Kenmore Refrigerators
Why is icemaker making a clicking sound?
Ice Maker Not Dispensing Ice ' ThriftyFun
www.thriftyfun.com/Ice-Maker-Not-Dispensing-Ice-4.html
Sometimes your refrigerator ice maker makes ice, but does not dispense it. ... If it gets pushed all the way back to the ice maker it prevents the metal arm from full ... Itry not to put anything on the shelf over the bin and also try to keep it pulled out just a little ... My ice maker is making a clicking noise and not making much ice.
Ice maker making ice, but won't come out thru door
www.appliance-repair-it.com/ice-maker-making-ice-but-wont-come-out-...
If when you attempt to dispense ice (and it doesn't work) the whole refrigerator seems to .... Many have just bought a new refridgerator or don't use the ice dispenser. ... I'vetried to decrease the cold in it from the dial and that doesn't help. ... The motor was working and the auger would turn with no ice in bin but the added ...
Dec 25, 2015 | Samsung RH29H9000SR RH29H9000SR 29 cu. ft....
How do I get the ice maker to produce for the first time
Is the arm that gets pushed up by the ice cubes (in order to stop making ice when it is full) in the down position? it is able to be pushed up and locked so that the icemaker doesn't make at ice and may need to be pushed down.
Aug 27, 2014 | Maytag MSD2454G Side by Side Refrigerator
Ice maker not making ice
should be in the down position the way it works is when the ice is dispenced into the bucket the arm at the same time raises up once there is enough ice the ice keeps the arm up stoping the ice maker
Apr 14, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice maker dispenses cruched ice in cube ice mode
Oct 05, 2009 | Refrigerators
Aug 24, 2009 | Maytag MFD2560HES Bottom Freezer French...
Ice maker overfill
The metal off/on arm may be disconnected. A full bin should keep the arm in the up position and shut off the ice maker.
Remove, then re-insert the metal arm in the back of the ice maker control head.
Make sure that a full bin of ice activates the control arm.
You may need to buy a replacement arm that is longer so that the ice catches on the arm.
May 20, 2009 | Jenn-Air JCD2295KES Stainless Steel
Maytag Refrigerator Ice Maker
  • first make sure the metal arm to the right of it is lowered, this turns the icemaker on.
  • then you can check the water supply to make sure it is turned on, sometimes when houses are vacant they turn the water off as a precaution. the valve may be behind the refrigerator or under the sink in the kitchen.
  • then...
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Jul 04, 2008 | Refrigerators
My icemaker is not making ice. This has happened 3 times in the past 3 years but this is the longest it has gone without making ice. The other 2 times it lasted 2 days. It has now been 4 daysince the ice...
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
May 15, 2008 | Amana Refrigerators
Maytag MSD2756G Side by Side Refrigerator Logo
141 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
